LT1 headers - El Camino Central Forum : Chevrolet El Camino Forums
Old 09-24-2014, 04:04 PM
studie studie is offline
Junior Member
Gear Head
Year: 1984
Region: 14(AR,LA,MS)
NECOA #: 9952
studie will become famous soon enough
Default LT1 headers
I have a 1995 lt1 from a firebird, aluminum heads with "D" port exhaust. What headers will work with this combo? I have a set of headers for the elky but not "D" port, regular round ports, will this work on this combo?
Building a Studemino with LT1 with 4L60e.
Old 09-25-2014, 03:46 PM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
I hear headman makes a dport header for a gbody.
heres a search
http://www.bing.com/search?q=headman...&pc=ASU2JS
edit:: do the aluminum LT1 heads have angled plugs??
JJ
Old 11-15-2014, 09:01 PM
Tinbender59's Avatar
Tinbender59 Tinbender59 is offline
Member
Knuckle Buster
Year: 1977
Region: 12(MO,OK,KS)
NECOA #: 44305
Tinbender59 will become famous soon enough
Garage
I am running regular round ports on an LT1
Look here, this was several mod ago, but it is still alive
http://www.gmtruckcentral.com/articles/lt1swap.html
Old 12-20-2015, 07:47 AM
roger1's Avatar
roger1 roger1 is offline
Year: 1983
Model: El Camino SS
Region: 13(TX)
NECOA #: 2332
roger1 has a spectacular aura about
I've got an 83 SS that I installed an LT1 (out of an Impala SS) several years ago. I used the original 305 exhaust manifolds on it and now am thinking about headers.
I was looking at the Hedman 68609 because they seem to have good reports on them as far as fit in an El Camino. However, I don't know if there would be any issues on an LT1 in one. I'm thinking about the passenger side because of where the A/C compressor is and the fact that I had to move the motor mount back a little on that side as well.
Anybody here have headers with an LT1 (low A/C compressor mount version) with this generation of El Camino?
1983 Choo Choo SS w/1996 LT1 and 4L60E
1955 Bel Air Sport Coupe w/Ram Jet 350 and Tremec T56 Magnum
1957 Chevrolet 3200 pickup w/TPI and 700R4
2008 Corvette 3LT Coupe, LS3/6spd, Atomic Orange, all stock
Pictures:
Old 12-20-2015, 08:31 AM
xlchjoe's Avatar
xlchjoe xlchjoe is offline
Site Contributor
Year: 1971
Region: 3 (DE,NJ,PA)
NECOA #: 52961
xlchjoe is a name known to all
Garage
Don't be shy, call Hedman.
And I will not be commanded
And I will not be controlled
And I will not let my future go on
Without the help of my soul
71 Camino
02 Z28
03 Blazer
11 Vette
11 Fatboy
Old 12-20-2015, 08:38 AM
roger1's Avatar
Year: 1983
Model: El Camino SS
Region: 13(TX)
NECOA #: 2332
Quote:
Originally Posted by xlchjoe View Post
I might.
But there is nothing like first-hand experience. Hoping to get some of that here.
Old 12-20-2015, 10:27 AM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
I have the caprice setup with the low pass side mount compressor..
dang, now I cant remember which ac manifold lines I used?? for the caprice maybe???
I did have to do some creative bending at the compressor lines, low side? was too close to the headers,,
and I used a accumulator from a C60 truck for a different low side outlet..
I changed the accumulator hose end to a 90* fitting too..
I think
if I had it to do over again, id use a custom ac manifold block with 90*s or 45*s off the compressor
and custom 2 piece hoses
I have the hooker long tubes,, 2451? I think??
they hang too low on the driver side, there made to work without the double hump xmember, I guess?
I don't remember any motor mount clearance problems tho..
I have seen a set of hedmans that looked like they would work better for the hose clearance,
the #2 tube goes back first, then down,
the hooker tube goes down first..
don't know the number tho...
  #8
Old 12-20-2015, 11:15 AM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
maybe these?? but there long tubes..
I don't see any thing that says they work with the ac box tho..
http://www.jegs.com/i/Hedman/500/68311/10002/-1
http://www.hedman.com/site/?d=119&dt...start=&limit=5
  #9
Old 12-20-2015, 12:12 PM
roger1's Avatar
Year: 1983
Model: El Camino SS
Region: 13(TX)
NECOA #: 2332
I was thinking mid-length headers because I don't want to cut my ground clearance.
