Cracked Windshield. - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-18-2017, 02:34 PM
knappyfeet's Avatar
knappyfeet knappyfeet is offline
Motor Mouth
Year: 1972
Region: 18(CA)
NECOA #: 33594
knappyfeet will become famous soon enough
Default Cracked Windshield.
Just noticed this crack today while cleaning.
Has antenna in it. I haven't bothered to check yet but are these still available at the local windshield replacement place?
Sent from my SM-T900 using Tapatalk
Old 03-18-2017, 03:08 PM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
sometimes it depends on if they have tinted and shaded glass,, w/wo antenna and what you want..
most places can order one the way you want it..
https://www.opgi.com/searchpart.asp?...ord=windshield
a search
http://www.bing.com/search?q=windshi...ASU2JS&pc=EUPP_
JJ
Old 03-18-2017, 03:16 PM
Sampoerna415's Avatar
Sampoerna415 Sampoerna415 is offline
Motor Mouth
Year: 1972
Region: 14(AR,LA,MS)
NECOA #: 77945
Sampoerna415 will become famous soon enough
Garage
You could also try to get it fixed with that windshield crack repair liquid, never tried the stuff myself so I'm not sure how good it works, but hey it's broken anyway good time to experiment! https://www.amazon.com/Permatex-0910.../dp/B000ALJ4MY
Old 03-18-2017, 04:00 PM
78 Elk's Avatar
78 Elk 78 Elk is online now
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is just really nice
a search
X2 yes you should be able to order a replacement.
hagensen78
Old 03-18-2017, 04:45 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
letting the glass shop order the windshield may be cheaper sometimes,,
if it comes in broke, let them deal with shippin back and forth..
it may be a little higher up-front price sometimes too tho,
check around with different shops, do some shopping..
if you have never replaced a windshield??
I recommend asking if you can watch the first time, and let the glass shop do it..
Old 03-18-2017, 08:10 PM
cyberray cyberray is offline
Year: 1978
Region: 13(TX)
NECOA #: 22854
cyberray is a glorious beacon of light
I would also recommend going to a swap meet. They usually have a glass supplier show up and you can check to see if they stock anything like what you are looking for.
Old 03-19-2017, 12:23 AM
HKDUP87's Avatar
HKDUP87 HKDUP87 is online now
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 has a brilliant future
Garage
I bought a new windshield with tint installed at Ecology Auto Wreckers in Santa Fe Springs Ca. $135.00 there's a guy in the parking lot that does nothing but windshields. I went inside to get what I wanted and he had already went and picked up the windshield and installed it in less than 2hrs. I think it's pick a part now but he's still there.
(this post was written by a well used crash test dummy, on a closed course. No armadillos were harmed in the making of this post. Your mileage may vary. If you have a stiff upper lip lasting more than four hours, seek medical assistance. Reading this post may cause bleary eyes in men over 50, and is known to cause a significant reduction in brain cells....)
Knowledge before $$$$ is my new philosophy!!!!!!
  #8
Old 03-19-2017, 01:36 AM
elkybuick's Avatar
elkybuick elkybuick is offline
Elkybuick
Year: 1980
Region: 6 (FL)
NECOA #: 19948
elkybuick will become famous soon enough
Garage
If you buy a windshield and have a shop put it in if it cracks on the way in you bought it if they furnish it and it cracks they bought it.
ElkyBuick
1980 El Camino
1973 Buick Riviera
Air Force Veteran
  #9
Old 03-19-2017, 02:57 AM
BAS-Sr's Avatar
BAS-Sr BAS-Sr is offline
Year: 1968
Model: El Camino SS
Region: 3 (DE,NJ,PA)
NECOA #: 8673
BAS-Sr has a spectacular aura about
Garage
http://uploads.tapatalk-cdn.com/201...b8503dd0ab.jpg
I replaced the windshield in my '68 last year, all '68 thru '72's fit each other, so I used a tinted with antennae in it (the '68 was a radio delete). I ordered it, cost $180. The first one came cracked, but the company shipped out a second one immediately and there was no charge to me for the second one, all I had to do was take pictures to show damaged one.
