Suggestions on how to clean a coolant overflow bottle. - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Body & Chassis > Detailing
Old 07-09-2005, 04:23 PM
a73elkyss a73elkyss is offline
Year: 1973
Model: El Camino SS
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 768
a73elkyss will become famous soon enough
Default Suggestions on how to clean a coolant overflow bottle.
I have an overflow coolant bottle that has yellowed over the years. Nobody makes a reproduction and the last NOS one on eBay went for over $100 dollars!
Any ideas on what product I could use to clean it up?
JW - NECOA #768 2011 El Camino SS -
Watch for the 6th gen Elco's
Old 07-09-2005, 05:35 PM
Bowtie's Avatar
Bowtie Bowtie is offline
Year: 1984
Region: 4 (MD,VA)
NECOA #: 4669
Bowtie will become famous soon enough
Default Iron-Out
If the plastic has actually yellowed, it is due to UV over time and nothing will restore it to new color. However, often a big part of it is from water contaminants built up over time and that can be addressed to a degree.
Aside from a thorough cleaning, I have had good results with a product called Iron-Out. It attacks iron stains like nothing else I've ever seen. It's great stuff. It is also used by folks on well water to get clothes really white and as a chemical in water treatment systems amoung other uses.
The only other partial solution I know of is bleach. Be aware though, too much bleach will actually shorten the life-span of the plastic. Be prudent.
Let us know how it turns out.
Take care.
Always a pleasure.
84 Elky TPI
No results plus excuses still equals no results.
Old 07-09-2005, 06:31 PM
Year: 1973
Model: El Camino SS
NECOA #: 768
Thanks Bowtie. I'm going to try the Iron-Out first and hope that works out. I thought of the bleach, but was not sure what it would actually do to the plastic. Thanks for the caution on that.
I'll update as soon as I get some results. Now to hunt down the Iron-Out...
Old 07-09-2005, 07:22 PM
Bowtie's Avatar
Year: 1984
Region: 4 (MD,VA)
NECOA #: 4669
Default No problem
Jay,
Not hard to find. Wal-Mart, Lowe's, etc. Mix a hard solution and let it soak in it for even a full day or two.
Sometimes I remind myself that the life expentency on most of our crucks was only expected to be less than 10 years. The quality of the rubber and plastic reflects it.
As a piece of trivia, the average licensed life expentancy of a Vette is still less than 8 years. While the average life of some other marks is 30+ years.
Take care.
Old 07-09-2005, 08:17 PM
Year: 1973
Model: El Camino SS
NECOA #: 768
Thanks Greg. I'll pick some up tomorrow.
How true, how true. Unreal how brittle and faded some of the plastic and rubber get. Can't tell you how many times I've just barely touched a piece of rubber and it would just crumble in my fingers.
I've had to learn to be very carefull around certain parts of the Elky.
Thanks again.
Old 07-09-2005, 10:06 PM
szonk's Avatar
szonk szonk is offline
Year: 1985
Model: El Camino SS
Region: 6 (FL)
NECOA #: 5244
szonk will become famous soon enough
Default life expectancies...
In my opinion, it is absurd to set life spans for any vehicle as there are too many variables but, one thing is for sure; how the owner ( especially the first one !) takes care of it is the #1 determining factor on how long it will last and/or it will look like after 10 or 20 yrs. Having a garage helps a ton also. One thing about older Chevys is the use of too many plastic clips that hold trim pieces that are famous rust starting areas wich is why a good repaint helps a bunch. That gives you a chance to remove everything that is clipped, screwed and or glued and deep prime every nook and cranny
Chillin in Lauderdale
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Coolant Overflow in my1972 Elky compmaker Performance Modifications 6 08-04-2016 08:54 AM
Coolant overflow tank replacement LeoC2 Engine Topics 22 02-25-2009 07:53 PM
5th gen window clean bottle lowdown Parts for sale 0 01-23-2006 03:12 PM
Coolant bottle painted. Opinions wanted. a73elkyss Detailing 15 11-04-2005 06:07 PM
"Boiling" overflow coolant tank da bob Engine Topics 6 06-18-2005 12:43 AM