Do you know if those Hedman full-length cut clearance or not?
I was looking at the Hedman 68609 mid-length for that reason.
It looks like the 68600 and 68609 are identical except the 68609 are for D port heads which the LT1 heads are.
I found a few threads on this forum where it was reported that the 68600 fit 5th gen El Caminos well. But, none of those reports were with LT1's with the low A/C compressor.
  #10
Old 12-20-2015, 04:03 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
I don't know about hedmans on elky's
they fit well and tuck up good on Camaro's and Vett's, but do hang down just a little..
I couldn't remember if my 95 iron LT1 heads are Dport or not,, or just the alum ones??
i'v never used the short/mid headers,,
you still get all the PITArs except the ground clearance, and less of the power...
I figure if I go to all the trouble, and the price of nice coated headers,, im goin long tube..
I don't think I would do it for shorty's, some of them look worse for changing plugs..
  #11
Old 12-20-2015, 04:10 PM
ElkyCali's Avatar
ElkyCali ElkyCali is offline
Motor Mouth
Year: 1981
Region: 18(CA)
NECOA #: 59297
ElkyCali will become famous soon enough
Garage
I've got Hookers on my Camaro which has the FI heads with 202's Can't recall the part number because they are almost as old as me ha. But I will look for a receipt just the same. Merry Christmas...Al
1953 BelAire, 1963 Impala, 1964 Impala, 1963 Vette, 1966 SS 396 Chevelle, 1967 Camaro, 1968 Camaro (still have), 1974 Ranchero, 1976 Harley Davidson, 1976 Elky, 1981 Elky (current driver), 1973 VW bug, 1974 VW super bug, 2006 F150 Harley Davidson (current driver)
1981 Frame Off thread
1981 Project Pics
Retired Air Force
  #12
Old 12-20-2015, 04:32 PM
roger1's Avatar
Year: 1983
Model: El Camino SS
Region: 13(TX)
NECOA #: 2332
Yeah, I agree with you about long tubes. But, cutting ground clearance is just something I wont do. Been there done that. I hate worrying about hitting headers on stuff.
Right now I have the stock 305 manifolds that came with the car on it. They have small outlets. You would think the mid-length headers would still be a pretty good improvement over those. I'd go from the present single exhaust to a dual with a X too when I do the headers.
OTOH, I still am quite surprised I turned a 13.93 at 93.4 mph in the quarter with this car and LT1 and street tires.
The engine is bone stock.
I didn't check to see if the iron LT1 heads have D ports or not. Maybe they don't. If that's true than the 68600 would be the choice for the Hedman mid-length.
  #13
Old 12-20-2015, 05:05 PM
sandblaster's Avatar
sandblaster sandblaster is offline
Year: 1985
Model: Conquista
NECOA #: 727
sandblaster has a spectacular aura about
Garage
Try This : http://www.classicindustries.com/pro...ts/ed6603.html
  #14
Old 12-20-2015, 05:07 PM
roger1's Avatar
Year: 1983
Model: El Camino SS
Region: 13(TX)
NECOA #: 2332
Quote:
Originally Posted by sandblaster View Post
Don't have an Impala.
Ive seen those on Impalas however. Ugliest headers you ever did see.
  #15
Old 12-20-2015, 05:35 PM
Rchevelle71's Avatar
Rchevelle71 Rchevelle71 is offline
Year: 1984
Region: 6 (FL)
NECOA #: 49858
Rchevelle71 will become famous soon enough
Any 1-3/4 primary header made for the car will work.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Mid length headers for LT1 krok18 LT1/LS1/EFI Tech 9 09-12-2012 11:32 AM
Long tube headers for LT1 El Corvino LT1/LS1/EFI Tech 7 01-18-2010 07:50 AM
LT1 headers El Corvino LT1/LS1/EFI Tech 8 04-07-2009 09:22 AM
lt1 80 elky headers kender LT1/LS1/EFI Tech 6 02-23-2005 10:36 AM
LT1 / G body headers. Which gaskets? lt1monte LT1/LS1/EFI Tech 2 01-17-2005 07:11 PM