When I got my '68 it needed to have the original windshield seal replaced, came from Utah, seal was dried out and leaked, so I had to take it out anyway. Decided to replace it with a new one with the built in antennae.
All in all, not too bad a job, worked out well!
'68 el Camino SS 396/325 hp, 4 Speed, 3.31, Buckets, AC, Black on Black
'72 el Camino SS, 454 LS5, 4-Speed, 3.73 Eaton LSD, AC, Buckets
'75 el Camino SS, 400 SB, 200R4, 3.42 LSD, AC, Swivel Buckets, PW, PDL
'87 el Camino Choo Choo SS (305 TPI, 200R4, 3.73 LSD)
'87 Buick GN Hardtop
  #10
Old 03-19-2017, 03:09 AM
BAS-Sr's Avatar
Year: 1968
Model: El Camino SS
NECOA #: 8673
Garage
Just checked the records, the new windshield was $169 shipped, came from AutoCity.
  #11
Old 03-19-2017, 08:37 PM
knappyfeet's Avatar
Motor Mouth
Year: 1972
Region: 18(CA)
NECOA #: 33594
Thanks guys for all the help......sincerely appreciated. It's nice to find out these windshields are more readily available than I initially thought.
This has been a year of "firsts" for me..........in that I did things for various projects that I never before attempted.....and they all went well. I'd love to por15 that nasty, dirty area in the picture prior to a windshield being installed.
In a side note my old girl doesn't get out as much as she deserves. Last time out was a trip to the dmv for a motorcycle transfer about 2 months ago and 2 miles away. Before that a Halloween cruise night a couple of days before Halloween. So this weekend......crack and all we spent the weekend using it with a saturday night cruise around San Diego and today a leisurely spent day along mission bay. I'm now motivated to finish some things on it I've been putting off.
Forgot to ad.........I love spending time just strolling ecology even when I really don't need anything
  #12
Old 03-19-2017, 08:52 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
I bought mine from The Parts Place, $179.00 but paid for shipping also. It came in a massive box that was really packed for protection. Had a local glass guy remove the old one, but installed the new one and back window myself, with no problems. Getting the old one out was something I didn't want to deal with, so for 30 bucks I had it removed....
  #13
Old 03-19-2017, 09:11 PM
Old Bear's Avatar
Old Bear Old Bear is offline
Site Contributor
Name: Gale and his cats
Year: 1970
Region: 18(CA)
NECOA #: 38617
Old Bear has a brilliant future
Garage
"we spent the weekend using it with a saturday night cruise around San Diego and today a leisurely spent day along mission bay"
No that's a nice weekend!
  #14
Old 03-20-2017, 07:22 AM
Chris Nelson Chris Nelson is offline
Year: 1986
Model: El Camino SS
Region: 6 (FL)
NECOA #: 16658
Chris Nelson will become famous soon enough
If you lived in Florida the state makes the insurance companies pay for new windshields , if you carry collision insurance , no deductible on windshields . I guess the state don't want anyone driving around with cracked windshields . I know a lot a people who have done this here . Check with your insurance company . Too bad they don't do that with all the glass .
  #15
Old 03-20-2017, 07:42 AM
BAS-Sr's Avatar
Year: 1968
Model: El Camino SS
NECOA #: 8673
Garage
Quote:
GOOD point Chris!
I forgot that a few years back, I cracked the windshield on my '87 Choo Choo while working in the garage. I checked with the classic auto insurance, they ended up covering a new windshield "INSTALLED" fully. I had too pay for the windshield and installation out of my pocket ($20 and then sent in the receipt, got fully reimbursed!
You should check with your insurance to see what they say?
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Cracked! I mean the plastic. dntknwhw2b Interior Restoration 2 05-07-2012 07:12 AM
Cracked Dash? Big Fella Interior Restoration 7 03-29-2012 05:08 PM
cracked at top of windshield and top of truck SAcamino Body Restoration 6 09-18-2009 04:53 PM
Dash cracked 87 ridgeline Interior Restoration 10 04-12-2008 06:50 AM
cracked dash rod123 Interior Restoration 2 12-26-2004 08:05 PM
