Headers/Dual exhaust conversion - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-16-2017, 11:07 AM
designo614's Avatar
designo614 designo614 is offline
Member
Loose Nut
Year: 1987
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 73610
designo614 will become famous soon enough
Garage
Default Headers/Dual exhaust conversion
I am going to install headers on my 87 305; currently the stock pipes merge into a single cat, then muffler, then split into dual pipes out the back end. With the headers, I want to make it true dual exhaust. To do so, will I need to replace the support crossmember, as with this product?
https://www.dixierestorationdepot.co...TH4&d=1210&p=1
1987 El Camino SS, 1987 Corvette Coupe, 1995 Corvette Convertible, 1966 VW Glass Buggy
Old 02-16-2017, 11:11 AM
kat0069's Avatar
kat0069 kat0069 is offline
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
kat0069 will become famous soon enough
Garage
Looks just like the G-Force unit I bought, works well but they are a bit "fiddly" to install. Maybe if you have access to a lift it won't be so bad. Not a bad price.
What do you mean, "I ain't kind"? I'm just not your kind. -Megadeth, Peace Sells
Too many things to keep tires on.....
1987 El Camino (My Baby) For your entertainment, my build thread:
1968 Camaro RS (our car)
2000 Wrangler Sport (My jeep)
2013 Wrangler Rubicon Unlimited (the wife's daily)
2017 Silverado 1500 Z71 4X4
1976 Corvette
1968 VW Autostick Bug (Project)
2003 Built FXSTI HD Softail Standard (Dyno'd @ 100 hp)
2002 Monaco Dynasty Duchess (Home on the road)
Old 02-16-2017, 11:41 AM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
dual exhaust is a good idea, but
headers and holleys are for racecars..
to get the driver side pipe to tuck up better then yes, something needs to change..
if you use Hooker long tube headers? the driver side header hangs lower so the crossmember is not
absolutely necessary but you loose some ground clearance..
if you can weld, or know someone, you could mod your crossmember,
or just build one..
130$ Jegs free shippin
http://www.jegs.com/p/JEGS-Performan...50980/10002/-1
or
175$ Iceman, check shippin price
http://www.gbodyparts.com/product_in...cc49d988b39556
JJ
Old 02-16-2017, 11:56 AM
designo614's Avatar
Member
Loose Nut
Year: 1987
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 73610
Garage
[QUOTE=JJLT1;2147921]dual exhaust is a good idea, but
Yeah, this won't be a race car by any stretch, but I want better than stock performance. So, I am considering either a number of mods (headers, dual exhaust, cat delete, cam, heads, intake, carb) on my 305 with 116,000 miles, or a new crate 350 swap.
I know the 350 swap will be more expensive, and either way I'll be doing a number of things I never have before. My mechanic tells me it's possible to do all the mods with the engine in place, even the cam if the radiator is out and front brace removed.
Old 02-16-2017, 12:02 PM
Mr86Camino's Avatar
Mr86Camino Mr86Camino is offline
Year: 1986
Model: El Camino SS
Region: 12(MO,OK,KS)
NECOA #: 4450
Mr86Camino will become famous soon enough
By federal law if the car came with a catalytic converter, it needs one forever. If there any emissions testing in your area, it will not pass. The exhaust will stink more with no cat but that is no big deal. It is a law that is widely ignored in may states, but it is a federal offense to remove the Cat.
Most street cars run best whit a X pipe in the system. Droning can be a problem. It all comes down to what your goals are for the car.
1986 El Camino
1985 Porsche 911
2008 Infiniti G35X (wife's car)
Old 02-16-2017, 01:20 PM
designo614's Avatar
Member
Loose Nut
Year: 1987
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 73610
Garage
My county in NC doesn't require emissions testing on '96 and older (currently), so my inspection station has told me they don't check for cats; however I'm not opposed to them. New ones will flow much better than the old ones certainly.
About the X pipe, I've seen those systems for sale also, but didn't know what the advantage was. Cuts down on drone? Still requires the new cutout crossmember I guess, because it's still 2 pipes after the X.
