I would like to put the TH200-4R transmission in my '85 El Camino, I think it has a TH200??? I'm putting a 350 eng in it What will I have to do to change tramsmission. Will the same cross member work!!! :dontknow:
No. The stock cross member will not work. Ive heard that with a frame extention from summitracing.com the stock cross member will work, But dont know for sure. Everything else is the same though.
you prob. wont need the frame extensions on a 85 because from 84 & on you dont need it (my 84 did though) i think you would like the 200r4 xmem made by iceman racing . the rest of the swap was the same except for the brackets for the t.v. cable & if you are using a holly carb there is a brcket for the tv cable . carl
Don't forget a lock up kit for the convertor. Bowtie Overdrives has a nice TV cable set up for holleys. Easy to install to boot.
Related Threads
El Camino Central Forum
892K posts
41.8K members
Since 2002
