Drip rail seal installation? - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-10-2017, 01:48 PM
78 Elk's Avatar
78 Elk 78 Elk is offline
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is just really nice
Default Drip rail seal installation?
I purchased a set of drip rail seals for my 78 from Mike's Monte. I couldn't get them to seal. So I purchased some from Steele Rubber. These are a little wider. I could use some tips on how to install them. I want to start and glue the middle section over the top of window first. How have you been doing yours? All help is appreciated.
hagensen78
Old 01-10-2017, 02:57 PM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
start in the corner, and go both ways..
JJ
Old 01-10-2017, 06:03 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Thanks I'll give it a try.
Old 01-10-2017, 07:20 PM
greywolf's Avatar
greywolf greywolf is offline
Year: 1984
Region: 12(MO,OK,KS)
NECOA #: 64
greywolf has a spectacular aura about
Garage
What JJ said. The rear corner is the only hard point you can't fudge. I put a dab of weather strip adhesive there and worked forward. Hook the inside into the channel and then poke it in from the outside. I also used a little weather strip adhesive at the front corner and ends of the seal. The seal also had a couple plastic buttons to hold down the ends of the seal.
When you're done, you'll see it's different from the old seal so the window will need adjustment.
Old 01-10-2017, 07:55 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
I could not remember if the corner was in front or back??
don't stretch the rubber if you don't have to
and
if it seems too long, you can lightly bunch it just a little..
Old 01-10-2017, 08:30 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Those are great tips. Thank you.
Old 01-11-2017, 06:42 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
x2 check the fit before slamming the door too hard the first time..
maybe roll the window down about a 1/4" the first time, check the gap..
I usually lay the seals out in the sun the day before and let them unwind..
if you have a black bed mat, it works good for a heater..
it probly would work better changing them in the summer,
then let it sit out in the sun for a few days or a week, before adjusting, it will probly settle some more..
  #8
Old 01-11-2017, 07:40 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Thanks. I already took the old one out. I was planning to ask about the blue temps. Do you suppose that halogen lights would work to warm them up in the bed of my black Elk.
  #9
Old 01-11-2017, 09:00 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
o yea it would probly help, if there hard..
just saw the lows for tomorrow
http://www.intellicast.com/National/...wTomorrow.aspx
it was 23* sat morning here, and i'v had the ac on since sunday..
maybe even throw them in the dryer on low for a little while?? maybe??
  #10
Old 01-11-2017, 09:12 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Thanks. My phone messed up. I was talking about glue temperature. If I try I'll bring them in the house a to apply the glue. I'm using the 3M black glue.
  #11
Old 01-11-2017, 09:25 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
I don't what the temps will do to the glue?? it don't say??
http://www.3m.com/3M/en_US/company-u...2908126&rt=rud
Quote:
3M™ Black Super Weatherstrip Adhesive
Work Time ... Less Than 4 Minutes ..
brush and spread as needed on each surface, and let it cure for up to 24 hours.
  #12
Old 01-11-2017, 09:36 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
I couldn't find anything either. Thought I would ask. Thanks again.
  #13
Old 01-11-2017, 09:47 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
you could do a test on something,
scrap metal or such, just to see if it will set up in the cold, or how long..
  #14
Old 01-11-2017, 09:59 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Thanks, I'll give that a try.
  #15
Old 01-14-2017, 10:09 AM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Just for information,. I put the 3M weatherstripping glue on a piece of metal in the garage. The temperature was 13* and it set up well. It won't scrape off with finger nails.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Drip Rail Aaron M Body Restoration 3 08-18-2014 12:17 PM
Drip rail help please Wayne,az Body Restoration 7 11-06-2013 05:15 PM
drip rail bigdoged Wanted Items 0 11-06-2013 04:03 PM
67 drip rail rayray562 Body Restoration 7 03-17-2013 06:48 PM
cab drip rail 78 Elk Body Restoration 4 11-06-2012 08:30 AM
