Irwindale Raceway2016 Part 2 "QTR TNZ" Thursday Nights Come Down See The Excitement - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Regional Discussion Forums > Regional Discussion > Region 18 (CA)
Old 03-04-2016, 09:07 PM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 has a brilliant future
Garage
Default Irwindale Raceway2016 Part 2 "QTR TNZ" Thursday Nights Come Down See The Excitement
I started this thread back on 8/21/2015.
"Taking the 85 to the Irwindale Drags Saturday Night anybody else interested?" With over 21,000 hits and a lot of obstacles in our path D & R Racing LLC would like to thank you for all of your support.
It's now 2016 and Dale and I on the right track to be able to say "QTR TNZ" are in our sights so I wanted to start this new thread with our dyno results and Test and tune.
"Irwindale Raceway 2016 Part 2 Thursday Nights Come On Down And See The Excitement"
Yesterday Dale , Gale and I went to R & D Dyno in Gardena CA to see what we had or didn't have with my 509 Big Block. The first pull they used the Dyno results to see what needed to be adjusted and came with A/F motor was running lean and the jets were too small for the 950 Holley so they changed them from 76 to 80's on the pri. bowl and 84 to 88's on the sec. The timing was set by another shop to 38 so they backed it down to 36 total timing. The next two pulls were almost identical at 491.50 HP @6000 RPM @ 491.07 Torque at the rear wheels. I guess with the TH400 25% Power Loss that's around 653 HP at the motor. Not bad and we have room for improvement. I guess by installing 1-inch Phenolic spacer on the intake/carb. to keep the fuel cooler we could pick up 10HP for $24.00
Here's the Dyno pull and results.
https://www.youtube.com/watch?v=hD25N5_9FLs
Next we went to Irwindale to see what the truck would do.
Two runs 1/8 mi. E/T's 7.17 @ 99 MPH 60FT 1.63
We did it the front tires showed daylight between the asphalt and tire.
Give it up for Gale he was eating rubber while filming.
https://www.youtube.com/watch?v=_MxVP2aRM5Q
https://www.youtube.com/watch?v=5TMh1oxLGwo
https://www.youtube.com/watch?v=DPEmmJib7_c
Here's from Dale's vantage point.
We're now doing the G-Body Twist.
https://www.youtube.com/watch?v=gLDXD_IASug
https://www.youtube.com/watch?v=qjMVTLGeZGY
I chocked this run but Gale got the worse filming from the rear tire.
https://www.youtube.com/watch?v=Z43pEqme2DI
Stay tuned this should be a good couple of months and come on down to the track it's a blast plus there's a wealth on knowledge to be had on motors just ask.
(this post was written by a well used crash test dummy, on a closed course. No armadillos were harmed in the making of this post. Your mileage may vary. If you have a stiff upper lip lasting more than four hours, seek medical assistance. Reading this post may cause bleary eyes in men over 50, and is known to cause a significant reduction in brain cells....)
Knowledge before $$$$ is my new philosophy!!!!!!
Old 03-04-2016, 09:26 PM
78 Elk's Avatar
78 Elk 78 Elk is offline
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is just really nice
Thanks for sharing your experience. Awesome video's.
hagensen78
Old 03-04-2016, 09:41 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
First point of business is shedding weight. We already have a Harwood fiberglass pin down hood that will shed close to 75lbs off the front then hack a 1/3 off the 3-inch exhaust from the rear tires to the rear end of the truck and install Flowmaster 44's or Dynomax Hemi Super Turbo's out the rear wheels. The extra pipe will save money modifying the system .
@ $198.00 ea. fiberglass front fenders are being considered also. Inner door panels will be changed with Alum. door panels, shed the electric door locks and go to a single headlights up front..
From what I'm told every 100lbs shaves a 1/10 off the E/T so 6's are a reality here quick. After one run last night I was informed by Tech I must have my flame retardant jacket on while in the truck. I have noticed lately the tech inspection on my truck is getting more attention. Their now on there knees looking under the truck and checking all SFI/NHRA required equipment for date codes and class. I HAVE NO PROBLEM WITH IT SAFTEY FIRST!!!!!
Old 03-04-2016, 10:54 PM
steve69ss396's Avatar
steve69ss396 steve69ss396 is offline
Year: 1969
Model: El Camino SS
Region: 18(CA)
NECOA #: 2083
steve69ss396 has a spectacular aura about
Garage
Congrats!
