Not to mention lower springs will screw up the front end alignment. It may be tough getting it aligned properly with a 2" drop. A lot of shops won't even try to align a car with cut / lowered springs.
I did this on my S10 pickup and wore through a set of new tires in under a year, and the front control arms bottomed out on EVERY pothole.
I would go with drop spindles, they keep the stock springs and alignment. _________________
I thought about springs too, but ended up going with Belltech drop spindles. I think it was a 1.5" drop.I was also originally going with a Hotchkis rear bag kit,but instead went with Belltech Nitro Drop shocks.Everything works well,and I have the nose-down raked look _________________ '79 Chevy Corvette,350 sbc- '78 Olds Cutlass Supreme,350 sbo'- 99 Mitsubishi Galant,3.0 V6- '84 Chevy El Camino Conquista,305 sbc
A 2" spring drop should put your suspension in an alignable position. If the money's there, do 1" drop springs and SC&C Stage 2 kit. _________________ Dustin
Posted: Sun Jun 29, 2008 5:42 pm Post subject:
My Elky in not a 5th gen, but a 4th gen. I have the 2" lowering springs on mine. Also had no problems with Alignment, but it also has all new front Poly Bushings that also helped with that. Side shots below.
I have a 5th gen (84) and lowered it with shorter springs. Had no trouble getting it aligned. Also I have no tire wear issues. I do like the way the car hangs in on curves and freeway ramps.
I have a 5th gen (84) and lowered it with shorter springs. Had no trouble getting it aligned. Also I have no tire wear issues. I do like the way the car holds on in curves and freeway ramps.
Since I installed the drop spindles, a HUGE front sway bar & new shocks my 84 takes corners like its on rails. The stock wheels & tires are still mounted,but I have 17" tires,& when I get the wheels,it should be even better. _________________ '79 Chevy Corvette,350 sbc- '78 Olds Cutlass Supreme,350 sbo'- 99 Mitsubishi Galant,3.0 V6- '84 Chevy El Camino Conquista,305 sbc
