El Camino Central :: View topic - Water leaking into interior.....
Moriarty
Necoa #: 12240
PostPosted: Sun Sep 28, 2008 8:44 pm    Post subject: Water leaking into interior..... Reply with quote
I have water leaking into the interior on the passenger side at the toe section on the floor. It happens when it rains really hard.
I've looked for leaks at the firewall and can't seem to find one.
When I look at the leak it seams to be coming from the black plastic heater vent.
Is it possible it's coming in from the heater?
Has anyone else experienced this?
If it's a seal, where is the seal and what is the part number?
Oh, yeah. I have a 78 Caballero.
Thanks in advance.
PostPosted: Sun Sep 28, 2008 11:04 pm    Post subject: Reply with quote
Alix, you may want to check the Fan Motors drain, it may be plugged with debri. Is your Elky equiped with A/C? The seal around the windshied could also be leaking. Those are just two areas I would check into.
Moriarty
Necoa #: 12240
PostPosted: Mon Sep 29, 2008 10:22 am    Post subject: Reply with quote
The windsheild was recently replaced and I looked for any holes. Could'n find one.
I do not have AC,
Where is the drain for the fan motor?
Thanks,
gr8efx
Necoa #: 10393
PostPosted: Wed Oct 01, 2008 7:58 pm    Post subject: Reply with quote
CoyoteOn2 is almost certainly spot on with the blocked heater box/fan drain. It will be plugged up with leaves and other junk, so after it has been raining for a while the box fills up and then the water trickles inside.
It is hard to explain how to find it, but if you go under the hood and reach right down under the heater box you should feel an opening. It is almost big enough to get your hand/fingers into, if it feels blocked just keep poking with your fingers until you clear the junk out.
I hosed my Elky down with water first until it started leaking inside, having the water build up in the box will help flush the blockage out. Nice mess it was, all over my hand Laugh
Growing old is compulsory - Growing up isn't!
358L-CO
Necoa #: 12263
PostPosted: Wed Oct 15, 2008 5:10 pm    Post subject: Reply with quote
well i just bought my el camino like 2 months ago and really havent done much to it yet besides get some new door panels and a dash for it... but i have water leaking in from the windshield.. now if i were to take the windshield off and replace all tyhe moldings will this stop this issue... i had this problem with a 84 caprice i had but didnt have the car long enough to get it fixed
I bet my engine sounds better than yours....
PostPosted: Wed Oct 15, 2008 7:04 pm    Post subject: Reply with quote
The moldings don't have anything to do with sealing the glass to the body. Get somebody to help you and get a light and lay down in the floor and let them run the hose on the elky and see if you can nail down where it is actually coming in. Once you know that for sure it will make it easier to recommend a fix.
lugnut
Necoa #: 9993
PostPosted: Fri Oct 17, 2008 12:23 pm    Post subject: wet carpet Reply with quote
Not sure if this is your problem but I just pulled the carpet on my 86 and saw some rust staining where the floor boards meet the firewall on the passenger side. Took my grinder to it and there were holes all along that seam. Not huge and not difficult to repair. The remainder of the floor was like brand new. Might be because of that damn seam sealer GM used.
Richard
hemi57
Necoa #: 9074
PostPosted: Fri Oct 17, 2008 9:52 pm    Post subject: Reply with quote
My '75 had leaks from the heater core, windscreen, a drilled hole in the metalwork behind the RHS kick panel and seams in the firewall. That was just from the front.
I would recommend pulling the seat/s and the carpet to check out what the overall state of the floor is.
John (from Down Under)
welder5
Necoa #: 12463
PostPosted: Tue Nov 04, 2008 8:53 pm    Post subject: 1985 El Reply with quote
I just replace my HVA/C box froma junk lemans and found that the very bottom of the box on the inside part of the firewall there is a crack in the fiberglass. any tips to seal this up? I heard someone say use a spray on silicone sealer down inside the box.
1978 chevy El Camino 355/350 two tone blue
1985 chevy El Camino 355/5 speed Black
1999 chevy Tahoe which brought both El's home on a trailer
2005 toyota Camry