Your driving has gotten better and more consistent. What does your converter flash to and what rpm are you crossing the line at?
Old 03-05-2016, 03:44 AM
xlchjoe's Avatar
xlchjoe xlchjoe is offline
Site Contributor
Year: 1971
Region: 3 (DE,NJ,PA)
NECOA #: 52961
xlchjoe is a name known to all
Garage
Way to go(sic) Robert! Enjoying watching you progress from a Wannabe to a Track Smart Driver/Owner.
And I will not be commanded
And I will not be controlled
And I will not let my future go on
Without the help of my soul
71 Camino
02 Z28
03 Blazer
11 Vette
11 Fatboy
Old 03-05-2016, 10:26 AM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Quote:
Originally Posted by steve69ss396 View Post
Congrats!
3100 And looks like 5800 RPM. Any suggestions?
Old 03-05-2016, 10:31 AM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
  #8
Old 03-05-2016, 11:15 AM
Year: 1969
Model: El Camino SS
Region: 18(CA)
NECOA #: 2083
Garage
Quote:
It doesn't appear to be spinning. A looser converter would probably help. Definitely if the one you have now only flashes to a little over 3,000. The video's you just posted say you launched at 4,500 on one pass? If it flashes that high, that's good. What size is the converter, probably 10"? What RPM did the motor make peak HP. You want to cross the line above the peak.
  #9
Old 03-05-2016, 05:32 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Oh Yea courtesy of Gale!!!!!
  #10
Old 03-05-2016, 11:08 PM
Old Bear's Avatar
Old Bear Old Bear is offline
Site Contributor
Name: Gale and his cats
Year: 1970
Region: 18(CA)
NECOA #: 38617
Old Bear has much to be proud of
Garage
These are the folks that helped with the tuning improvements Thursday.
R & D Dyno Tuning and Automotive Performance Consulting
  #11
Old 03-06-2016, 02:51 AM
DONE DEAL DONNY's Avatar
Year: 1984
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a reputation beyond reputeDONE DEAL DONNY has a reputation beyond reputeDONE DEAL DONNY has a reputation beyond repute
Garage
Man, those are great dyno numbers!!!
keepem coming!!
#12, 1984 El Camino "Bumping Uglies"
  #12
Old 03-06-2016, 03:05 AM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Peaks at 6000 RPM but doing the math it should be 6400
Torque Converter, 10 in. Diameter, Powerglide, TH350, TH400, 2,900-3,300 Stall, Each
Input Spline Quantity:
30
Anti-Ballooning Plate:
Yes
Lockup:
No
Diameter (in):
10.000 in.
Crank Pilot Diameter:
1.703 in.
Furnace-Brazed:
Yes
Balanced:
Yes
  #13
Old 03-06-2016, 07:19 AM
Haastalavista's Avatar
Haastalavista Haastalavista is offline
Year: 1981
Region: 13(TX)
NECOA #: 911
Haastalavista has a spectacular aura about
Garage
If you watch the launch where you're running against the KITT Firebird there's something goofy with the launch. Looks like the trans brake releases and then grabs again. Or something like that. Definitely a stutter there after it starts to move.
  #14
Old 03-06-2016, 07:32 AM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Quote:
That was me getting excited and shifting into second after releasing the trans brake button.
  #15
Old 03-07-2016, 04:01 PM
Year: 1981
Region: 13(TX)
NECOA #: 911
Garage
Good. Glad it's nothing mechanical.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
"El Camino Night" - July 15, 2016 John Harris Region 2 (CT,MA,ME,NH,RI,VT) 41 08-01-2016 04:31 PM
Here's a ten part series " CARRIER" As the USS Nimitz sets off for the Persian Gulf HKDUP87 General BS Topics 7 08-20-2013 10:24 AM
GAP MATTERS PART 2 " .055 " Sweet Jesus the time is here for all to know HKDUP87 Engine Topics 19 07-14-2013 11:03 AM
200C "kickout" "cutloose" Trans Lingo? Wkumet Transmission & Drive line 3 03-17-2012 12:24 AM
Interior part "Bondo" for repairing nicks, scrapes? rbabcock Interior Restoration 2 11-16-2011 11:53 AM
