Posted: Sat Sep 27, 2008 11:53 am Post subject:
Yes, you can move it. Although there may already be a sending unit there for the choke light. You could "T" of this but its kind of bulky. You can also get some 90* adaptors and move the stock location to clear the headers.
Necoa #: 7482
Posted: Sat Sep 27, 2008 3:12 pm Post subject:
Remove the plug just above your timing cover, add the fitting connect your gauge, at this point you will have the pressure that has been sent through the entire engine, this is the end of the line, and really the best place to sample oil pressure _________________ 385 stroker, brodix, weiand super charger,
