what trans shift bracket do you have? the one that comes out of the side of the trans i mean. theres the one that centers on the shaft and one that sits sort of off center. for the allignment problem it sounds like you have the wrong one. even when properly alligned though with that 3 speed shifter youll never get the trans in first. (detent wise. it wont affect how it shifts or what gear it starts in) B&M shifters are made to go in place of factory shifters and maintain the factory look. a few of tyhem are even designed for use with overdrive units.
First if you want to keep the indicator you'd have to mark it different, but second and more importantly it may not let get go all the way back to first. You usually lose park if you get 1st
I cut out my console and used the shifter cover that came with the B&M so I could get all the gears.
I think thats what your asking?
The stock shifter will not reach first. I have heard folks using a shifter out of an F-body. For the indicator, they make a plate that "covers" the PRND2L and now indicates PRND321. You can find them used on Ebay sometimes, and I think MikesMontes.com carries them.
Hey ALAsh. Use the original lever off the metric trans and adjust it so you have all gears but manual low. I had a TH700 in my 70 elky for 10 year's and Never once did i need to put it in manual low.
I'm thinking of going with a B&M Megashifter to get all 4 gears if I can make it fit inside the original floor console. It looks like it will work with a little effort although I am not sure which model # is the better choice.
Perhaps a call to B&M on Monday to hear their recommendation will clear this up.
I agree that with your combination, there may not be a good reason to ever need the shifter to put it into low. You may need to do it to check line pressure, but you can do that by manipulating the trans linkage with a wrench
Have you thought about a shifter for a 200-r4 tranny?
Related Threads
El Camino Central Forum
892K posts
41.8K members
Since 2002
