kat0069's '87 El Camino - Page 7 - El Camino Central Forum : Chevrolet El Camino Forums
  #91
Old 02-05-2017, 03:07 AM
cquester5 cquester5 is offline
Site Contributor
Year: 1969
Model: El Camino SS
Region: 6 (FL)
NECOA #: 56954
cquester5 will become famous soon enough
Garage
Quote:
Originally Posted by kat0069 View Post
Hello All!
Stopped by the Rod Shop to drop off the Dakota Digital parts this morning and get some update pictures. I forgot to get some of the pictures I wanted while at the shop today, but I have a few to go along with the updates. If you want to see some more install pics of the clutch pedal assembly you can check it out in this Rod Shop link http://www.jimsrodshop.net/Taylor_19...ElCamino__.htm
For the fuel system.
http://i392.photobucket.com/albums/p...psjlmxqef8.jpg
http://i392.photobucket.com/albums/p...psy7jzow4d.jpg
http://i392.photobucket.com/albums/p...psocchnhsn.jpg
http://i392.photobucket.com/albums/p...psgjke90wn.jpg
http://i392.photobucket.com/albums/p...psztal2sdk.jpg
They have the fuel tank fitted with the Stealth 340 retro fit kit, the fuel lines ran and are ready to put the tank back in. There may need to be some minor trimming of a bed brace and a plate installed from what I can see first hand. We shall see.
The Engine.
http://i392.photobucket.com/albums/p...psr2rv4ukb.jpg
http://i392.photobucket.com/albums/p...psurflummq.jpg
http://i392.photobucket.com/albums/p...psjxg0ou1b.jpg
Engine is set into place, exhaust is reconnected. It looks like there is plenty of room for the serpentine system.
Transmission.
http://i392.photobucket.com/albums/p...pswhgjlmy0.jpg
http://i392.photobucket.com/albums/p...pserbc9i0p.jpg
http://i392.photobucket.com/albums/p...psjxvlbkd1.jpg
http://i392.photobucket.com/albums/p...psmisbbdu0.jpg
http://i392.photobucket.com/albums/p...pswwrmjlgs.jpg
They have the transmission in, clutch, pressure plate, hydraulic throw out bearing, clutch master cylinder mounted, clutch pedal installed and beginning the trans tunnel mods and shifter hump fabrication.
A couple of random shots of the bottom of the car.
http://i392.photobucket.com/albums/p...psggatk4lx.jpg
http://i392.photobucket.com/albums/p...psuh8tehkx.jpg
On a side note, under the carpet and all along the bottom of the car is exceptionally "clean" and rust free. So far except for the battery box area there has been no metal work that isn't related to the trans tunnel mod.
Next on the list is to get the tins back on it, then to get it motivating under it's own power. It's starting to resemble a car again!
Thanks for looking.
WTG Kyle...really looking good. It has been quite the journey for you!
  #92
Old 02-05-2017, 09:55 AM
kat0069's Avatar
kat0069 kat0069 is offline
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
kat0069 will become famous soon enough
Garage
Taking much longer than I expected.....I guess I'll learn patients one way or another!
What do you mean, "I ain't kind"? I'm just not your kind. -Megadeth, Peace Sells
Too many things to keep tires on.....
1987 El Camino (My Baby) For your entertainment, my build thread:
1968 Camaro RS (our car)
2000 Wrangler Sport (My jeep)
2013 Wrangler Rubicon Unlimited (the wife's daily)
2017 Silverado 1500 Z71 4X4
1976 Corvette
1968 VW Autostick Bug (Project)
2003 Built FXSTI HD Softail Standard (Dyno'd @ 100 hp)
2002 Monaco Dynasty Duchess (Home on the road)
  #93
Old 02-05-2017, 11:21 AM
Zerberfert's Avatar
Zerberfert Zerberfert is offline
Year: 1986
Region: 13(TX)
NECOA #: 16779
Zerberfert will become famous soon enough
Garage
WTG. Keep it up and don't get in a hurry. Most of my major mistakes were when I got in a hurry.
Work smarter, not harder.
  #94
Old 02-06-2017, 04:03 PM
kat0069's Avatar
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
Garage
I got a few more pictures on the way out of town. They had a bit more work done as well.
One of the Bypass piping that was made for the Vortec intake.
Pic of the Sick Speed Monte clutch pedal installed.
This one shows some of the hokey wiring I did when I installed a neutral safety switch for the Automatic floor shift.....don't laugh too hard, it worked.
Cleaned painted & reinstalled Booster / Master cylinder.
One of the Plumbing for the throw out bearing & how it's routed to keep it off the headers.
Random shot.....
  #95
Old 02-13-2017, 09:48 PM
kat0069's Avatar
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
Garage
Here are the pictures for the above post....in order. (I just realized my photo's did not attach from Dropbox)
  #96
Old 02-13-2017, 10:02 PM
kat0069's Avatar
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
Garage
I received a few more progress pictures today.
This one is the mount that was fabricated for the hydraulic master cylinder reservoir.
This one is a shot of the finished product.
Here are a couple of shots of the transmission tunnel mods taking shape.
Here are some shots from under the hood, some of the systems being tied in.
AND last but not least....the tins are going back on at long last!
Thanks for looking!
  #97
Old 02-14-2017, 02:25 AM
Site Contributor
Year: 1969
Model: El Camino SS
Region: 6 (FL)
NECOA #: 56954
Garage
Coming along great Kyle!!
  #98
Old 02-16-2017, 10:25 PM
kat0069's Avatar
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
Garage
There's been some more progress, thought I'd share.
A couple more shots of the transmission tunnel mods, it's nearly complete.
Some more pictures from under the hood (which isn't on the car).
There were some modification to a bed brace required to get the tank back under the car.
Here's some shots of fuel delivery components going in.
And another shot of the core support, it shows the color a bit better.
Thanks for looking.
  #99
Old 02-17-2017, 08:27 AM
Old Bear's Avatar
Old Bear Old Bear is offline
Site Contributor
Name: Gale and his cats
Year: 1970
Region: 18(CA)
NECOA #: 38617
Old Bear has a brilliant future
Garage
Deleted msg - Kyle's images are showing up OK Now.
  #100
Old 02-17-2017, 09:52 PM
kat0069's Avatar
Silver Contributor
Name: Kyle A Taylor
Year: 1987
Region: 15(AZ,NM)
NECOA #: 36434
Garage
Hey all!
Whatcha' think of the kick a** chrome grille that Eklers sent me for my Camino......I bet whomever got it would MUCH rather have their package, that I received.
Test fitting the new radiator today.....looks like it doesn't fit so well.
Seems like a bust all in all......can't win 'em all I guess.
Tags
aeromotive, crate, el camino, fast, tko
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
