mini-tub, tub, or nothing - El Camino Central Forum : Chevrolet El Camino Forums
Old 06-28-2005, 02:23 PM
hicotton02 hicotton02 is offline
Member
Knuckle Buster
NECOA #: 1403
hicotton02 will become famous soon enough
Default mini-tub, tub, or nothing
Hello everybody! Its been a while since i made a post. anyway, i have been working on a 700hp engine for a while. well im taking a break from it and focusing on getting the power to the ground. how fat of tires (approx.) will i need to hook? if they are slicks. 3.73 gears and limited slip 12 bolt is what i have for rear end. i am going to do eaither a ladder bar or a 4 link when i decide what im doing with the chassis. I am prepared to minitub or tub if needed. Tell me what ya'll think.
1975 El Camino Classic 383/TKO-600
1953 F100 239 Flathead
2002 GMC 2500HD 6.6/Allison
real enthusiasts don't discriminate between domestics and imports!
Old 06-28-2005, 04:45 PM
Supercharged 86 Supercharged 86 is offline
Year: 1986
Model: El Camino SS
Region: 3 (DE,NJ,PA)
NECOA #: 3474
Supercharged 86 will become famous soon enough
You might be able to get away with 10.5" slicks with no tubbing depending on how low you want the car in the rear. I can't wait to see this thing when it's done! Are you going to lighten it up any?
-JOHN
Old 06-28-2005, 11:20 PM
Member
Knuckle Buster
NECOA #: 1403
probably not as a matter of fact it might get heavier. I'm told with this power i might want to look into a cage. also a back half possibly. I want this car to have a nice low aggressive stance. maybe with a little rake. This is what im thinking about on the tires. get enough footing so it can hook up off of the line. then, using the same size tires but street, drive it around town.
Old 09-15-2005, 10:00 PM
carterkraft carterkraft is offline
Junior Member
NooB
Year: 1982
Model: Conquista
Region: 13(TX)
NECOA #: 5318
carterkraft will become famous soon enough
If you really are making 700 hp then you are gonna need some tire, 10.5 min, unless of course you are nuts
Go with the 4-link instead of the ladder bars, the take some time to setup but the effort is well worth it.
I would put in at least a 6 point bar, 4 in cab and 2 in the bed.
I have some full tub 8 point pics.
82' Conquista, 12 point cage, Chris Alston 4 link, Moser 9", 32*14.5" slicks.
Soon to be blow through turbo'd 406 sbc
"Of course it's a street car"
Old 09-27-2005, 09:14 AM
STARFIRE350 STARFIRE350 is offline
Member
Knuckle Buster
NECOA #: 4622
STARFIRE350 will become famous soon enough
if your going to back half go 4 link. also a cage is always a good idea even with lower horse power than that
Old 09-27-2005, 05:16 PM
dennis68 dennis68 is offline
NECOA #: 2629
dennis68 will become famous soon enough
What are your intentions with the car? Charlie's Camaro (The Mule) makes way over 1000HP and he runs around on 10" wide street tires. If you want to drag race and are interested in 60' times than a minitub and some 10.5 slicks with a 4-link are the way to go. If you want the g-machine route stay away from the 4-link or ladder bars and look into some 285/40R17 (or equivalent in your wheel size) Nitto 555R's, they hook really well.
Old 09-28-2005, 06:53 AM
Member
Knuckle Buster
NECOA #: 4622
that camaro is special built and he spent alot of money including corvet front end. and currie rear do you know that guy that owns the mule? It broke down on the power tour and was in the dealership I worked at and I got a verry good look at that car inside and out its a realy nice car and at that time the engine builder said is made 1200 plus at the rear tires and when the tour was over they had plans to turn up the boost! 8O
  #8
Old 09-28-2005, 04:48 PM
NECOA #: 2629
Yes, I know Charlie and Mark (the builder). There is nothing special about the front suspension, typical after market add-ons for a PT style car.
Even the rear is a simple 4-link conversion (designed and marketed by DSE, a company of Kyle Tucker).
Yes, the power train is capable of more but at it's current tune of ~1000RWHP he is plenty happy with it.
Not sure what bearing that has on the thread though....other than to reiterate what I have already stated.
  #9
Old 09-29-2005, 06:52 AM
Member
Knuckle Buster
NECOA #: 4622
well they said it was c5 front I was verry inpressed with the car they said it was 1200 so I have no other info on the car but what they said as far as pertaining to this thread I was just making conversation You obviously know more about the car and owner than I do sorry to have bother you with my banter
  #10
Old 09-29-2005, 05:00 PM
NECOA #: 2629
No bother and I didn't intend any ill feelings, just adding some facts to the thread about this car.
The car uses C5 hubs via modifies spindles (which ATS is launching an aluminum version of this year that will fit El Caminos). The arms are tubular but nothing fancy about the geometry or mounts.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
mini spool 80_elco410 Transmission & Drive line 1 06-04-2008 05:38 PM
Mini-Spare EdRichardson Suspension & Steering 0 04-27-2008 07:26 PM
this mini cooper evil6boy General BS Topics 1 01-18-2008 06:09 PM
Mini Tub VS Tub El Corvino Transmission & Drive line 0 04-28-2007 02:54 PM
Anyone mini tub a 5th gen? Rob Kozak General BS Topics 1 04-19-2004 09:17 PM
