Old vet motor - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-02-2017, 06:24 PM
RaZar's Avatar
RaZar RaZar is offline
Junior Member
NooB
Year: 1964
Region: 16(CO,MT,WY,UT)
NECOA #: 46954
RaZar will become famous soon enough
Default Old vet motor
Ok this is the deal .i picked up this 65 vet motor..it's got camel back heads..polished crank ..very low miles the cills mike out great .got the KB Pistons .hade the heads dun 202s all fresh ..my Q is should I go with the old school carb or FI...and I am running a duntov set up..a 303 duntove
Old 01-02-2017, 06:29 PM
RaZar's Avatar
Junior Member
NooB
Year: 1964
NECOA #: 46954
Default Haha
Sorry bout that guys ...I have allways run mopar.im new a Chevy guy ...but I love them all
Old 01-02-2017, 06:38 PM
RaZar's Avatar
Junior Member
NooB
Year: 1964
NECOA #: 46954
BTW I am running 4 speed...
Old 01-02-2017, 07:35 PM
84elcoconquista's Avatar
84elcoconquista 84elcoconquista is offline
Year: 1984
Model: Conquista
Region: 12(MO,OK,KS)
NECOA #: 20278
84elcoconquista will become famous soon enough
Garage
You may find this interesting. After seeing this, I wished I could afford fuel injection!
Pretty cool comparison.
1984 - El Camino Conquista~ 305;3-Speed; 2.41
Old 01-02-2017, 09:00 PM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 has a brilliant future
Garage
Quote:
Save your money go carb. and tune it with an Auto Meter Wide Band A/F Gauge and a Vacuum Gauge.
AutoMeter 4379 Ultra-Lite Wide Band Air Fuel Ratio Kit; 2 1/16 in.; 10:1-17:1 Ratio; Silver Dial Face w/Digital Display; Brushed Aluminum Bezel; Red LCD w/Red; Yellow; Green Segment;
I have learned to never characterize any of my cars as fixed....they are just temporarily between malfunctions. .....Dan ( old_coot)
Knowledge before $$$$ is my new philosophy!!!!!!
Old 01-03-2017, 07:40 AM
Marv D's Avatar
Marv D Marv D is offline
Year: 1967
Region: 15(AZ,MN)
NECOA #: 13944
Marv D has a reputation beyond reputeMarv D has a reputation beyond repute
Not trying to burst any bubbles, just it always amazes me how many 'vette' motors there are out there for sale. There are more 'vette' motors out there than there were 'vettes'!!! Assuming this one had the stamping on the pad that verifies it really a L84 solid lifter FI motor that went into vettes...
So what we got if it is truely a 1965 L84 motor the ID pad will verify. Lets assume you have traced the stamping and casting clock and verified....
What we got is a Early small journal forged crank( good) , rods with the small rod bolts (bad), and sounds like someone has replaced the TRW 11:1 forged pistons with a set of KB pistons. (IMO could be VERY bad)
Have you verified the deck clearance?? MANY of the builder KB pistons are a reduced pin height putting the piston 0.040"+ down the hole, and leave a 0.080 - 0.120"+ quench even with a 0.020" steel shim head gasket.
None of the early small journal blocks are 4 bolt, but that is of minor concequence for practical use (street)
L76, L79, L84,,, these WERE some of the most powerfull smallblocks (HP to cubic inches) to come out of Detroit for many decades to come. BUT running 11:1 compression today with unleaded crap fuel available isn't gonna be fun. And reducing the compression with a piston swap is going to KILL the HP. The L84 solid cam is intended for 4000-6500 RPM really intended for road-racing, and high RPM use (not real street happy)
What have you verified in stamping and casting numbers that tells us what we are working with? I'll be honest,, if it truely IS a 65 L84 motor,, I'd sell that thing to a Corvette restorer and take the bucks and go buy a motor more fitting to todays fuels and street driving.
But that's just me. Your mileage may vary.
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.....
