New Member posting - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-27-2004, 09:59 AM
ECHarv ECHarv is offline
Junior Member
NooB
Year: 1987
Model: El Camino SS
Region: 22(CANADA (Ontario and East)
NECOA #: 1555
ECHarv will become famous soon enough
Default New Member posting
Hi All:
Have been 'lurking' around the site for a while & decided I could use the benefit of some advice.....there is obviously a lot of talent out there.
I have a '83 Elky, pretty much a plainjane beast; 305, 3 speed auto, full guages, air, pw, pdl, cruise. I bot the car in AZ, but I think it originally came from CA, based on emmissions equip. 120 k miles. Good solid body, no rust, but the desert heat has been hard on door rubbers, bushings, etc & the dust has taken its toll on things like bearings, speedo, tach, etc.
I am at the very beginning of a rebuild & decided to start with the suspension. After looking over the posts from a number of members in the 'suspension' section, have tentativley decided on the following for the rear suspension: Replace shocks with KYB Gas-A-Just, replace bushings with polyurethane, add airlift adjustable air bags, add swaybar.
I am unsure whether I need to replace rear springs, the car looks low in the back, but when measured seems to be fairly level, about 26 1/2" to inside of wheel wells, both front & back.
Would appreciate any suggestions before I proceed.
Thanks.
ECHarv, in Arizona
Old 01-27-2004, 10:27 AM
Alchemist Alchemist is offline
NECOA #: 1756
Alchemist will become famous soon enough
Default Re: New Member posting
First of all...WELCOME!!!!
So far as the rear goes...lotta folks swear by their airbags! That way you can get it so it LOOKS right...as well as pump'm up to carry a load! :thumbsup:
Old 01-27-2004, 11:52 AM
87SS 87SS is offline
87 Choo Choo
Year: 1987
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 128
87SS will become famous soon enough
Harv!
Quote:
I'm sure you're fine but those air bags will give you the flexibility to cure most ills
Old 01-27-2004, 12:32 PM
ElkySS's Avatar
ElkySS ElkySS is offline
NECOA Founder
Year: 1987
Model: El Camino SS
NECOA #: 1
ElkySS will become famous soon enough
Welcome!
The things you mention are some of the very first things I did to my '87.
Sounds like a good plan.
-dan
Old 01-27-2004, 01:20 PM
Tommy's Avatar
Tommy Tommy is offline
Year: 1978
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 14
Tommy will become famous soon enough
Garage
Sounds like a great start! Yes, Air lift bags work great. Welcome to a great site.
78 Camino SS, new built 357, built 700r4, 3.23 posi
78 Conquista, 350, 350th. stock for now
93 S10 4x4, 4.3, 5 spd
83 280zx turbo, 5 spd
99 Maxima SE-L, 5 spd
2000 Maxima SE
AF SMSGT retired
NECOA #14
Old 02-03-2004, 06:03 PM
Junior Member
NooB
Year: 1987
Model: El Camino SS
NECOA #: 1555
Default Thanks for the welcome
Thanks for the words of welcome, much appreciated. I am in the process of choosing suppliers for suspension parts, etc. & would appreciate being able to benefit from the knowledge of members who have already been there.
Please see my requests for guidance under "Suspension".
Thanks.
Harv
Old 02-10-2004, 06:29 PM
JOHNSUBR JOHNSUBR is offline
Member
Loose Nut
NECOA #: 2234
JOHNSUBR will become famous soon enough
sounds really nice .Iwould go with air bags,the air shocks blow out after a while or just use long bolts with a zillion washers on top of the shocks like mine was when I got it
1970 ELCAMINO
  #8
Old 02-11-2004, 03:26 AM
Deluxe Edition
Posts: n/a
Hi and Welcome. to the site I'm kinda new here as well.
If yo want to make the air bags self maintaining Just rob the pump, harness, and control modual from a 86 Caddy and wala AIR RIDE
It fits but if you put the pump up front you may want a Olsmobile cutless inner fender with the factory mounts and ,rob a power antenia relay to adapt it to your car
I have the diagrams if you need them.
  #9
Old 01-29-2012, 06:39 PM
KELAN KELAN is offline
Junior Member
NooB
Year: 1971
Model: El Camino SS
Region: 19(AK,ID,OR,WA)
NECOA #: 21078
KELAN will become famous soon enough
New to site,,,,, 71 SS supposedly,,,,I
  #10
Old 01-29-2012, 06:41 PM
Junior Member
NooB
Year: 1971
Model: El Camino SS
NECOA #: 21078
Default new
new
  #11
Old 01-29-2012, 08:51 PM
Jim Earl's Avatar
Jim Earl Jim Earl is offline
Year: 1972
Model: El Camino SS
Region: 12(MO,OK,KS)
NECOA #: 14646
Jim Earl will become famous soon enough
E.C., Welcome from Oklahoma, good luck with your 73!, Jim
  #12
Old 01-30-2012, 05:39 PM
DOUG213XRJ's Avatar
DOUG213XRJ DOUG213XRJ is offline
Year: 1978
Region: 9 (IN,KY,MI)
NECOA #: 13817
DOUG213XRJ has a spectacular aura about
Welcome aboard, Harv.
Doug
78 El camino
79 Malibu (sold)
81 Malibu
  #13
Old 01-30-2012, 07:12 PM
78 Elk's Avatar
78 Elk 78 Elk is offline
Year: 1978
NECOA #: 3102
78 Elk is just really nice
Welcome from Idaho.
hagensen78
  #14
Old 01-30-2012, 11:22 PM
Junior Member
NooB
Year: 1971
Model: El Camino SS
NECOA #: 21078
To all,
thanks for the posts and welcome..................... R/ kelan
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
More Posting Guidelines acauth1 For New Forum Members Only 2 06-20-2012 06:56 PM
Posting Guidelines acauth1 Site Rules 6 04-29-2011 11:03 AM
That's it! I'm not posting here again... LeoC2 General BS Topics 1 12-31-2004 08:37 PM
Posting w/out sign in?? 70ELCO Site Topics 2 03-10-2004 04:08 AM
