I've decided to put in a diverter valve. I am using the 69's version. I was wondering if anyone knows which hose I divert? The one from the water pump or from the intake? The hose size looks to be the ...
Ok- I got home a little early for the 4th celebration and went through all my manuals and exploded views. I took out the glove box and disconnected the heat/cold cable on the unit and put it in a posi ...
On the 68 model, is there a heater control valve that lets coolant through? The only vacuum I have is for actuating the vent doors. Is the valve located inside the evaporator unit? I know on later yea ...
I will try the cut off this weekend coming but I'm a little bummed to have spent so much care in rebuilding the evaporator unit and to have it not work properly (so I tend to believe). Inside the car, ...
I have a 68 ss 396 with original a/c. I have restored the car and the a/c system- everything is new-compressor, condenser, evaporator, dryer, expansion valve, hoses and vir ...
