A/C Question... - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-10-2017, 04:44 PM
Zerberfert's Avatar
Zerberfert Zerberfert is offline
Year: 1986
Region: 13(TX)
NECOA #: 16779
Zerberfert will become famous soon enough
Garage
Default A/C Question...
If needed, here is a little background about my build: http://www.elcaminocentral.com/showthread.php?t=192457
I am about to hook up my A/C soon and I have a few questions. Here is a picture of the power connector for the old A/C compressor.
Are both of those green wires power wires, or is one of them a ground?
Do I need to put the diode in the new connector for the new compressor?
The connectors are different, but I have a new pigtail, so no problems there.
No problem on tell where the power wire goes.
Depending on the answers, I am sure I have more questions.
Work smarter, not harder.
Old 01-10-2017, 05:18 PM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
does yours have the ac relay like the 87?? I think??
one is power and one is a ground
the green one from the cycle switch should be the +pos..
I believe the diode/resistor thang does serve a purpose, it keeps the switch contacts in better shape..
something about a back surge, or emp, or a nuculer somethin or other,
when the magnetic field collapses in the clutch..
JJ
Old 01-10-2017, 06:33 PM
Zerberfert's Avatar
Year: 1986
Region: 13(TX)
NECOA #: 16779
Garage
Not sure if an 86 had a relay or not. I don't remember seeing one and thanks for the info.
Old 01-11-2017, 07:48 PM
sandblaster's Avatar
sandblaster sandblaster is offline
Year: 1985
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 727
sandblaster has a spectacular aura about
Garage
Some reading info on the Diode HERE :http://www.freeasestudyguides.com/ac...coil-test.html
Old 01-11-2017, 08:35 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
its coming back to me now
you can get the relays with the diode built in now days too...
as said in the reading, the new clutch coils may have a diode built in, maybe that's why is says which is + and - ..
check it both ways thru thru the coil with a ohm meter..
x2 spiking the ecm is bad news..
but those test are fun..
Old 01-12-2017, 04:31 PM
Zerberfert's Avatar
Year: 1986
Region: 13(TX)
NECOA #: 16779
Garage
I think I am getting this figured out. Please check the video.
https://youtu.be/Tws4sVURmFI
I think there is a diode in the compressor coils already. If this is true, can I assume that I will not have to add a 2nd diode on the pigtail connector?
I also show what I think is the A/C relay. Can they be pick up at a local auto parts?
The coil had 3.5 ohms which that link said was good.
I hope to hook everything up and have A/C this weekend. It getting to the low 80's in this part of Texas, which is ridiculous.
Thanks for all the info.
Old 01-12-2017, 05:40 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
Quote:
This video is unavailable.
Sorry about that.
i aint no lec-trick-shen, but i assume??
if you can not get a ohm reading both ways thru the coil?? then it has a diode..
and i would not think you need 2 diodes?? don't know??
  #8
Old 01-12-2017, 06:41 PM
Zerberfert's Avatar
Year: 1986
Region: 13(TX)
NECOA #: 16779
Garage
Video should be viewable now.
Didn't think about checking the ohms both ways...
  #9
Old 01-12-2017, 06:58 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
fancy meter too..
if that relay gets a hot signal with the ac switch on?? then maybe??
i have not traced out the one with the power steering switching the ac..
  #10
Old 01-12-2017, 07:09 PM
Zerberfert's Avatar
Year: 1986
Region: 13(TX)
NECOA #: 16779
Garage
I removed the power steering switch and just connected those wire together. Hope that's not a problem.
Also, when I reversed the leads on the compressor, no beep to say it's a diode. I was not paying attention to the numbers. If I remember how my multimeter works, the beep is enough to tell you without looking at the numbers.
I need to do some wiring before I will know if I get power to what I think is the A/C relay. I looked on rockauto and didn't see any. Need to look on the internet somemore.
Thanks again,
  #11
Old 01-12-2017, 07:29 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
these are 87 diagrams, caprice with a relay,, and Elky w/o the relay..
I should have said, I have not traced out the 1 with a relay...
ID:	70466   Click image for larger version
  #12
Old 01-12-2017, 07:34 PM
Zerberfert's Avatar
Year: 1986
Region: 13(TX)
NECOA #: 16779
Garage
Looking at the first picture, in the middle of the picture it shows the ECM. Do you have to have the computer for the A/C to work?
  #13
Old 01-12-2017, 07:37 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
I don't know Skip..
looks like if you don't have the ecm anymore, you don't need the relay..
there is nothing to close the relay..
if that's what the relay is for???
  #14
Old 01-12-2017, 07:44 PM
Zerberfert's Avatar
Year: 1986
Region: 13(TX)
NECOA #: 16779
Garage
Then would the A/C even work? Getting nervous again.
I think I understand the 2nd picture pretty well. The Mode Selection Switch goes to the Pressure Cycling Switch which I think is on the Dryer. Then from there the power steering switch which I removed. Then to the compressor. That should get the power to the compressor I hope.
  #15
Old 01-12-2017, 07:53 PM
Zerberfert's Avatar
Year: 1986
Region: 13(TX)
NECOA #: 16779
Garage
JJLT1, could you verify the first picture is for Vin Y vehicles. Mine is a Vin G, so don't think that pic is for my Elky. That would be good news.
Thanks for all the help.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Gen. Question / Alternator Question OLD GEEZER RICHARD Region 13 (TX) 3 01-14-2013 08:15 PM
question ? related to the what is this wire question harpman1 Electrical Systems 7 08-17-2012 06:59 PM
