Printed circuit board for 72 ss guage cluster - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Body & Chassis > Electrical Systems
Old 03-20-2017, 04:21 PM
filthyrich's Avatar
filthyrich filthyrich is offline
Member
Loose Nut
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 68370
filthyrich will become famous soon enough
Garage
Default Printed circuit board for 72 ss guage cluster
Anybody know where the part # is on a 72ss elco ?. And do you have to pull it to see it. ?
Old 03-20-2017, 05:14 PM
xlchjoe's Avatar
xlchjoe xlchjoe is online now
Site Contributor
Year: 1971
Region: 3 (DE,NJ,PA)
NECOA #: 52961
xlchjoe is a name known to all
Garage
Quote:
Have to pull da cluster.
ID:	73769   Click image for larger version
And I will not be commanded
And I will not be controlled
And I will not let my future go on
Without the help of my soul
71 Camino
02 Z28
03 Blazer
11 Vette
11 Fatboy
Old 03-20-2017, 05:46 PM
filthyrich's Avatar
Member
Loose Nut
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 68370
Garage
Default Circuitboard
Ugh, wish I would have seen it while I had It out.
stinking speedo cable was a b****, now
I'm having problems with a few things and I think it's the circuitboard.blinkers don't light up on the dash no mo everything else is good, allready tried new lamps and holders,just wanna get the
Correct part, I hate after market crap.
Thought about conductive paint repair but
It's pretty old and something else will just happen, has anyone tried the after market ones from ecklers or restoparts ?
Any reviews. Good , bad ? Let me know if ya got any info. Thanks in advance
Old 03-20-2017, 07:05 PM
O52's Avatar
O52 O52 is offline
Year: 1970
Model: El Camino SS
Region: 18(CA)
NECOA #: 22875
O52 is a glorious beacon of light
Garage
The trick for the speedometer cable is to disconnect it from the transmission, pull up the slack through the firewall and attach it while you still have access to the back of the cluster. Give it a good pull to make sure its connected, and spin the cable from below to verify operation. As you push the cluster/dash assembly back into place the cable will feed back down towards the transmission.
Ed
70 El Camino SS
Old 03-20-2017, 08:54 PM
filthyrich's Avatar
Member
Loose Nut
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 68370
Garage
My problem was putting it back on. When i pulled out the cluster the first time the inner cable was stuck to the speedo and pulled away from the tranni which didn't
Work after I had a bear of a time putting the outer housing back onto the cluster after the cluster was in place.almost impossible but I did it finally, then had to remove the outer cable at the tranni and easily put it back in place then the speedo worked again. do you think I can just disconnect at the tranni only,without having to remove it from the cluster at all without tweaking the cable ? Cuz I had to pull it out upward
Cuz I didn't want to pull the hole dash forward
Which would be a lot more work. Are you saying you think it can be carefully finnesed up and out without removing the cable from the cluster at all ?
Old 03-21-2017, 02:33 AM
xlchjoe's Avatar
Site Contributor
Year: 1971
NECOA #: 52961
Garage
Did some searching of old emails. I replaced my circuit board in mid '15 and have had no issues. Maybe same supplier still out there?...
May try to drop him a line?... You sent a payment of $59.95 USD to Hi Tech Classics (sonnie244@yahoo.com)
Hi Joe - Order confirmed. eBay will update you when your order ships to 2701 Lynne Ave.
PAID : $59.95 with Paypal
Free shipping.
View order details
70 71 72 1970-1972 CHEVELLE SS EL CAMINO MONTE CARLO CIRCUIT BOARD GAUGE CLUSTER
Estimated delivery: Sat. Jun. 6
Item Id: 371336028964
Old 03-21-2017, 04:01 AM
M Zeigler's Avatar
M Zeigler M Zeigler is offline
Year: 1972
Model: Sprint
Region: 16(CO,MT,WY,UT)
NECOA #: 17119
M Zeigler will become famous soon enough
Garage
I bought a new circuit board for my Sprint from NPD when I put a Monte Carlo dash in it, everything works and the price was decent.
Mike
  #8
Old 03-21-2017, 06:44 PM
O52's Avatar
O52 O52 is offline
Year: 1970
Model: El Camino SS
Region: 18(CA)
NECOA #: 22875
Garage
I can't see how you can replace the circuit board without pulling the dash out at least at 3 or 4 inches. Replace the upper mounting bolts at the ends with 6" long studs to hold the dash in place. Keep the center section supported, thats it's weakest point. You can leave the speedo cable attached if you disconnect it at the trans and loosen any hold down clamps. I pulled the cable up a few inches which is all I needed. No binding at all.
If you buy a new circuit board, make sure you get the right one for your application, gauges or warning lights.
  #9
Old 03-21-2017, 11:22 PM
filthyrich's Avatar
Member
Loose Nut
Year: 1972
Model: El Camino SS
Region: 18(CA)
NECOA #: 68370
Garage
Thanks, That's what I wanted to hear.last time it didn't matter cuz I was after the stock
Clock to send out for repair, so the cluster was coming out anyway. clock doc
On line as I would rather have a stock part than an aftermarket part any time.
Thanks again .
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Printed circuit board for 72 ss guage cluster filthyrich General BS Topics 1 02-22-2017 06:55 PM
1981 Printed Circuit Board??? SOONERFAN Wanted Items 1 08-29-2016 07:18 AM
76 SS Printed circuit board f3nderbass Wanted Items 0 09-21-2011 01:39 PM
Printed Circuit Board vmccall399 Electrical Systems 4 01-03-2010 08:40 AM
Printed Circuit Board? 87SS Electrical Systems 33 05-09-2004 05:01 PM
