Do i have a dash pad? - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-16-2017, 09:17 AM
ThreeHourShower's Avatar
ThreeHourShower ThreeHourShower is offline
Member
Knuckle Buster
Year: 1983
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 76914
ThreeHourShower will become famous soon enough
Default Do i have a dash pad?
Looking at replacing the speakers, but i dont have grills. Instead i just have some perforated holes, leading me to believe there is a pad over the top. Of thats the case, how do i get to my speakers?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old 02-16-2017, 09:29 AM
Member
Knuckle Buster
Year: 1983
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 76914
This is an 83 btw folks, currently im looking for instructions on removal of the entire dash, but im still worried ill have to pry the dash pad off to get to them. Thats the part that worries me.
Old 02-16-2017, 09:49 AM
Rchevelle71's Avatar
Rchevelle71 Rchevelle71 is offline
Year: 1984
Region: 6 (FL)
NECOA #: 49858
Rchevelle71 will become famous soon enough
Looks like a dash cap to me.
Old 02-16-2017, 10:04 AM
Member
Knuckle Buster
Year: 1983
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 76914
Excellent, looks like it will take some work. And good write ups on how to remove one? And if im lucky enough not to break it, what should i use to replace it?
Old 02-16-2017, 10:38 AM
kat0069's Avatar
kat0069 kat0069 is offline
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
kat0069 will become famous soon enough
Garage
Save yourself some effort and put them in the doors? It'll be more expensive probably.....but ultimately easier and you won't chance wrecking your dash. Just my opinion.
What do you mean, "I ain't kind"? I'm just not your kind. -Megadeth, Peace Sells
Too many things to keep tires on.....
1987 El Camino (My Baby) For your entertainment, my build thread:
1968 Camaro RS (our car)
2000 Wrangler Sport (My jeep)
2013 Wrangler Rubicon Unlimited (the wife's daily)
2017 Silverado 1500 Z71 4X4
1976 Corvette
1968 VW Autostick Bug (Project)
2003 Built FXSTI HD Softail Standard (Dyno'd @ 100 hp)
2002 Monaco Dynasty Duchess (Home on the road)
Old 02-16-2017, 10:50 AM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 has a brilliant future
Garage
Here you go'
(this post was written by a well used crash test dummy, on a closed course. No armadillos were harmed in the making of this post. Your mileage may vary. If you have a stiff upper lip lasting more than four hours, seek medical assistance. Reading this post may cause bleary eyes in men over 50, and is known to cause a significant reduction in brain cells....)
Knowledge before $$$$ is my new philosophy!!!!!!
Old 02-16-2017, 10:52 AM
Member
Knuckle Buster
Year: 1983
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 76914
Ill probably put some there too later on, as of now i already have most of the glue seperated successfully, only the front lip under the windsheid is stuck still. Ive been working it out carefully, and the original dash underneath is pretty much garbage.
  #8
Old 02-16-2017, 10:58 AM
Member
Knuckle Buster
Year: 1983
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 76914
Success! The pad is off, and ill clean the adhesive to apply new stuff. Should i just use silicon? What about that spray-on 3M stuff?
  #9
Old 02-16-2017, 04:53 PM
old goat's Avatar
old goat old goat is offline
Year: 1985
Model: Conquista
Region: 10(IL,MN,WI)
NECOA #: 23551
old goat is a name known to all
Garage
Cool From what I remember you....
....have to put the adhesive supplied with dash cap (our others may suggest options) So that the dash can expand and contract! Otherwise it may/will crack! Directions show certain points to apply and not! Good luck!
A bit blurry but...
Old Goat
  #10
Old 02-16-2017, 06:37 PM
Year: 1984
Region: 6 (FL)
NECOA #: 49858
Silicone works for the adhesive
  #11
Old 02-16-2017, 08:27 PM
J.P.Jenny J.P.Jenny is offline
Member
Loose Nut
Year: 1983
Model: Caballero
Region: 13(TX)
NECOA #: 72545
J.P.Jenny will become famous soon enough
Garage
Default Pad
When I do mine, I think I will just use a few carefully thought out locations for double sided tape pads. Just keep it from moving around
The partial cover on it now is not even secured at all and causes no problems. JP
  #12
Old 02-16-2017, 08:49 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
That is an excellent video ! I watched it because my back-burner project is my '87 SS Elco, which is really rough behind the dash, from the leaky windshield, rusty stuff back there !!
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
5th gen Dash and dash pad. Kevinthomas Parts for sale 1 01-19-2017 04:14 PM
Looking for 67 Dash Pad Allmotor Interior Restoration 3 01-08-2017 06:44 AM
Dash pad vs Dash cap Zalked Interior Restoration 7 10-03-2013 09:11 PM
4th gen dash w/dash pad on eBay a73elkyss Ebay / Craigslist Alert 2 08-07-2005 06:39 PM
New Dash Pad vs. Dash Cap mojowrkn Interior Restoration 3 03-02-2004 06:47 PM
