Went ahead and put in a Bluetooth radio/dvd unit. Couldn't stop there and redid the panel and eliminated the cig. lighter for a USB charging port. Just want to add a little trim to neaten up the edges. So far so good.
Haven't pulled the seats yet LMRestos. Will in the near future. |
| Sponsored Links | ||
Advertisement | ||
Great job.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. I have learned to never characterize any of my cars as fixed....they are just temporarily between malfunctions. .....Dan ( old_coot) To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
#19
Looks good. If it wasnt so cold ide have alot more done to mine. just got a new tunnel fabbed up just gotta welded it in and i plan on making seat brackets tomorrow
#20
Wow, that wall looks great! I'd like to do something like that to my 78 but I'd have nowhere to put my spare. Im thinking more of a single 10" though. Again, great job
#21
did you do that center console your self?
1980 el camino conquista To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
#22
Yeah, I had some red diamond plate left over from a previous project and got it to fit. Still need to put some trim on it to finish it and make the fit a little nicer.
#23
I can get to the spare, it will take a little bit more time to do it but there is just one bolt that holds the wall on. Take it off and I can pull the wall out and get the spare. I figure if I get a flat then a few extra minutes isn't going to hurt too much. Late is late.
#26
Very nice.
Doug
79 Malibu 78 El Camino 81 Malibu |
#27
I like it man looks sharp and cleans up behind the seat. is it hard mounted or just sitting in there?
#28
I used one large bolt in the middle and the fit is just right so that it tucks right in. No movement at all. When I first put it in I didn't bolt it down and it would slide forward an inch or so and I kept pushing it back and that was getting old.
#29
Very COOL! Nice work
1975 El Camino 12 Year Ground up Resto Complete 7-17-07 To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. 1967 Pro Street Camaro 489ci 622hp @ 6000rpm 593ft-lbs. torque @ 4800rpm on pump gas To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| My Red Wall | thosemillerboys | Audio | 24 | 03-01-2013 07:00 PM |
| '72 Rear Cab Wall | MI2600 | Interior Restoration | 3 | 07-22-2012 10:09 AM |
| wall light | Paulie's El camino | Interior Restoration | 3 | 01-27-2012 07:57 PM |
| Ok, help me off the wall | 74 chick | Engine Topics | 18 | 09-02-2010 04:48 AM |
| Fire wall hardware on 72 | SJC3087 | Heating & Air Conditioning Systems | 6 | 09-23-2004 10:13 AM |