Old 02-16-2017, 01:38 PM
kat0069's Avatar
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
Garage
[quote=designo614;2147930]
You will most likely need the dual exhaust if you install the 350, so it's a good first step. Don't expect huge of "gains" from it, mostly just noise. If you don't like drone, stay away from chambered exhaust like Flowmaster 40 series, which I installed on mine. If I were to do it again, I may not go with headers but instead use better cast iron manifolds. Yes you want an x pipe (IMHO), yes you still need the crossmember (either modified or new).
Also, it's not necessarily true that it will stink more without cats, if it is a healthy engine it shouldn't smell much regardless. I bought high flow cats for mine but the shop I used talked me out of installing them......I am going to install them when I replace my mufflers with something less annoying at highway speeds.
  #8
Old 02-16-2017, 02:00 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
IMO
depending on the setup?? type and pipe diameter/length, muffler/flow/back pressure, routing/install,,
90% of the power increase will be from the dual exhaust, the other 10% average hp is not
worth the aggravation of headers- the install, ground clearance, burnt wires, plug access, leaks,
on a stockish motor..
and after all that youll still need to change the rear gears for the real potential to be known..
i'd do the duals without the header cost, and rear end gears and then see what you think about it..
gears will cost more than the headers, but show bigger returns..
if you want more??
if your thinking heads, cam, intake,
keep driving the 305 and find a roller cam 350 or 383 to buy or build, less down time just to swap..
up-grade money spent on a 350 or 383 would show bigger returns than on the 305,
same money for more torque/power..
  #9
Old 02-16-2017, 09:13 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
Maybe a larger diameter pipes & muffler in a single exhaust, would add a bit of power ?
It's back to the limitations of the 305, for making power....
Do you still have the computer & the carb & distributor ? If you toss the computer, and replace the carb & distributor, cruise wont work if you have it..
  #10
Old 02-16-2017, 09:30 PM
kat0069's Avatar
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
Garage
Quote:
IIRC, There is a work around for this that I've read about on these great forums......it's got something to do with the black wire (for the cruise, under the dash) coming from the ECM needing to be grounded.
  #11
Old 02-16-2017, 10:46 PM
57 Handyman 57 Handyman is offline
Motor Mouth
Year: 1987
Region: 20(HI)
NECOA #: 71626
57 Handyman will become famous soon enough
JJLT1 et.al.,
Will the Jeg's double hump cross member fit in an '87 EC without any problems? Since Jeg's does not show El Camino in its listing for this part, I am wondering. However, the bigger factor is the Jeg's unit is $100 less than the comparable G-Force which many seem to gravitate to.
  #12
Old 02-16-2017, 11:48 PM
jpmdaddy's Avatar
jpmdaddy jpmdaddy is offline
Site Contributor
Year: 1966
Region: 13(TX)
NECOA #: 20314
jpmdaddy is of outstanding character
Save your 305 tuning money and buy a new 350 crate motor, they start at about $1600 and lately both SummitRacing and JEGS have had free shipping
  #13
Old 02-17-2017, 05:01 AM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
i'v been told by some other guys on here have used them with no problems,
yea I think they say they'll fit one cutlass supreme but not another cutlass supreme
with a different trim package too..
  #14
Old 02-17-2017, 05:12 AM
designo614's Avatar
Member
Loose Nut
Year: 1987
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 73610
Garage
Quote:
I spent my time last night browsing Jegs and Summit exactly for that; think I'm headed in that direction. Blueprint engines are cheaper than GM, but there may be a good reason why... anyone have experience there?
  #15
Old 02-17-2017, 06:21 AM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
David are you going to keep the computer??
the GM motors are bran-new,, the Blueprint are probly all rebuilt..
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Dual exhaust Beepster Performance Modifications 18 01-26-2012 08:54 AM
Dual Exhaust and new Headers MASierra Performance Modifications 13 08-04-2011 04:19 PM
Dual exaust without headers Allie's79 Performance Modifications 3 09-15-2009 02:29 PM
1979 with 3bolt 3" headers...need dual exhaust Xonticus Performance Modifications 5 08-12-2006 09:01 PM
Need tips on type of headers and dual exhaust to install Elcaminonyc For New Forum Members Only 15 10-20-2003 08:13 AM
