El Camino Central :: View topic - Not getting fuel
Not getting fuel
galangmaid
Necoa #: 12327
PostPosted: Thu Sep 25, 2008 5:09 pm    Post subject: Not getting fuel Reply with quote
OK I have almost a full tank of gas. The car (85' 4.3L FI) has been running great until this morning. I cranked it up, idled for a few minutes, started to back up out of the driveway and it died. Tried recranking it and it wouldn't fire up. The battery is good. Replaced plugs, wires, dist cap/rotor a couple of weeks ago. So i figured it couldn't possibly be those item. So.....I sprayed a little starter fluild down the throttle body and it cranked right up but them died again. So I'm thinking it fuel related type problem. I went ahead and changed the inline fuel filter in case it was plugged up......didn't help. Also, when i turn the key on, I can hear the fuel pump for a few second then it quites which it always does.
What else can be the problem?
Thanks in advance for your help.
Flaminmeano
Necoa #: 7482
PostPosted: Thu Sep 25, 2008 7:30 pm    Post subject: Reply with quote
Oil Pressure switch/fuel pump relay
385 stroker, brodix, weiand super charger,
PostPosted: Thu Sep 25, 2008 7:34 pm    Post subject: Reply with quote
I'd say you have a fuel pump issue. (weak) Run a fuel pressure test, you will most likley be to low on pressure.
Or as Tim states, a weak relay that kicks out.
galangmaid
Necoa #: 12327
PostPosted: Thu Sep 25, 2008 9:12 pm    Post subject: Reply with quote
ok tell me this. When I took my in-line fuel filter off from under the car and then turned on the ign switch. Shouldn't there be fuel sqirting out of the gas line ?? There wasn't any.
Also. can an external type fuel pump be use in place of the internal type?
PostPosted: Thu Sep 25, 2008 9:22 pm    Post subject: Reply with quote
Correct !!!! With the line disconected, and key on, FUEL IN THE TANK, You should be getting allot of fuel pumping out the line, THAT is if the pump is good. If not , as I thought , you have a bad fuel pump. It will have to be replaced. NO YOU CAN NOT use an external, change out the bad one. It's not that hard to do, (with an empty tank).
galangmaid
Necoa #: 12327
PostPosted: Thu Sep 25, 2008 9:31 pm    Post subject: Reply with quote
Thanks man. So I definately have a bad fuel pump because the gas only dripped out of the line when the switch was on and/or off even though i could hear the pump running for a few seconds and then shut off.
Flaminmeano
Necoa #: 7482
PostPosted: Thu Sep 25, 2008 10:12 pm    Post subject: Reply with quote
You have to run battery power directly to the pump to verify that the pump is not running, you could just have a bad relay
galangmaid
Necoa #: 12327
PostPosted: Fri Sep 26, 2008 6:08 am    Post subject: Reply with quote
And where exactly is the fuel pump wires?
galangmaid
Necoa #: 12327
PostPosted: Fri Sep 26, 2008 7:10 pm    Post subject: Reply with quote
Problem solved.
Turned out to be a blown fuse that blew when the air cleaner pinched one of the injector's wire. Sure glad I didn't have to pull that gas tank.
PostPosted: Fri Sep 26, 2008 7:44 pm    Post subject: Reply with quote
That's good you found the problem, and here's a tid bit of info ~~~~~~
the fuel pump would not run a few seconds with a blown fuse, it would not run at all. In which case the info you provided in the beginning was in error. BUT THAT'S ALL GOOD ~~~ You got it fixed. That's what counts in the end.
galangmaid
Necoa #: 12327
PostPosted: Sat Sep 27, 2008 8:07 am    Post subject: Reply with quote
However it wasn't the fuel pump fuse that blew and the pump was buzzing. It was the fuse to the injectors and because it's an impulse type system, as long as the injectors not getting power and operating, the fuel will not start flowing. My machanic showed me all of that when he was testing everything. Yes I know it's strange but sure glad it's working again.
Thanks again for everyones help. Great Forum.
Page Generation: 0.331 Seconds
