American Autowire Harness CH85262 - Page 2 - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-14-2017, 11:40 AM
JJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond repute
the HEI usually gets a 12ga wire from the firewall connector to the coil/batt connection on the cap..
the points harness will have the resistor wire..
you can use the resistor wire to trigger a relay with battery power to the HEI..
or
replace the resistor wire with a 12ga stranded copper wire..
or
tie into the ignition wire on the other side of the firewall with a 12ga wire to the distributor..
85-SS 95-LT1-383 4L60 8.5-3.73
Old 02-15-2017, 02:12 PM
Jackeup68's Avatar
Jackeup68 Jackeup68 is offline
Year: 1968
Model: El Camino Classic
NECOA #: 73322
Jackeup68 will become famous soon enough
my harness has the hook up for a points distributor. its a yellow wire and a white wire with some kind of woven insulation. Suprised many people even know where ridgecrest is.
2004 Silverado 5.3 Vortec Blue
1987 Pontiac Trans Am GTA 355 TPI Black
1976 Chevy K10 stepside 383 stroker 4 spd manual 4x4
1968 Chevy El Camino 454 TH350 NP205 4x4
11 Year Navy OIF/OEF Veteran Airframer
"If its broke hit it with a hammer,if that doesn't work get a bigger hammer. If you break it ohh well needed to be replaced anyways."
VFW Captain Ship 4084 Ridgecrest CA.
Old 02-15-2017, 05:01 PM
you wont need the yellow wire anymore with the HEI..
that was the 12v bypass for the points..
that's the resistor wire with cover,, use the white wire to trigger the relay
or
replace the resistor wire from the firewall to the distributor with a 12ga stranded copper wire..
or
  #19
Old 02-15-2017, 09:45 PM
Tophog's Avatar
Tophog Tophog is offline
Year: 1966
Region: 17(NV)
NECOA #: 12656
Tophog will become famous soon enough
I had a sign and custom paint shop in the 'Acres' on Everett St. (behind the Self Storage), from '93 to 2000. Now I'm on the other side of Death Valley, in Pahrump!
And if my Elkie sat like yours, I wouldn't have ripped the rear bumper off coming out of Sand Canyon on a dark night. Took a wrong turn and found a drainage ditch!
I even took the dinosaur to Schmidt's Tunnel a couple times! (Back when Toni still owned it.) Had to move a few rocks in Last Chance Canyon wash. Got really weird looks from guys in 4x4s! (Yours would have no problem!)
My headers only clear the ground by about 4-1/2", and no hydros or air bags!
Custom painters don't screw up . . . they just add more graphics!
Low, not slow, '66 Elkie. - 327, 3.31 posi, 5 speed sleeper.
'90 Jeep Wrangler
'06 Sierra 4x4
'13 Chevy Cruze
'63 custom Harley Pan/Shovel
'95 custom Harley Softail
Navy veteran, '76-80
Moderator - Nevada Shooters
  #20
Old 02-17-2017, 08:26 AM
Jackeup68's Avatar
Year: 1968
NECOA #: 73322
I been in alot of those places with my old 76 k10 stepside. Doubt i will be taking my elky out on those areas due to it having such a nice paint job.
  #21
Old Yesterday, 04:39 PM
Jackeup68's Avatar
Year: 1968
NECOA #: 73322
I dont see a spare wire on my harenss. but i should be able to run a wire from the fuse panel on the ign tab up to the distributor right ???
  #22
Old Yesterday, 06:38 PM
Tophog's Avatar
Year: 1966
Region: 17(NV)
NECOA #: 12656
Yeah, you may have to run a spare to the HEI. A 'keyed' 12v wire.
  #23
Old Yesterday, 08:25 PM
Jackeup68's Avatar
Year: 1968
NECOA #: 73322
i got the wires for the old points system. they have 12 volts going to them should they be okay to use or should i run a wire from the fuse box up to the distributor???
  #24
Old Yesterday, 10:13 PM
what spare wire are you looking for?? in which harness??
I don't mention using the ign tap in the fuse box because people usually don't know how many things or what is running on that circuit all ready.. that's where everything extra gets added..
it could be a smaller wire, a longer run, with more connections??
I don't have 68 diagram, but usually the pink wire from the ignition switch feeds the coil/dist,
its usually a bigger wire, just for the ignition,
when it goes thru the firewall connector it changes to the resistor wire with the braded insulation..
I like the relay setup because I know my coil/dist is getting full battery voltage,
and its usually not going to go out because something else on the circuit has a problem..
will the hei run on the ign tap at the fuse box?? probly..
is it a better way to do it?? probly not..
check to see if the ign tap is hot in the start position too, on some cars it may not be??
Postal Code
Required
Street Address
Complete, verifiable Street or other address required (Hidden)
City
Your city or town
State or Province
Required
Location area within State
Which selection best describes the area of the State that you live in.
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Required. Your real name to be shown in your posts and profile.
Insurance
Please select your insurance company (Optional)
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
American muscle NEURON General BS Topics 0 05-27-2016 01:54 PM
Anyone install the American Autowire 70-72 Upgrade Wiring Harness? chevymike Electrical Systems 6 04-05-2016 09:51 AM
American V8 sound etcmick For New Forum Members Only 11 07-26-2009 07:53 PM
American Inventor 77SS General BS Topics 69 06-28-2007 11:16 PM
American made? Bowtie General BS Topics 15 03-09-2007 05:58 PM
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
