Holley Street Avenger - El Camino Central Forum : Chevrolet El Camino Forums
Old 05-04-2017, 01:20 PM
78 Elk's Avatar
78 Elk 78 Elk is offline
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is just really nice
Default Holley Street Avenger
I have been having issues with my Holley Street Avenger. Holley has agreed to repair and send it back to me for$75.00. I'm have to pay freight to them. I thought this sounded pretty good since I have had this carb since 03.
hagensen78
Old 05-04-2017, 02:00 PM
jim48442's Avatar
jim48442 jim48442 is offline
Member
Loose Nut
Year: 1981
Region: 9 (IN,KY,MI)
NECOA #: 76545
jim48442 will become famous soon enough
Garage
What one are you using. Im using a 870 converted mine back to manual choke. Never really had and problems but does seem to run rich or lean lol. Cant pass a gas station with this on a big block. Im really thinking of just going to a 650 double pumper or a deisel engine hahaha.
Old 05-04-2017, 02:10 PM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
yea, a good kit is probly half of that..
whats it doing??
did you get the leaking fixed?? i think thats what we were talking about onetime before??
JJ
Old 05-04-2017, 02:29 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Mine is a 670. I'm having problems with the Choke. I set the Choke. Then if I touch the butterfly, it falls to the open position. If you don't touch it, it falls when you start it. I took the Choke cap off and all is good. The other issue is the fuel bowls overfill. I take the sight covers off. Then rock the car, reset the floats with the car running. In a few days it's overfull again. The leak issue was resolved with the fuel regulator, which is set at 6lbs.
Old 05-04-2017, 03:23 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
a driver car would probly be fine with 4-5psi fuel pressure, it may help the overfilling too..
try 5psi and see if it gets better??
sounds like the spring/linkage is disconnected on the choke flap/butterfly??
if you richen the choke setting, can you feel the spring on the flap??
http://www.onallcylinders.com/2013/0...el-carburetor/
Old 05-04-2017, 03:39 PM
jim48442's Avatar
Member
Loose Nut
Year: 1981
NECOA #: 76545
Garage
I would have to agree if the flap just falls your linkage isnt hooked up.
Old 05-04-2017, 04:14 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Thanks. There isn't any spring on this linkage. It just runs on the fast idle cam.
  #8
Old 05-04-2017, 04:21 PM
Rchevelle71's Avatar
Rchevelle71 Rchevelle71 is offline
Year: 1984
Region: 6 (FL)
NECOA #: 49858
Rchevelle71 will become famous soon enough
The spring is internal, under the cover, the windy thing that grows with heat.
  #9
Old 05-04-2017, 04:26 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
this is a electric choke??
the spring is in the black cover,
turning the cover rich or lean should make the spring tighter or looser..
  #10
Old 05-04-2017, 04:47 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
I don't know. The spring looks like new and it moves the butterfly when I set the Choke. When I set the Choke further, then it sticks. Then the next time the Choke won't work.
  #11
Old 05-04-2017, 05:00 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
I was having problems with the bowls flooding at 5.5 lbs. Not a problem at 9-9.5lbs.
  #12
Old 05-04-2017, 05:04 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
still sounds like the spring connection to the choke linkage/flap is not right,,
the choke flap should be spring loaded both ways..
if its cold it should snap closed with spring pressure,,
if hot it should be held open with spring pressure..
  #13
Old 05-04-2017, 05:12 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Thanks I'll look into a Choke cap.
  #14
Old 05-04-2017, 05:22 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
maybe if you can do some pics, we might be able to see something..
yea maybe pull the black cap back off and see if the spring and linkage tang are lined up??
  #15
Old 05-04-2017, 05:27 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
I had it off 2 days ago and put it back together. I'm not sure how to show the spring over the tang, but I'll see what I can do. Thanks again for the help.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Opinions on Holley Street Avenger 670 jpmdaddy Performance Modifications 59 09-03-2012 05:34 AM
Holley Street Avenger sell or trade Jack_K Parts for sale 8 06-21-2011 07:30 AM
Holley 670 Street Avenger Carb razor376 Parts for sale 1 03-26-2011 08:07 PM
Holley Street avenger and dual plane intake problem???? thomas8408 Engine Topics 0 11-03-2005 03:21 PM
570cfm Holley Street Avenger Carb mojowrkn Parts for sale 3 03-23-2005 05:09 AM
