s10 Rear end swap - Page 2 - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-01-2013, 10:18 AM
JJLT1 is a jewel in the rough
heres a summit search for 94, gen2, LT1, 5.7,153 tooth..
http://www.summitracing.com/search/p...-based-engines
i dont know what the difference is?? but if you take out the LT1 gen2 you get more hits..
the b&m 20238 comes up for a 94 gen1 5.7 but not a LT1,,
the problem with putting a leaf spring rear in a 5 gen,, is welding brackets to the cast iron center section,,
lots a places makin rearend kits out there.. you can get just the housing,,some with disk breaks..
http://paceperformance.com/i-5146104...um-brakes.html
85 SS LT1 383 4L60 8.5 3.73
Old 01-01-2013, 03:37 PM
LT1Elco LT1Elco is offline
Region: 4 (MD,VA)
NECOA #: 23269
LT1Elco will become famous soon enough
A regular flex plate will fit the LT1, im just concerned that the torque converter bolts on the lockup converter for my th350c are a strange size, ive read that gm made some of the torque converter bolts in the lockup transmission metric sizes. Im going to verify the bolt size tomorrow and order a flex plate asap.
Ive ssen lots of places to buy housings or complete rear ends but my problem is im on a very tight budget so a lot of things are out of my price range at the moment, but fortunately my existing 3.08 open rear end is in good shape however im definitely going to go posi as soon as i have the money
Old 01-01-2013, 04:16 PM
jojothetattooboy's Avatar
jojothetattooboy jojothetattooboy is offline
Year: 1981
Region: 10(IL,MN,WI)
NECOA #: 22672
jojothetattooboy will become famous soon enough
I know a lot of people will disagree with me but I researched this because I too am building a budget car. The 7.5 you have now can be built to work to your advantage. From what I was told, you should keep the gear ratio under 3:42. Go above that and you are asking for trouble! Most people weld the axle tubes where they meet the cast casing. An upgrade of studs for the main caps along with an aftermarket cover is supposed to help drastically. Several companies make reinforced aluminum covers. This helps with deflection. It keeps your gear set "set-up." A good aftermarket differential along with decent aftermarket axles and proper set-up and this will safe you a lot of money! Some people I spoke with also change the ends on these housings to a popular Ford end to have bolt in axles to eliminate the c-clips. I ended up doing the LS1 disc brake conversion. If a c-clip fails the calipers should retain the axles. Not ideal, but I don't have plans to run my car on the strip. I rebuilt my 7.5 for about $800 including the disc brake swap. I'm happy with it. I did some of it in stages so I didn't break the bank. Just some info.....
  #19
Old 01-01-2013, 04:18 PM
bonos40's Avatar
bonos40 bonos40 is offline
Year: 1980
NECOA #: 8754
bonos40 will become famous soon enough
KEYSER...
Have you ever thought about writing a book of your knowledge, it seems that evertime someone needs an answer to a perplexing question ,,,you have or find the answer.
I must say I'm proud to be a member of an orginazition that has the quality of member as youself.
thank you for helping us less knowledgeable out .
thanks again !!!
  #20
Old 01-01-2013, 05:28 PM
Region: 4 (MD,VA)
NECOA #: 23269
jojo, you say you rebuilt your rear end for $800?! thats amazing and definitely could be in my price range a lot easier than fitting a 10 bolt or buying a new rear. Im definitely going to look into buying an old gbody housing for cheap to rebuild, I would rebuild the one I have but the car is meant to be a daily driver and i need to get it on the road asap and keep it there as much as possible.
  #21
Old 01-01-2013, 05:52 PM
Keyser Sose's Avatar
Keyser Sose Keyser Sose is online now
NECOA #: 15853
Keyser Sose is a name known to all
I got mine out of the local as paper. It's a 7.62 out of an 85 Monte SS, 3:73 open, but ALL the internals (gears, bearings, races, seals, etc) were brand new w/GM part nos on them. Kid had hit a tree with the front of the car. I paid $100 for it, with 2 stock rallye wheels and new brakes (incl. aluminum drums) on it. Look around, the deals are out there.
WHEN YOU KNOW WHAT THE MAGICIAN KNOWS, IT'S NOT MAGIC ANYMORE!
  #22
Old 01-01-2013, 06:45 PM
Year: 1981
NECOA #: 22672
I found a wrecked '99 Camaro rear for the disc brakes. I swapped the internals over from the Camaro along with new axles, bearings and a new differential. It worked out pretty well. I first used the differential out of the '99 Camaro and it ended up being bad. If a another person went this route, I'd check the differential out really good!! There are lots of people buying these cars wrecked for the engines and transmissions. You can usually score a deal on the rear end if you are patient.
  #23
Old 01-01-2013, 07:06 PM
NECOA #: 15853
Thanks man. When I run for president, you can be my media spokesman!
I've been asked why I don't write a book about my life too (it's been pretty interesting). But if I did, they'd put it in the fiction section, cause no one would believe it all actually happened. LOL
I can answer a lot of questions as they come up, but I have no idea how I would categorize everything if I tried to put it in a book.
After a LOT of pestering, I even tried to teach a couple friends, over the years, how to be creative with cars. I came to the conclusion that you either see things that way, or you don't. It can't be taught. Right joe (jlcustomz)?
Originally Posted by bonos40 View Post
KEYSER...
thanks again !!!
  #24
Old 01-01-2013, 07:16 PM
melissadunagan's Avatar
melissadunagan melissadunagan is offline
Year: 1981
NECOA #: 12939
melissadunagan will become famous soon enough
The LT1 is a one piece seal that may be the different. I also think it has a smaller id on crankshaft mount.
the ferret lady
  #25
Old 01-01-2013, 08:13 PM
ccc's Avatar
ccc ccc is offline
Year: 1986
Region: 19(AK,ID,OR,WA)
NECOA #: 21252
ccc is just really nice
i have a 95 LT1 in my 86 you would use any 86 to 99 small block flywheel from a one piece rear main seal motor includeing the original LT1 flywheel they all will bolt right up to your 350 turbo
  #26
Old 01-02-2013, 06:49 PM
sandblaster's Avatar
sandblaster sandblaster is offline
Region: 3 (DE,NJ,PA)
NECOA #: 727
sandblaster will become famous soon enough
Try this :http://ls1tech.com/forums/automatic-...r-bolt-up.html
  #27
Old 01-02-2013, 06:55 PM
Region: 4 (MD,VA)
NECOA #: 23269
Thanks for the input everyone, I just sent a question into summit about a flex plate I plan to order verifying the size of the torque converter bolt holes. I want to verify because the torque converter bolts in my TH350C are metric 10mm and I want to be sure they will fit before I order.
Tags
5th gen, brakes, posi, rear end, s10
G8 Rear Swap psycho74 Transmission & Drive line 2 06-21-2012 03:37 PM
rear end swap lky7_nate Transmission & Drive line 7 04-26-2010 12:20 PM
Rear swap amalgamator Suspension & Steering 9 05-25-2009 08:44 AM
rear end swap srwolf73 Transmission & Drive line 17 08-23-2005 12:11 PM
rear end swap JJ73 Transmission & Drive line 7 02-24-2004 06:52 PM