I just finished reviewing my social security statement and thanks to the current administrations handling of my SS funds,,,, I only have to work until noon on the day of my funeral
Old 01-03-2017, 11:51 AM
paulj paulj is offline
Year: 1964
Region: 9 (IN,KY,MI)
NECOA #: 65705
paulj will become famous soon enough
Back in the mid 60's Honest Charley sold FI short blocks for around 250 and 202 heads for 100 bucks. No, they weren't out of a vette but....
  #8
Old 01-11-2017, 02:12 PM
Fox C.'s Avatar
Fox C. Fox C. is offline
Junior Member
Twisted Wrench
Year: 1977
Model: El Camino Classic
Region: 5 (NC,SC)
NECOA #: 75585
Fox C. will become famous soon enough
Garage
Default Big Time Small Block Fan
Just for reading pleasure, I wanted to give a little input. A few years ago I traded my 406 ATK dirt bike (after it back fired and threw me over the handlebars, fracturing my heel and spraining my ankle... 406 2-stroke is no joke) for a 1969 Med. journal 327 short block. I didn't get the original 461 heads as they had been used on one of his late models, but he gave me three 370 heads (Pontiac 300hp/350 heads, used in the Chevy powered Firebirds). I did get the original 461 high-rise intake, and it still has a Duntov 30/30 cam in it. I also have an original Holley 770cfm Vac, secondary, but I think I'll use the 850cfm Carter Quadra-Jet I recently overhauled.
I plan to build this engine for my 77 Elky. Will need a lot more stall and have to go much lower in my rear gear than I've had for a daily driver. The biggest thing keeping me from starting the build is the cost of the pistons. I plan to shoot some nitrous to it, so forged is a must. I have not found flat-tops with the required 1.675 compression height, I'll have to opt for 7.5cc domes to keep the 11:1 compression as factory. I want to keep it as near original as possible. In it's day, this was a 365hp monster of a small block.
My buddy just took a 430hp/355ci iron-block out of his S10, and dropped in an LS... I'm not going that route... I get much more satisfaction from being competitive with 48 year old know how. "Old School Rules"...
  #9
Old 01-11-2017, 03:37 PM
xlchjoe's Avatar
xlchjoe xlchjoe is offline
Site Contributor
Year: 1971
Region: 3 (DE,NJ,PA)
NECOA #: 52961
xlchjoe is a name known to all
Garage
Quote:
Originally Posted by Fox C. View Post
...A few years ago I traded my 406 ATK dirt bike (after it back fired and threw me over the handlebars, fracturing my heel and spraining my ankle...
Didn't mommy tell you to kick through and hold kicker down till it either starts or finishes motion?
And I will not be commanded
And I will not be controlled
And I will not let my future go on
Without the help of my soul
71 Camino
02 Z28
03 Blazer
11 Vette
11 Fatboy
  #10
Old 01-11-2017, 04:28 PM
84withzz4's Avatar
84withzz4 84withzz4 is offline
Year: 1984
Region: 14(AR,LA,MS)
NECOA #: 3532
84withzz4 will become famous soon enough
I'm testing my memory here. I think the really good Duntov cam part number ended in 098. Local Chevy parts dept could not keep them in stock. The valve setting was 8 & 16. it really had that thump, thump, thump sound. I later ran the 30/30 cam. I didn't care for it at all! switched back....
1984 El Camino Choo Choo Custom Clone w/ ZZ4
1995 Buick Century S/W - 138K miles - wife's car
2006 Buick Lacrosse - 18K miles - wife's 2nd
Veterans Administration retired 1967-1997
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Vet's Weekend! donaldta Region 8 (OH,WV) 3 11-11-2016 04:34 PM
Changing carb motor to TBI motor DBC86ElCamino Engine Topics 5 07-31-2013 05:17 PM
Motor stand motor mounting question HKDUP87 Engine Topics 12 05-31-2012 08:22 AM
difference between a car motor and a truck motor ? 82HotRodWannabe Engine Topics 5 01-15-2005 04:44 PM
VIDEO OF MY ELKYHOLIC BEFORE THE BIG MOTOR AND ALL MOTOR mrfogger General BS Topics 4 01-15-2005 12:08 PM
