Intake Manifold Help needed - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-25-2017, 10:11 PM
MMRC Trucking's Avatar
MMRC Trucking MMRC Trucking is offline
Junior Member
Twisted Wrench
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 77274
MMRC Trucking will become famous soon enough
Garage
Default Intake Manifold Help needed
I am needing to replace my intake manifold (self inflicted damage) I am a rookie at this so please go easy on me lol. The manifold on it now is an Edlebrock. Though I can't seem to find a model number on it. I would like to replace it with the same style. I am not to familiar with the terminology.(single plane, dual plane, air gap etc) I am reading while looking to replace it. This is for a 402 BB.
Old 02-26-2017, 05:24 AM
JKCamino's Avatar
JKCamino JKCamino is offline
Deputy Director Region 19 Owner of the KLRMino
Year: 1973
Region: 19(AK,ID,OR,WA)
NECOA #: 5944
JKCamino is a name known to all
Garage
What's wrong with the intake now?
1973/75 Custom Laguna S3 El Camino COPO Replica AKA Killer AKA (KLRMINO)
Old 02-26-2017, 05:58 AM
stevesolo16 stevesolo16 is offline
Junior Member
Twisted Wrench
Year: 1967
Region: 18(CA)
NECOA #: 35450
stevesolo16 is an unknown quantity at this point
Your best bet for street use is Edelbrock dual plane RPM manifold. Call their Tech Support and they'll walk you through it.
Single plane manifolds are mostly for high-performance applications.
Old 02-26-2017, 08:49 AM
gilby's Avatar
gilby gilby is offline
Year: 1974
Model: El Camino Classic
Region: 18(CA)
NECOA #: 10426
gilby has a reputation beyond reputegilby has a reputation beyond repute
Garage
..yea, ..on those Big block, ya need to remove the valve covers.'cause the lip of the valve cover overlap the head a bit,but,just enought to make it kind of a pain in the butt.
..once the covers are off,then the intake manifold comes off easier..
..1974 Conquista
..1979 GMC Caballero
..2003 Impala
..2015 Spark
Old 02-26-2017, 10:16 AM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
welcome Michael
spread bore or square bore carb??
peanut or oval or square port heads??
do you need the heat riser or carb heat and choke heat??
edelbrock should have a number on it some where, look on the rear behind the carb??
JJ
Old 02-26-2017, 10:59 AM
Sano68 Sano68 is offline
Junior Member
Twisted Wrench
Year: 1968
Region: 18(CA)
NECOA #: 78034
Sano68 will become famous soon enough
I agree with Stevesolo16. That manifold is a great all around manifold. It will give you plenty of low end torque and plenty of mid power. Good luck!
Sent from my SM-G900V using Tapatalk
Old 02-26-2017, 03:12 PM
Junior Member
Twisted Wrench
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 77274
Garage
Well I broke a bolt removing the thermostat housing. The while using a cheap easy out set I broke the tip of the extractor in the bolt. Tried to drill that out and just ended up destroying it.
  #8
Old 02-26-2017, 03:15 PM
Junior Member
Twisted Wrench
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 77274
Garage
Trying to figure out how to do pictures here. Ill give this a try.
It is a single square hole where carb mounts.
  #9
Old 02-26-2017, 03:16 PM
Junior Member
Twisted Wrench
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 77274
Garage
thank you
  #10
Old 02-26-2017, 03:19 PM
Junior Member
Twisted Wrench
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 77274
Garage
http://share.photobucket.com/sharepr...php?id=NjAxMTE
  #11
Old 02-26-2017, 03:21 PM
JKCamino's Avatar
Year: 1973
NECOA #: 5944
Garage
I'm sure it can be repaired at little to no cost, step 1 is removing the intake so you can work on it easier.
Well you sure did a number on it, lol hard to tell but it still could be repairable and not a total loss.
  #12
Old 02-26-2017, 03:41 PM
Junior Member
Twisted Wrench
Year: 1968
Region: 18(CA)
NECOA #: 78034
BTW...... there's 2 Torker manifolds. A Torker and a Torker II. Yours looks like an original Torker.
  #13
Old 02-26-2017, 04:32 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
that is a very short [low profile] single plane non-airgap manifold,,
square bore,, not sure if it has a heatriser or not..
looks a lot like the "Torker II" maybe a 2.0 ?? there were different makes/numbers..
look on the rear for the name..
get the head casting number, that will tell what kind of port they are..
  #14
Old 02-26-2017, 05:31 PM
me7824's Avatar
me7824 me7824 is offline
Year: 1983
Region: 13(TX)
NECOA #: 56026
me7824 has a spectacular aura about
Garage
That can be fixed. Find a good machine shop in your area. Less than the cost of a new one I'm sure, good luck.
John 3:30
He must increase. I must decrease.
  #15
Old 02-26-2017, 09:43 PM
Junior Member
Twisted Wrench
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 77274
Garage
thank you all for your help. Turns out it is a Torker II 2.0
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Looking for an intake manifold TWY Engine Topics 12 07-12-2016 11:56 AM
intake manifold blieske Wanted Items 0 11-27-2012 12:47 PM
intake manifold astro932 Engine Topics 5 09-23-2012 07:41 PM
Intake Manifold texasjim Engine Topics 7 06-16-2011 09:38 AM
Intake Manifold SoSlowSS Performance Modifications 35 12-31-2004 03:32 PM
