3.42 7-5/8" Ring & Pinion - El Camino Central Forum : Chevrolet El Camino Forums
Closed Thread
Old 02-21-2013, 08:03 AM
Jack_K's Avatar
Jack_K Jack_K is offline
Site Contributor
Year: 1980
NECOA #: 18056
Jack_K will become famous soon enough
Default 3.42 7-5/8" Ring & Pinion
I have a matched ring and pinion gear set. It's 7.625" but fits the 7.5" and 7.625" 10-bolt rears. Ratio is 3.42. These fit the 3-series carriers. Also have new ring gear bolts.
These gears are used but in great condition. $100.00 plus shipping.
Jack
Old 02-21-2013, 08:26 AM
TexasElCamino's Avatar
TexasElCamino TexasElCamino is offline
Deputy Director Region 13, Belton Committee
Year: 1978
NECOA #: 18728
TexasElCamino has a spectacular aura about
I'm checking with Ralph, but that just might be what I need for my 78. Will send you a pm if so! Thanks!
Terry
Duct tape extraordinaire
Old 02-25-2013, 09:34 AM
Jack_K's Avatar
Site Contributor
Year: 1980
NECOA #: 18056
I'll take $75.00 plus shipping. Remember, this is a 7.625" ring gear. It's bigger than the 7.5" but still fits the same carrier and rear end.
Anybody?
Old 02-25-2013, 11:06 AM
jarheadJim's Avatar
jarheadJim jarheadJim is offline
Region: 14(AR,LA,MS)
NECOA #: 19099
jarheadJim will become famous soon enough
Who makes that?
Old 02-25-2013, 11:32 AM
woody31's Avatar
woody31 woody31 is offline
Year: 1981
NECOA #: 14520
woody31 is just really nice
Do you have a good 26 spline 3 series carrier??
hey yall,,,watch this...
Old 02-25-2013, 01:55 PM
Jack_K's Avatar
Site Contributor
Year: 1980
NECOA #: 18056
No carrier.
I have no idea who made the gears. There's no marking on either.
Old 03-02-2013, 03:34 PM
RoyalKnight82's Avatar
RoyalKnight82 RoyalKnight82 is offline
Year: 1982
Model: Royal Knight
Region: 9 (IN,KY,MI)
NECOA #: 15372
RoyalKnight82 will become famous soon enough
Jack
Ok, I can safely say that I have no clue about rear ends except what higher and lower gear numbers mean. So clue me in a litter if you would please? My rear is 2.41 posi unit. Will this work for me?
In case you need more info, my rear is a 10 bolt in a 82 Camino.
Matthew W. Clark, Sr.
Proud owner of a 1982 El Camino SS Z16 Royal Knight.
Under Construction: 2/2012
Planned things to change(Updated): 334 w/TBI, T5 5-speed, 3:42 Posi, Rear Disc Brakes, Some 3rd gen Camaro interior (Dash, Seats, Center console, etc.)....and of course, all the body work. Will take photos and keep ECC updated on progress.
Old 03-02-2013, 06:37 PM
Jack_K's Avatar
Site Contributor
Year: 1980
NECOA #: 18056
No it won't work for you as is. In order to use a 3.42 gear you'd have to change the carrier (your posi) or get a ring gear spacer.
There are ring gear spacers available (ebay for instance) that will let you use these gears on your carrier.
So, you need my gears and a ring gear spacer.
Jack
Old 03-02-2013, 06:45 PM
woody31's Avatar
Year: 1981
NECOA #: 14520
Default spacer
Jack
make sure if you buy a spacer it comes with longer bolts,,,
Old 03-02-2013, 07:09 PM
Year: 1982
Model: Royal Knight
NECOA #: 15372
Ok, I really am clueless on rear ends. But I do know a little terminology for them. You are saying it won't work because I have a 2 series carrier. So that means a series 2 is 3.08 and numerically lower and 3.08 and higher is series 3, correct?
So in order for me to use these gears I would need something like what is on this eBay link?
http://www.ebay.com/itm/Ring-Gear-Sp...73d59e&vxp=mtr
Old 03-02-2013, 08:02 PM
jojothetattooboy's Avatar
jojothetattooboy jojothetattooboy is offline
Year: 1981
Region: 10(IL,MN,WI)
NECOA #: 22672
jojothetattooboy will become famous soon enough
To anyone upgrading gears....check first before purchasing! GM had an overlap between the "series." Mine had a set of 3.08's with 2 series carrier from the factory. The 3.42's are also available for a 2 series carrier aftermarket. Spacers would be ok if the gears were obsolete but otherwise should be avoided in my opinion.
http://www.summitracing.com/parts/rmg-4900051/overview/
  #12
Old 03-03-2013, 05:30 AM
Jack_K's Avatar
Site Contributor
Year: 1980
NECOA #: 18056
Yes, that's it.
  #13
Old 03-03-2013, 06:58 AM
Jack_K's Avatar
Site Contributor
Year: 1980
NECOA #: 18056
I believe the 2-series includes the 3.08.
Everyone has an opinion and MINE is that the spacer is totally acceptable. What's the difference between a spacer and a thicker gear? Same spacing.
Sure, a thicker gear might be a tad bit tougher, but the thin gear is stock and used in the 3-series carrier, so what's the problem?
  #14
Old 03-03-2013, 08:15 AM
Year: 1981
NECOA #: 22672
SAFETY! Longer bolts and two sliding faces(ring gear to spacer, spacer to carrier) retained by the same bolts. The ring gear is slight press fit on the factory carrier. The 2 to 3 series spacer doesn't have much of a "shoulder" for the gear to fit tight on the carrier. Sure it's the same spacing but why would one risk something simple like this?
I'm not an expert but Richmond Gear is. They don't sell them and don't recommend them either.
  #15
Old 03-03-2013, 08:32 AM
Year: 1981
NECOA #: 22672
Jack K .....thanks for the PM to me about ruining your "potential sale"
I apologize and I was only concerned for the safety of others.
Closed Thread
ring and pinion Steve84Ec Parts for sale 0 08-15-2008 09:20 AM
3.23 ring and pinion Steve84Ec Parts for sale 0 07-23-2008 07:07 AM
3.42 ring and pinion speedy86 Parts for sale 2 09-26-2005 10:08 AM
ring gear and pinion workNprogress General BS Topics 7 06-14-2003 06:16 AM
7.5" Ring and Pinion sets Mecheng Parts for sale 1 06-07-2003 11:02 PM
