El Camino Central :: View topic - Engine Flooding and Edelbrock
Preclude
Necoa #: 12170
PostPosted: Wed Oct 01, 2008 9:25 pm    Post subject: Engine Flooding and Edelbrock Reply with quote
I have an 86 Elky. The previous owner rebuilt the 305 and added a mild cam, and Edelbrock intake and a Edelbrock 500n cfm Performer Carb. He had someone tune the carb after installing but it was running way to rich (mixture screws were set at 2 1/2 - 3 turns each). I have crannked them down to 1 1/2 turns a piece and will do a better adjustment with a vacuum gage later - seems to have helped.
Problem is that once in a while the engine hesitates a bit and every once in a while it just seems to flood out.
A friend of mine (former gearhead) says that Edelbrocks usually need a fuel pressure regulator as the stock fuel pump kicks out a bit too much pressure for them (their floats or something) that causes the problem I have. Has anyone heard of this as well - it soes not seem to be taked about in the blogs I've looked at.
And, if I do put one in, what kind do I use and what should it be set at?
Thanks,
Michael
Michael
PostPosted: Wed Oct 01, 2008 9:49 pm    Post subject: Re: Engine Flooding and Edelbrock Reply with quote
Highly un-likely Check for worn / dirty needle & seats, or just replace them, then re-adjust float level, install a quality in-line fuel filter.
Flaminmeano
Necoa #: 7482
PostPosted: Wed Oct 01, 2008 10:52 pm    Post subject: Reply with quote
You need to make all adjustments on the carb with a vacumm gauge
The metering rods probaly need a lighter spring installed because the camshaft is not producing enough vacumm to pull them down into the jets
so your loading up at idle, you can buy a spring kit for these carbs
385 stroker, brodix, weiand super charger,
Page Generation: 0.279 Seconds
