1981 El Camino - El Camino Central Forum : Chevrolet El Camino Forums
Old 08-23-2016, 05:59 AM
MuhThugga MuhThugga is offline
Member
Knuckle Buster
Year: 1981
Region: 3 (DE,NJ,PA)
NECOA #: 72593
MuhThugga will become famous soon enough
Default 1981 El Camino
I picked this up earlier in the month. I have a 355 shortblock sitting on an engine stand without a home, and I found this El Camino on Craigslist that was in need of an engine. It seemed like the perfect match:
The plan is to drop in the 355 with a Crane 2032 cam, Vortec heads, and a FiTech EFI system, and put a 2004R behind it.
Old 08-23-2016, 06:06 AM
Member
Knuckle Buster
Year: 1981
NECOA #: 72593
I decided to pull the interior out and check the floors. Everything looked good on the underside of the car, but I wanted to check inside, as well. After poking around with my trusty painters tool, I found some trouble spots:
Since dealing with my dad's '64 Impala SS project, I looked at this floor and said, "Whatever."
Old 08-23-2016, 06:14 AM
Member
Knuckle Buster
Year: 1981
NECOA #: 72593
So, I started patching away at the front driver's side floor:
Some brush-on seam sealer for good measure:
Primer:
And a coat of Rustoleum that I had laying around. It'll look great under the carpet:
Old 08-23-2016, 06:49 AM
78 Elk's Avatar
78 Elk 78 Elk is offline
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is just really nice
Good looking El Camino.
hagensen78
Old 08-23-2016, 06:56 AM
Nicks 1984 elcamino's Avatar
Nicks 1984 elcamino Nicks 1984 elcamino is offline
Year: 1984
Region: 8 (OH,WV)
NECOA #: 23695
Nicks 1984 elcamino has a spectacular aura about
Garage
Thumbs up
Yep! I think that motor will feel right at home in that elky. Good luck keep us updated.
Old 08-23-2016, 07:55 AM
xlchjoe's Avatar
xlchjoe xlchjoe is offline
Site Contributor
Year: 1971
NECOA #: 52961
xlchjoe is a name known to all
Garage
Quote:
A real Jeffreyangelo!
And I will not be commanded
And I will not be controlled
And I will not let my future go on
Without the help of my soul
71 Camino
02 Z28
03 Blazer
11 Vette
11 Fatboy
Old 08-24-2016, 05:59 AM
Member
Knuckle Buster
Year: 1981
NECOA #: 72593
Quote:
The lesser-known brother of Michelangelo. Usually found hanging out with Jerry Christ.
I got the heads back from the machine shop yesterday. The shop said that something was off with the retainers and keepers that I had ordered for using the LS6 valve springs. I found that odd since I had ordered Comp 787-16 retainers and 648-16 locks, which is what is needed to make these springs work. Well, something clearly isn't jiving:
  #8
Old 08-24-2016, 07:31 AM
carlfan's Avatar
carlfan carlfan is offline
Year: 1978
Model: Conquista
Region: 7 (AL,GA,TN)
NECOA #: 20575
carlfan will become famous soon enough
Garage
Welcome from Alabama. Nice welding and great looking job on those floors
78 conquista 350 with turbo 350
  #9
Old 08-24-2016, 07:58 AM
RGSS's Avatar
RGSS RGSS is offline
Member
Loose Nut
Year: 1982
Region: 6 (FL)
NECOA #: 64306
RGSS will become famous soon enough
Good job on the floor Jeff. Looking good.
Did not know you could use LS6 springs in the SBC heads. Interested to know how it orks out for you. I have a set of LS6 springs laying around.
RG
1982 Elky - Under the knife
  #10
Old 08-24-2016, 08:35 AM
Member
Knuckle Buster
Year: 1981
NECOA #: 72593
Thanks for the compliments.
Yes, you can use LS beehives on SBC heads. You just need the Comp 787-16 retainers and 648-16 valve locks. Comp just needs to make sure they put the correct stuff in their bags.
I wound up ordering a Vortec spring kit from Alex's Parts. I had an issue with the springs being much tighter than I liked around the guide bosses. This isn't an issue with other SBC/LT1 heads and is just unique to the Vortec variants.
  #11
Old 08-24-2016, 10:20 AM
Ol' D Ol' D is offline
Silver Contributor
Year: 1987
Region: 18(CA)
NECOA #: 49322
Ol' D will become famous soon enough
Hi Jeff and welcome from So Cal. Good luck on your project.
  #12
Old 08-24-2016, 10:38 AM
Whip 44's Avatar
Whip 44 Whip 44 is offline
Site Contributor
Name: Bob alias Whip
Year: 1985
Region: 6 (FL)
NECOA #: 24092
Whip 44 has a spectacular aura about
Garage
From South Florida. Sounds to me like a match made in heaven.
Also nice job on the floor repair. I had a 63 Impala S/S 327 4 on the floor way back when. Loved that car.
  #13
Old 08-24-2016, 11:22 AM
Member
Knuckle Buster
Year: 1981
NECOA #: 72593
The '64 is a bit of a basket case. However, it was built at the Boxwood plant in Delaware, so that was a bit of a match made in heaven, as well. That one is getting a 5.3 and a TKO500. It was originally a 327/4 speed car, and then someone started using it for drag racing. They cut out the bottom of the X-frame and welded on an angled floor to allow for a one-piece driveshaft, and then installed the drivetrain from a '68 Chevelle, from the 396 to the 12 bolt posi.
Of course, we had no idea when we bought the car and told the guy to keep the big block since we were planning on a 5.3 swap and had no use for it.
  #14
Old 08-24-2016, 02:57 PM
old goat's Avatar
old goat old goat is offline
Year: 1985
Model: Conquista
Region: 10(IL,MN,WI)
NECOA #: 23551
old goat is a name known to all
Garage
Cool Greetings from Deerwood MN
Welcome & good luck! Looks great!
Old Goat
  #15
Old 08-27-2016, 07:09 AM
Member
Knuckle Buster
Year: 1981
NECOA #: 72593
I decided to start tackling this floor last night since the FedEx guy dropped off the patch panel from Rock Auto:
After prodding more with the painter's tool, I decided that this was the best course of action:
And after some measuring, cutting, fitting, and recutting, I was able to get the patch piece tacked into place and call it a night:
By the way, the Kobalt wire wheel drill attachments from Lowe's are all I have been using on the Elky and my dad's 64 Impala SS to clean things up. They work very well at stripping paint, rust, and other crud off the sheet metal.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
1981 el camino JessePinkman For New Forum Members Only 34 12-12-2015 08:11 PM
1981 El Camino 267 powerhorse Wanted Items 0 07-03-2014 05:06 PM
1981 El Camino Steve84Ec Ebay / Craigslist Alert 0 07-26-2013 06:32 PM
1981 El Camino nodigg For New Forum Members Only 8 03-18-2012 10:50 AM
1981 El Camino whiteghost For New Forum Members Only 14 09-30-2011 04:31 PM
