| Author |
Message |
Topic: no heat in my 71 |
CANTED
Forum: Heating
& Air Conditioning Systems Posted: Wed Nov 19, 2008 8:23 pm Subject: no heat |
| Your problem is probably not at the controls, Chad. To look in at that, the easy way is to pull the dash pad. Remove the row of screws along the top of the plastic part of the dash, there will be two ... |
Topic: rewire 82 el camino |
CANTED
Forum: Electrical Systems Posted: Wed Nov 19, 2008 7:53 pm Subject: wire diagram |
| Welcome to ECC, John. Not sure if they will help but here is how to get to the wire digrams on the site. On the top right of the home page, click electrical systems, then scroll down that page untill ... |
Topic: Caballero won't start? |
CANTED
Forum: Electrical Systems Posted: Wed Nov 19, 2008 7:21 pm Subject: fuse link |
| Yes, this will open the circuit to your fuse block. |
Topic: HELLO, FROM VIRGINIA |
CANTED
Forum: Messages
for new forum
members Posted: Wed Nov 19, 2008 7:01 pm Subject: Welcome |
| Welcome, Paul. Tell us about your carburetor problems in the engine section, perhaps someone can help. Ease up on the all caps though, makes it hard to read. |
Topic: OMG! HALL OF SHAME! OMG! |
CANTED
Forum: General
BS Topics Posted: Wed Nov 19, 2008 6:52 pm Subject: blue oval |
| I don't see how that thing makes it into our hall, the Raunchero hall, no question. |
Topic: some wierd stuff |
CANTED
Forum: Engine
Topics Posted: Sun Nov 16, 2008 9:40 pm Subject: PCV line |
| About a 3/8 hose from the base of the carb to the PCV valve mounted in the valve cover. Check your idle speed, too high can cause run on. Carbon build up is also possible, get some sea foam from the p ... |
Topic: Where can I find clock works? |
CANTED
Forum: Interior
Restoration Posted: Sun Nov 16, 2008 9:33 pm Subject: clock |
| OPGI says theirs fits 64-72, must be a Borg clock, 80 bucks. |
Topic: Can not find wind noise |
CANTED
Forum: General
BS Topics Posted: Sun Nov 16, 2008 9:23 pm Subject: noise |
| Does not sound like wind noise if it will do it with the windows down. |
Topic: Are you a mechanic? |
CANTED
Forum: General
BS Topics Posted: Sun Nov 16, 2008 9:15 pm Subject: disagree |
| I don't buy it Mike. The side gears travel with the carrier when going straight. They mesh with the spider gears which as you stated are not turning. Any back lash between these four should not be an ... |
Topic: Rear Quarter Skin Replacement on a 72' |
CANTED
Forum: Body
Restoration Posted: Sat Nov 15, 2008 10:16 am Subject: interchange |
The quarters are cut off, then the new ones put back in their place. Lots of cutting grinding drilling. If it is not a full quarter, the section to be replaced is cut off.
You can add the 70' parts ... |
CANTED
Forum: General
BS Topics Posted: Sat Nov 15, 2008 9:59 am Subject: trick |
Ok, Neil, Ill bite. #1. A hacksaw blade will cut just about anything.
#2. The bottom is not moving, it is on the ground.
Got to be a trick, let's have it, I can take it.  |
CANTED
Forum: General
BS Topics Posted: Sat Nov 15, 2008 9:51 am Subject: ASE |
| I take exception to the way they word questions. At times there is room for argument, but that is not possible. On the axle question, I liked A&D but there was no answer for both. If the pinion is ... |
Topic: 454 or 502 in a '79 |
CANTED
Forum: Engine
Topics Posted: Fri Nov 14, 2008 10:37 pm Subject: plug |
Well deserved, Neil. We will be in Palm Beach May 9-15, looking forward to a ride in it.  |
CANTED
Forum: General
BS Topics Posted: Fri Nov 14, 2008 10:27 pm Subject: test |
| C,D. |
Topic: Bumper lights added |
CANTED
Forum: Electrical Systems Posted: Fri Nov 14, 2008 9:41 pm Subject: Bumper lights added |
| I have seen this done and wanted to do it to mine. The reflector housings in the bumper are the backup light housings from the 68/69 minus the bulb fixture. I thought it would not be that big of deal ... |
