Rear shock opinions. - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-09-2017, 05:17 PM
Sampoerna415's Avatar
Sampoerna415 Sampoerna415 is offline
Motor Mouth
Year: 1972
Region: 14(AR,LA,MS)
NECOA #: 77945
Sampoerna415 will become famous soon enough
Garage
Default Rear shock opinions.
I live in pot hole country, I have some cheap KYB shocks out back that I got for free and I am not very happy with them. I'm running cargo springs out back because I use this thing as a truck and I swapped the Monroe air shocks for the KYB and it helped a little. Would the high dollar Bilstein shocks help soften up the ride a little or am I better off with something else?
Old 03-09-2017, 06:16 PM
suprise.camino's Avatar
suprise.camino suprise.camino is offline
Member
Loose Nut
Year: 1979
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 38186
suprise.camino will become famous soon enough
Garage
I have a 79, We put in the kyb Gas adjust. We like the way it rides. Altho it would be better once we get all the body bushings replaced...
I know the blisteins are typically more expensive, I have never used them. Good luck on your search
Nick
"Badges...We don't need no stinkn badges"
Old 03-09-2017, 06:44 PM
kat0069's Avatar
kat0069 kat0069 is offline
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
kat0069 will become famous soon enough
Garage
Mine rode like a dream with Bilsteins, but then again I also had stock springs.
What do you mean, "I ain't kind"? I'm just not your kind. -Megadeth, Peace Sells
Too many things to keep tires on.....
1987 El Camino (My Baby) For your entertainment, my build thread:
1968 Camaro RS (our car)
2000 Wrangler Sport (My jeep)
2013 Wrangler Rubicon Unlimited (the wife's daily)
2017 Silverado 1500 Z71 4X4
1976 Corvette
1968 VW Autostick Bug (Project)
2003 Built FXSTI HD Softail Standard (Dyno'd @ 100 hp)
2002 Monaco Dynasty Duchess (Home on the road)
Old 03-10-2017, 05:13 AM
pitts64's Avatar
pitts64 pitts64 is offline
Year: 1969
Model: El Camino SS
Region: 3 (DE,NJ,PA)
NECOA #: 19572
pitts64 will become famous soon enough
I like Bilsteins too...
Old 03-10-2017, 05:21 AM
old goat's Avatar
old goat old goat is offline
Year: 1985
Model: Conquista
Region: 10(IL,MN,WI)
NECOA #: 23551
old goat is a name known to all
Garage
Cool KYB's....
...should do the job? The Cargo springs may be the problem! Nothing wrong with Blisteins for the money!
Old Goat
Old 03-10-2017, 05:32 AM
JKCamino's Avatar
JKCamino JKCamino is offline
Deputy Director Region 19 Owner of the KLRMino
Year: 1973
Region: 19(AK,ID,OR,WA)
NECOA #: 5944
JKCamino is a glorious beacon of light
Garage
Go with coilovers if your wallet can handle it you get the best of both worlds and better plus you can adjust the altitude at anytime. QA1, viking, and spohn make one. spohn uses QA1 shocks. I went with spohn in the rear because they had the correct upper mount for my 4th gen and Qa1 up front. Granted this will cost 10x more than what a stock setup costs. Oringinally I had just the Monroe air adjust shocks stock springs and it was just fine without a rear sway bar
1973/75 Custom Laguna S3 El Camino COPO Replica AKA (KLRMINO)
Old 03-10-2017, 06:00 AM
jarhead's Avatar
jarhead jarhead is offline
Year: 1987
Region: 13(TX)
NECOA #: 11248
jarhead has a reputation beyond reputejarhead has a reputation beyond repute
I would use what many others, me included, use. The cargo springs are fine.. add some Air-lift bags in the springs and some Gas Adjust KYB's. You keep 5-10 lbs if air in the bags and it helps support what you carry and the KBY's take care of the dampening.
Those members that have this set-up.. please chime in. Also, add a rear sway bar if you can, it helps towing when to take turns as well.
