floor boards - El Camino Central Forum : Chevrolet El Camino Forums
Old 12-10-2012, 08:16 AM
caminokid863 caminokid863 is offline
Year: 1973
Region: 3 (DE,NJ,PA)
NECOA #: 23142
caminokid863 will become famous soon enough
Default floor boards
I have a 73 and currently just about to finish riveting small patches in. I know that riveting is frowned apon but being a senior in high school and not knowing welding that great it was my best option plus they were only about 4x4, patches needed. But my real question is what should I use as a coating to keep it all sealed. I was thinking about using a form of bed liner anyone have a better idea?
Old 12-10-2012, 08:55 AM
87next2last1's Avatar
87next2last1 87next2last1 is online now
Deputy Director Region 6 - Supporting Member
Year: 1987
NECOA #: 16317
87next2last1 is a glorious beacon of light
maybe use some seam sealer ?
1987 EL Camino Conquista 4.3L Daily Driver (My Car)
1984 EL Camino SS V8 Work Truck & Toy (My Truck)
Check out both of my Caminos on link Below !
Old 12-10-2012, 09:15 AM
Year: 1973
NECOA #: 23142
I already am. I got a tube of it and already applied to one side around the seam of the new panel overlap. But anything else I also used spray on rust converter by rustoluim that really work that well ?
Old 12-10-2012, 01:11 PM
Keyser Sose's Avatar
Keyser Sose Keyser Sose is online now
NECOA #: 15853
Keyser Sose is a name known to all
Get a quart of Dupli-Color brush on bedliner, and coat the patches on both sides. holds up so well, it made my floors waterproof. See!
WHEN YOU KNOW WHAT THE MAGICIAN KNOWS, IT'S NOT MAGIC ANYMORE!
Old 01-16-2013, 09:33 AM
Year: 1973
NECOA #: 23142
That's awesome and I already did the entire floor is seam sealed and bed lined
Old 01-22-2013, 05:52 PM
brddg's Avatar
brddg brddg is offline
Knuckle Buster
Year: 1969
Region: 15(AZ,MN)
NECOA #: 23412
brddg will become famous soon enough
You may consider using a metal-bonding adhesive. It's as strong as a weld if done correctly, does not require any grinding and is corrosion-proof if all bare metal areas are covered with the adhesive. I have done this on several projects and have had great success. Even filled holes on the bed rail of my dad's pick-up and put body-filler over the top. That was over 10 years ago and still no evidence that it will fail. The downside is that the adhesive is expensive and usually requires a special dispenser. Good luck.
Old 01-25-2013, 07:19 PM
Rustbucket's Avatar
Rustbucket Rustbucket is offline
Site Contributor
Year: 1972
NECOA #: 23274
Rustbucket will become famous soon enough
I used to use aresol undercoat when I did stuff that way... Im hoping this is just a temporary repair until you can have them welded in correctly
Proud owner of the following vehicles:
1966 Ford Mustang 1982 C 20 Chevrolet Scottsdale Pickup,1986 D30 Military Chevrolet pickup, 2013 BMW x3, 2013 Ford F150 Ecoboost, 2003 Honda 750, 1971 Harley Davidson Sportster , 2011 Bayliner 185
Old 01-25-2013, 08:06 PM
Dimitri13's Avatar
Dimitri13 Dimitri13 is offline
Year: 1973
Region: 20(HI)
NECOA #: 23291
Dimitri13 will become famous soon enough
Would anyone recommend POR-15?
1977 El Camino Classic - Acquired 1/3/13
Build thread:
1973 El Camino SS - Acquired 4/13/13
Old 01-25-2013, 08:19 PM
NECOA #: 15853
That's an actual picture, NOT a photoshop. I parked it on the new asphault at work, at the auto auction, on the only spot in 99 acres that held water like that (no one knew that until this happened, they made the paver come back in and fix it). Story of my life! The water was actually about 1 inch below the floorboards, until we used a pushtruck to push it out of there to high ground, then it looked like the tide was coming in, but the floors didn't leak.
Old 01-26-2013, 03:56 AM
jpmdaddy's Avatar
jpmdaddy jpmdaddy is offline
Site Contributor
Year: 1966
NECOA #: 20314
jpmdaddy will become famous soon enough
Very good product. Most recently I used it on the new floorboards in my 66.
But be careful, if exposed to sunlight UV, the black will turn a little milky-
exposed areas need another coat of paint - which, of course, POR-15 sells too
"a little worn around the edges"
my '66 long term project:
my '71 Cutlass convertible:
Old 01-26-2013, 05:40 AM
Rustbucket's Avatar
Site Contributor
Year: 1972
NECOA #: 23274
por 15 is good as it will coat everything but it wont seal the two pieces of metal together like undercoat will
floor boards rejektedrekoning Body Restoration 11 03-12-2012 06:25 PM
Back to the boards, it's been awhile! 82Ellie General BS Topics 9 03-25-2011 03:02 PM
floor boards* 1977 Tyler Wanted Items 3 01-22-2011 10:32 AM
1966 floor boards Buck Body Restoration 3 10-19-2007 08:13 AM
Floor pan 81elky Body Restoration 11 11-25-2003 10:29 PM
