scored a big block - Page 2 - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-03-2013, 09:36 AM
Lemmy's Avatar
Lemmy Lemmy is offline
Year: 1970
Region: 24(EUROPE)
NECOA #: 1487
Lemmy will become famous soon enough
Light Truck and Passenger Car engines are the same. Medium and Heavy Duty GM Trucks use a tall deck block. The distance from the crank center line to the top of the cylinders is .4" taller than the short deck block. The block is beefier and the cam is raised. Most parts are interchangeable and one will bolt in place of the other.
The tall deck block is taller and wider than the short deck so there are clearance issues when installing in a car. They are commonly used in drag racing because the thicker cylinder walls and the raised cam allow engine builders to bore the cylinders bigger and install longer stroke cranks then can be done on a short deck block.
http://wiki.answers.com/Q/What_is_th...evy_car_engine
_______________________________________________
Current: 1970 El Camino
Past: 1972&1971 El Camino
Old 01-03-2013, 09:57 AM
daytonchoppers's Avatar
daytonchoppers daytonchoppers is offline
Year: 1971
NECOA #: 13238
daytonchoppers will become famous soon enough
When I bought my Elco it had a 454 with those same heads it went 14.20's and i later found out a cam lobe was wiped.
Put '66 closed chamber oval port heads on it went 11.50's
With a little more work went 10.70's 9.5-1 pump gas daily driver with stock suspension.
'71 El Camino 10.18 129,'97 WS6 12.60 111,
'02 WS6 13.61 102,Shovelhead Chopper
Old 01-03-2013, 10:37 AM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Year: 1959
Model: El Camino Classic
NECOA #: 9311
Bryan59EC has a spectacular aura about
a 502 is still a short deck motor-----they just have very large coffee can sized pistons
a 1-ton truck is still considered light duty/pick-up class so it should have the same engine
that was used from the 70 Chevelle on up to the TBI motors-----short deck
2 of the 3 454 engines I have came from a 1-ton.
Car?? Truck?? Who Cares??
59--454/5-spd "Daddy"
66--3oh7--- TKO 600---25mpg "Mousey"
65 Ranchero---factory v8/4spd car "Old Blue"
MT spies have scored again!! Keyser Sose General BS Topics 6 11-09-2012 02:23 AM
Scored a 73! Flügelwagen For New Forum Members Only 21 08-07-2012 10:03 PM
Scored Like a Bad boy Today ! redflash Brake Systems 2 02-03-2011 05:22 PM
Scored a $20 Elky! FIRST ELKY 4 ME General BS Topics 32 03-13-2010 04:50 PM
Scored a 400 today! texaselky Engine Topics 2 11-20-2008 06:17 AM
