El Camino Central :: View topic - 79 Temperature Blend Door Problem?
dlc1979
Necoa #: 11714
PostPosted: Fri Sep 19, 2008 1:02 pm    Post subject: 79 Temperature Blend Door Problem? Reply with quote
The temperature blend door, the one controled by the sliding lever and is cable operated, doesn't open completely, i.e., the sliding lever won't go all the way to the right (hot), just about 3/4 way. Heat seems to work fine.
I replaced the heater core just before this, could (probably did, but what?) I have done something to prevent the slider from going all the way to the right (hot) during the replacement?
Hep me!
Many thanks.
1979 El Camino SS Royal Knight
(Tuned Port ZZ4 350)
1967 SS Nova Pro Street
1987 Olds 442
mhamilton
Necoa #: 6495
PostPosted: Sat Sep 20, 2008 8:06 am    Post subject: Reply with quote
Have you checked the threaded adjustment at the end of the cable? You have to move the temp lever and make sure you can hear the door hitting at full cold. It may not hit at full hot, but it should be close to the end.
Otherwise, have you checked the blend door lever is not broken?
dlc1979
Necoa #: 11714
PostPosted: Tue Sep 23, 2008 1:38 pm    Post subject: Reply with quote
Thanks for the tips.
I took a look last night. Blend door lever not broken. Took the cable loose from the lever, blend door moves freely, however, the cable is very sticky at the far end of travel.
I shot some WD-40 on the cable end, moved the lever back and forth a few times, seemed to free up quite a bit, although still a little drag on it towards the hot temp.
All in all, works, but I figure sometime in the near future, I'll have to figure out how to lube or replace the cable.
Thanks for all the help.
1987 Olds 442
mhamilton
Necoa #: 6495
PostPosted: Tue Sep 23, 2008 6:48 pm    Post subject: Reply with quote
Glad you got it fixed. I don't think you could lubricate the cable any better than what you did, since the end is looped you can't get the core out to really clean it. Should be fine in an interior application like that.
Might also pull the control head and clean/lubricate that end, and the switch sliders. I used a little bit of white lithium to lubricate mine. A slightly heavier grease might work a bit better, though.
dlc1979
Necoa #: 11714
PostPosted: Wed Sep 24, 2008 8:51 am    Post subject: Reply with quote
Sounds like good advice. I'll try to get to that this weekend, along with new foam on the lower door so I can get more air/heat to the defrosters and upper A/C ducts.
Thanks again for your help.
1987 Olds 442
