Hello all,
I'm currently in the middle of a full-on HEI rebuild with the goal in mind to maximize timing performance to achieve the best possible fuel economy. We're not talking your basic cap and rotor type rebuild, but a full disassembly and cleaning, checking the advance mechanism, re-curving of advance weights and an adjustable vacuum advance. I will document everything here visually for those that are interested, but first I have a question:
What is an ideal shimmed clearance between the distributor housing and the gear? I have a Moroso shim kit for such an adjustment, but there is no indication as to what I'm shooting for. Currently, I have about .058" (via feeler gauges) endplay. You can physically lift the rotor shaft up when installed, which has a distinct effect on the timing, retarding it quite a bit.
Shaft endplay - shaft at its bottom of travel
Shaft endplay - when the shaft lifts, as it would under acceleration, timing retard significantly
Anyone have a spec to I should try to achieve for clearance? Thanks!
