1981 El Camino - Page 5 - El Camino Central Forum : Chevrolet El Camino Forums
  #61
Old 02-16-2017, 03:33 PM
jim48442's Avatar
jim48442 jim48442 is offline
Loose Nut
Year: 1981
Region: 9 (IN,KY,MI)
NECOA #: 76545
jim48442 will become famous soon enough
Ware did u get the h4 kit from everyware i looked they only had the 4 headlight deal and i only have 2. Do u have high and low beam in 1 bulb also ?
  #62
Old 02-16-2017, 04:43 PM
MuhThugga MuhThugga is offline
Year: 1981
Region: 3 (DE,NJ,PA)
NECOA #: 72593
MuhThugga will become famous soon enough
Do you mean the relay harness? I believe I got it off eBay.
  #63
Old 02-16-2017, 05:14 PM
jim48442's Avatar
Loose Nut
Year: 1981
NECOA #: 76545
Well the h4 is the smaller bulbs right so you have a headlight housing then plug into that are a different size compaired to the 4 light system. So i would be asking ware the housing came from i k ow they sell kits but i havent seen one for the single like we have. I was just going to try silverlights halogen or something
  #64
Old 02-16-2017, 06:20 PM
jim48442's Avatar
Loose Nut
Year: 1981
NECOA #: 76545
Mine look like their 8x6 anyway you did some nice work on your car everything looks great
  #65
Old 02-17-2017, 03:35 AM
Year: 1981
NECOA #: 72593
I used Vision X VX-57 housings for the conversion. They are a 5x7 housing. I had to modify the cup that the housing fits in some, but it wasn't a big deal. I just had to cut the rear ears off that encompass the electrical plug. I remember that I had found a ton of options on Google when I searched for H4 Conversion Headlights.
The relay harness came from eBay, and was the only one I could find that did single headlights:
http://ebay.com/itm/331273872366?_mwBanner=1
I'll take some pictures of where I mounted the relays.
The housings use H4 bulbs, which utilize the sealed beam plug. The relay harness is required due to the halogens operating at a higher wattage, and yes, the single bulb does handle high and low beams.
And thank you for the kind words. They are much appreciated.
  #66
Old 02-23-2017, 05:07 AM
Year: 1981
NECOA #: 72593
The Dakota Digital gauges have been ordered, as have the new wheels.
US Mags Rambler U111
17x7 in the front
17x8 in the rear
  #67
Old 02-23-2017, 08:40 AM
jim48442's Avatar
Loose Nut
Year: 1981
NECOA #: 76545
Once u get those guages set up its like a new car again lol. One of the best upgrades i have done
  #68
Old 03-05-2017, 07:29 AM
Year: 1981
NECOA #: 72593
I haven't gotten pictures of the gauges, but they did come in.
The new wheels also came in.
  #69
Old 03-05-2017, 07:59 AM
xlchjoe's Avatar
xlchjoe xlchjoe is offline
Site Contributor
Year: 1971
NECOA #: 52961
xlchjoe is a name known to all
Classy wheels!
And I will not be commanded
And I will not be controlled
And I will not let my future go on
Without the help of my soul
71 Camino
02 Z28
03 Blazer
11 Vette
11 Fatboy
  #70
Old 03-05-2017, 08:13 AM
78 Elk's Avatar
78 Elk 78 Elk is offline
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is just really nice
That's looking great. Thanks for sharing your headlights conversation.
hagensen78
  #71
Old 03-28-2017, 07:27 AM
Year: 1981
NECOA #: 72593
I haven't updated much because it has mostly been a bunch of wiring. However, I did purchase a phasable rotor from MSD so that I can phase the rotor exactly as needed. In hindsight, and for anyone looking to do this in the future, just buy a replacement distributor for a TBI/TPI car. They are already phased and locked out, and are a hell of a lot cheaper. You just need to eliminate the ignition module and make a small pigtail for a standard coil. Done.
I also installed an adjustable vacuum switch for the transmission lockup. I have fused 12V switched power going to the switch, which then goes to the 12V power side of the lockup plug. The ground will go from the plug to the cruise control switch, and then to chassis ground. The transmission was internally wired for lockup in 4th gear. Essentially, the vacuum switch will only supply 12V when the engine is in a set vacuum range. That way, the converter will only lock up when cruising in 4th. Give it more gas or step on the brakes, the converter will unlock even if the transmission still remains in 4th gear.
I also replaced the BWD ignition coil with a MSD unit. FiTech said I needed an MSD or equivalent, and I couldn't find the ratings on the BWD unit.
I picked up a cheap air cleaner from Summit and painted it. It is a flat base and fits under the cowl perfectly. Of course, FiTech uses 5/16-18 threads for the air cleaner stud, and most air cleaners come with a 1/4-20 stud. I wound up going to Lowe's, getting some 6" threaded rod and a wing nut, and made one.
  #72
Old 03-28-2017, 10:07 AM
old goat's Avatar
old goat old goat is offline
Region: 10(IL,MN,WI)
NECOA #: 23551
old goat is a name known to all
Cool Enjoyed catching up on...
...your posts! Coming along nicely!
Old Goat
  #73
Old 03-28-2017, 11:35 AM
Year: 1981
NECOA #: 72593
The biggest expenses coming up are the radiator, shifter, and all of the AC components. I'm still debating between the Speedway Motors Musclecar shifter and something from Shiftworks.
  #74
Old 03-28-2017, 11:54 AM
jim48442's Avatar
Loose Nut
Year: 1981
NECOA #: 76545
Like the engine paint looks good not sure on the ford colors lol. Best one i ever did was orange with all brackets black looked pretty nice. Thanks for the info on tue headlights also did mine huge improvement for sure. Enjoyed your thread here
  #75
Old 03-28-2017, 03:01 PM
Year: 1981
NECOA #: 72593
It is actually a GM color: Dupli-Color DE1608 General Motors Blue.
Postal Code
Required
Street Address
Complete, verifiable Street or other address required (Hidden)
City
Your city or town
State or Province
Required
Location area within State
Which selection best describes the area of the State that you live in.
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Required. Your real name to be shown in your posts and profile.
Insurance
Please select your insurance company (Optional)
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
1981 el camino JessePinkman For New Forum Members Only 34 12-12-2015 07:11 PM
1981 El Camino 267 powerhorse Wanted Items 0 07-03-2014 04:06 PM
1981 El Camino Steve84Ec Ebay / Craigslist Alert 0 07-26-2013 05:32 PM
1981 El Camino nodigg For New Forum Members Only 8 03-18-2012 09:50 AM
1981 El Camino whiteghost For New Forum Members Only 14 09-30-2011 03:31 PM
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
