Front End Rebuild Kit - Page 2 - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-21-2013, 09:55 AM
Wayne Parrish's Avatar
Wayne Parrish Wayne Parrish is offline
Silver Contributor
Year: 1986
Region: 5 (NC,SC)
NECOA #: 19316
Wayne Parrish has a spectacular aura about
I understand that I can replace the stock with aftermarket urethane, BUT, how does it effect the ride from stock,or make it harder /harsher riding ?
Old 01-21-2013, 12:28 PM
WhisperPC WhisperPC is offline
Year: 1973
NECOA #: 5463
WhisperPC will become famous soon enough
Originally Posted by Wayne Parrish View Post
A question for someone "that has installed and used" urethane bushings and front rear parts . Does the ride stiffen up with them or is it about the same ride as stock bushings ? Thanks
Poly bushings deflect a LOT less than rubber bushings, under the same load. This means that the steering response is quicker. The cost of this is that the poly bushings transmit more of the road vibration & noise to the chassis.
Old 01-21-2013, 12:41 PM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Supporting Member
Year: 1987
NECOA #: 18458
HKDUP87 is a glorious beacon of light
That doesn't sound good for daily driving.
I have learned to never characterize any of my cars as fixed....they are just temporarily between malfunctions. .....Dan ( old_coot)
  #19
Old 01-21-2013, 02:08 PM
Camino80's Avatar
Camino80 Camino80 is offline
Year: 1980
Region: 10(IL,MN,WI)
NECOA #: 931
Camino80 will become famous soon enough
In my case I'll describe my ride as firm with a quicker response. It might be the use of the Edelbrock IAS shocks I put on. No vibration or noise to speak of taking into account the age of the car.
  #20
Old 01-21-2013, 10:12 PM
NEURON NEURON is offline
Loose Nut
NECOA #: 23153
NEURON will become famous soon enough
I believe you have to grease them from time to time to keep from squeaking(so embarrassing).I put up with them in my Cobra Mustang, I won't on an El Camino.I replaced all of the springs with heavy duty and installed a rear anti sway bar because I do like my vehicles to handle but I don't see any point to try and make it into a race car....I would have kept my Mustang then. I also got the bench seat so I can carry 3 people, guess some of us tend more to the truck than the automobile side of the ELKY.
  #21
Old 01-22-2013, 04:21 PM
HQDeezy's Avatar
HQDeezy HQDeezy is offline
NECOA #: 22419
HQDeezy will become famous soon enough
I just some what rebuilt my front end. Here's a list of parts I pieced together through Amazon, Napa, O'Reilly & Summit. I originally wanted to go with everything AC Delco also, but some items on Amazon were out of stock so I had to resort to mixing and matching.
Raybestos Lower Ball Joint $22 pair
AC Delco Upper Ball Joint $22 pair
Raybestso Center Link $37
AC Delco Idler Arm $30
Raybestso Out Tie Rods $23
Moog Inner Tie Rods - $38
MasterPro Upper Ctrl Arm Bushings $ 17
Napa Lower Ctrl Arm Bushings $30
Napa Front Rotors $60
Napa Ceramic Brake Pads $50
= $329
  #22
Old 01-23-2013, 08:27 AM
darbysan's Avatar
darbysan darbysan is offline
Supporting Member
Region: 17(NV)
NECOA #: 910
darbysan is of outstanding character
As for the Poly, I used poly-graphite bushings, and have no complaints. Can't really tell any difference in ride quality or noise. I liked the poly especially on the upper fronts, since they get a lot of heat from the headers.
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade.
Front end rebuild ShadowElky Suspension & Steering 86 01-07-2013 03:19 PM
Front End Rebuild on 87 geezer.nelson Suspension & Steering 26 06-03-2012 12:10 AM
Front end rebuild Richp85ElCO Suspension & Steering 6 05-16-2011 06:23 PM
Front Suspension Rebuild BlueFlame Suspension & Steering 2 05-04-2005 01:39 PM
front end rebuild was_seattle For New Forum Members Only 4 03-12-2005 03:40 AM
