Posted: Mon Sep 29, 2008 9:13 am Post subject: Nobody Knows about Cruise Control
Posted this under electrical a couple of months ago and had about 75 people look at it and no replys - hopefully somebody knows . . .
1986 Elky. When I got it 2 months ago, the Cruise Control worked fine - but now it does not. There is no blown fuse at the fuse block - is there and inline fuse and where is it? Could there be something else wrong? Any help here would be appreciated and thanks!
Michael
Clueless about Cruise Control _________________ Michael
Posted: Mon Sep 29, 2008 3:05 pm Post subject: Cruise Control
I've read the article recommended above, but it doesn't answer the situation I have: namely, my cruise control surges and falls off constantly. On a perfectly level road at a constant speed, it is perpetually speeding up or slowing down by a mile an hour or so.
Posted: Mon Sep 29, 2008 4:41 pm Post subject: Re: Cruise Control
Anyone have a fix for that condition?
Dave
Actually at the bottom of the article it does:
Conclusion:
After twenty plus years of diagnosing and repairing these systems, I have found the cruise switch to be the most common failure. Next in order of failure rates would be brake switch and/or adjustment, servo cable adjustment, vacuum system problems, (missing or broken lines, leaking reservoiur etc.) Then V.S.S, servo, module, and wiring.
