Burning smell - El Camino Central Forum : Chevrolet El Camino Forums
Old 09-10-2011, 11:13 AM
elcaminothepathway's Avatar
elcaminothepathway elcaminothepathway is offline
Year: 1984
Region: 11(IA,NE,ND,SD)
NECOA #: 17741
elcaminothepathway will become famous soon enough
Default Burning smell
I need help!! Every time I start my elky I have a burning smell it doesn't smell like oil or anything I have ever smelled before. Only happens in the first 5 min or running or so. The closest thing I can compare it too would be a burning belt. All my belts are tight and cannot see any signs of abnormal wear on any of them. I don't know where else to look or what to look for. Thanks for the help.
84 El Camino, restored. . . someday.
76 Scottsdale heavy half truck, seen all 49 drivable states thanks to my uncle.
Old 09-10-2011, 12:39 PM
goodcruiser goodcruiser is offline
Year: 1982
Model: Caballero
Region: 18(CA)
NECOA #: 17105
goodcruiser is a glorious beacon of light
When you first start it up you have the burning smell then it goes away?
Does it do it everytime when you start it up or only when cold?
What engine do you have?
Check to make sure the smog pump and the A/C are not binding up at initial start up.Be sure to try it without the A/C turned on to see if you still have the smell.
This one could be a bear to find as we're gonna need to accumulate some more info to eliminate possibilties.
Can you tell if the smell is coming from the engine compartment or is it coming from the inside of the cab?Can see any smoke even the smallest wisp would help you find where to look.
Old 09-10-2011, 01:59 PM
Marv D's Avatar
Marv D Marv D is offline
Year: 1967
Region: 15(AZ,MN)
NECOA #: 13944
Marv D has a reputation beyond reputeMarv D has a reputation beyond repute
Electrical maybe???
Take a REAL close look at the grounds between the engine and the battery. There is good reason the factory grounding scheme went ... battery to engine.... then engine to firewall and engine to frame.
I had a young man with a similar smell and all of a sudden the factory console shifter was acting 'sticky'. With the ground moved ftom the alternator bracket to the frame (to make it look better he said),, he was grounding the engine 100% through the shift cable. The shift cable was getting so hot it melted the teflon cable liner.
Just a thought.....
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.....
I just finished reviewing my social security statement and thanks to the current administrations handling of my SS funds,,,, I only have to work until noon on the day of my funeral
Old 09-10-2011, 02:44 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
"making it look better" doesn't seem to help these cars run any better.......and all that "stuff" was installed for a reason.....
Old 09-12-2011, 02:18 PM
Year: 1984
NECOA #: 17741
Its mostly when it is a cold start up however it does happen when its hot sometimes. I start it with a/c on and off, still smells the same. I have a 305 in it, all stock. I think the smell is coming from the engine, because if I start it up and don't run the air or vent and its not as strong, However if I start running the vents or a/c it gets stronger. I understand that could be moving the smell around and making it stronger but it makes me think it is coming from the engine compartment. I think that answers most of the questions. I will look at the electrical if I see anything abnormal I will report it but I don't know exactly what to look for. Thanks for the suggestions and thanks in advance.
Old 09-12-2011, 02:50 PM
just plain john just plain john is offline
Year: 1981
Region: 13(TX)
NECOA #: 11645
just plain john will become famous soon enough
A/C clutch?
Turbo Buick/Grand National powered
Old 09-12-2011, 02:52 PM
Year: 1984
NECOA #: 17741
What would indicate that it would be an A/C Clutch?
  #8
Old 09-12-2011, 03:00 PM
Year: 1981
Region: 13(TX)
NECOA #: 11645
They're usually very noisy and/or drag the belt. Does the clutch engage easily? I'm just throwing ideas out there, it's hard to diagnose a smell when you can't smell it
  #9
Old 09-12-2011, 03:05 PM
Year: 1984
NECOA #: 17741
I understand it is hard to diagnose. I don't often turn on the a/c. I suppose it could be it is rather noisy when it engages. (kinda one of the reasons I have never used it much) If it is the a/c clutch and it has been bad for awhile why has it just started smelling now? How much is it to replace an a/c clutch on an 84 with a 305?
  #10
Old 02-21-2017, 09:30 AM
DonGrinter's Avatar
DonGrinter DonGrinter is offline
Junior Member
Member
Year: 1984
Region: 18(CA)
NECOA #: 77937
DonGrinter will become famous soon enough
Default Having this same Issue
I just bought a 84 and unfortunately, I'm having this same issue. Did you ever resolve this issue? If so, what was it and how much did it cost to fix?
  #11
Old 02-21-2017, 10:25 AM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
welcome Don/Jordan
Jim hasn't logged-in in over a year, so we may never know??
if the smell comes out of the AC vents, maybe check the blower motor too..
JJ
  #12
Old 02-21-2017, 11:22 AM
gilby's Avatar
gilby gilby is offline
Year: 1974
Model: El Camino Classic
Region: 18(CA)
NECOA #: 10426
gilby has a reputation beyond reputegilby has a reputation beyond repute
Garage
..maybe ya pick up a plastic bag off the road and got hung up on the exhaust pipe.!..did ya see any signs of anything that might have melted on the pipe?
..1974 Conquista
..1979 GMC Caballero
..2003 Impala
..2015 Spark
  #13
Old 02-21-2017, 11:50 AM
cffisher's Avatar
cffisher cffisher is offline
Member
Knuckle Buster
Year: 1980
Model: Caballero
NECOA #: 75850
cffisher will become famous soon enough
Just a thought here. When you turn on your defroster your A/C comes on. So check the blower motor and the clutch. Could you start the car with the hood open and see if you smell it.. Start the car and look at the engine bay right away to see if anything is smoking?
  #14
Old 02-21-2017, 02:16 PM
xlchjoe's Avatar
xlchjoe xlchjoe is online now
Site Contributor
Year: 1971
Region: 3 (DE,NJ,PA)
NECOA #: 52961
xlchjoe is a name known to all
Garage
I would also check da battery cable to starter. May be coming apart internally and burning da outside jacket from within. Pop da hood then start it then go feel cable to see how warm it is.
And I will not be commanded
And I will not be controlled
And I will not let my future go on
Without the help of my soul
71 Camino
02 Z28
03 Blazer
11 Vette
11 Fatboy
  #15
Old 02-21-2017, 02:29 PM
old goat's Avatar
old goat old goat is offline
Year: 1985
Model: Conquista
Region: 10(IL,MN,WI)
NECOA #: 23551
old goat is a name known to all
Garage
Question
Missing any cats? Good luck!
Old Goat
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Does anyone know of a free dvd burning softwear El Big Joe General BS Topics 3 10-27-2007 11:49 PM
Burning question about ECM Kaballero Electrical Systems 0 02-25-2007 07:16 AM
burning up ignition modules 84camino305 Ignition Upgrades & Discussion Forum 13 01-22-2007 05:05 PM
Burning Smell when on fast Idle! eightysix Engine Topics 6 12-19-2003 12:14 PM
burning oil Matt Engine Topics 5 05-27-2003 10:36 AM