1987 El Camino, aka Harper's cruck
1983 El Camino S
Dang, I miss Ronald Reagan
more and more every day..
  #8
Old 03-10-2017, 08:48 PM
O52's Avatar
O52 O52 is online now
Year: 1970
Model: El Camino SS
Region: 18(CA)
NECOA #: 22875
O52 is a glorious beacon of light
Garage
I have coupe rear springs which drop the rear about an inch or so. Delco gas shocks, Air Lift bags and 1" rear sway bar. When carrying a load I air up the bags. Normally i run about 5 psi in the bags.
Ed
70 El Camino SS
  #9
Old 03-11-2017, 03:23 AM
xlchjoe's Avatar
xlchjoe xlchjoe is offline
Site Contributor
Year: 1971
NECOA #: 52961
xlchjoe is a name known to all
Garage
Quote:
Originally Posted by jarhead View Post
Attachment 72913
A popular setup that works.
Name:	camino rear 2.jpg
And I will not be commanded
And I will not be controlled
And I will not let my future go on
Without the help of my soul
71 Camino
02 Z28
03 Blazer
11 Vette
11 Fatboy
  #10
Old 03-21-2017, 08:33 AM
UMI_FOLMAR's Avatar
UMI_FOLMAR UMI_FOLMAR is offline
Member
Twisted Wrench
Year: 1972
NECOA #: 75978
UMI_FOLMAR will become famous soon enough
Quote:
Cargo springs have higher rates kind of like higher spring rates used in handling applications.
When you raise spring rates you need shocks that have higher rebound rates to handle the stored energy that the higher rated spring exert on rebound.
Most people think the compression is too stiff when they get a harsh ride from higher spring rates but it's actually the rebound that is the issue causing it.
Billstein shocks are probably the best over the counter shocks as far as the rebound curve goes.
Just remember the shocks are like the heartbeat of the suspension and you usually get what you pay for.
We have a manufacture custom build shocks for us to handle modern day spring rates...it makes a world of difference when you have the right shocks.
  #11
Old 03-21-2017, 08:47 AM
knappyfeet's Avatar
knappyfeet knappyfeet is offline
Motor Mouth
Year: 1972
Region: 18(CA)
NECOA #: 33594
knappyfeet will become famous soon enough
Quote:
When you air up the bags does it lift the rear a little? My air shocks can lift the back an inch to an inch and a half.
By the way I screened shot this setup cause it sounds like a winner. I have 2 inch drop springs in the rear.
  #12
Old 03-21-2017, 11:59 AM
jarhead's Avatar
Year: 1987
Region: 13(TX)
NECOA #: 11248
Kevin.. adding air to the bags does raise the rear a little.. maybe an inch on my 87. The nothing real noticeable like the air shocks it makes for a more stable ride AND concentrate the load on the axles and not the shock bolt.. to me that's poor engineering from GM..
  #13
Old 03-21-2017, 06:16 PM
O52's Avatar
Year: 1970
Model: El Camino SS
Region: 18(CA)
NECOA #: 22875
Garage
It does raise the back up an inch or so. I use them just for heavy loads which is once or twice every couple years. I have Delco Gas shocks which I'm considering replacing with Bilsteins or Konis.
  #14
Old 03-22-2017, 03:34 AM
Motor Mouth
Year: 1972
NECOA #: 77945
Garage
Does anyone one suggest any particular brand of air bags?
  #15
Old 03-22-2017, 03:42 AM
xlchjoe's Avatar
Site Contributor
Year: 1971
NECOA #: 52961
Garage
AirLift. Word.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Street Shock rear? Wyliecoyote Suspension & Steering 13 12-02-2015 09:00 AM
69 rear shock mounts ecycle Suspension & Steering 0 05-06-2015 07:04 AM
Rear shock question m_sweatt Suspension & Steering 6 01-21-2013 02:42 PM
Rear Shock Stud Brian Boru Suspension & Steering 5 01-24-2010 10:21 AM
Rear shock replacement suggestions Dads 85Choo Choo SS General BS Topics 7 09-23-2009 01:53 AM
