The G-Machine craze is hot! Pick up any issue of PHR (popular hot rodding) mag and you will see some beautiful classic rides that now handle the curves better than ever.
I want to go with bigger wheels on my '70. I'm running 15-8 1/2's Americans front and back with 235-15's in front and 265-50's in the rear. I would like to go to 17 8's in front and maybe with the correct backspacing a 17-11 in the rear. Of course having the widest tire that will tuck in without rubbing. I don't want to mini tub. Anyone test or pushed the limits in wheel/tire size with a 3rd gen elky? Here is the wheels I want to use...The "new" 200s just out by American with painted centers to match my old 15" wheel scheme I have now.
70 ElCO |
| Sponsored Links | ||
Advertisement | ||
402-Custom 17x11 5.25-8.0
This is the backspacing you have to work with. I think the wheel is too wide. John
72 SS 454/700r4 (A real SS that got a 454 along the way) To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
Talk to Dennis68. I think he's running 300+ tires in the rear with no problems. I like some HRE wheels and even the ASR-1s I see in TireRack ads all the time with the painted centers and polished/chrome lips. They're pricey though and don't always fit the looks of certain cars. Have you been to Pro-Touring.com? They'd probably have quite few suggestions for you.
-JOHN To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
Hey thanks, I will check out that site. Will contact Dennis also as we are both in the bay area.
The 17-11's in the rear is an extreme. I do think the 9-1/2 17's in the R are more realistic. |
When you do decide to buy, check out this site.
It is the cheapest I found for the Torque Thrust II's I put on my 72. www.newstalgiawheel.com John |
Thanks for wheel site tip John! Very nice!
When am I buying? Good question as I still have to explain to my wife why I need new wheels when there is nothing wrong with the ones I have. Then I have to tell her I also need tires for the up-grade in wheel size....I think I have a little time! |
Just be blunt with the wife and tell her that your car is out of style and show her this pic of the latest trend in wheels.
John
#8
Ready to take the P-T jump? Get your wallet out; it’s as expensive as it is addictive. Of course after wheels you will realize that you need bigger brakes, and some suspension might not hurt either, then maybe a turbo or two, and…..
17X11's with 6" of b/s will fit no problem, the catch is tires. I have run 315/35's at 2-3 of drop with no problems, WITH THE REAR FENDER LIPS ROLLED. At my current ride height 315's get tore up. I am running 285's now and even under the most extreme conditions (wide open on a road course) there is no tire rub at all. Current drop is about 5" or so for reference. There is a whole bunch of room to be had in the rear on the outside fender well, most guys will cringe at this but if you remove the rear wheels and take a short 5 lbs sledge hammer to the outside fender well you can open it up a good inch or so with no affect to the outside sheet metal of the 1/4 panel. I was swinging pretty hard (tire clearance was more important than cosmetics) but it didn't make so much as a bow in the 1/4 panel. There are a couple from pt.com running 315's with no problems (they are all at about 2-3" drops). Wheel backspacing is the key, it has to be right at 6-6.25" |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| steering wheel upgrade options | Maximus84 | Interior Restoration | 27 | 10-08-2008 07:34 PM |
| steering wheel upgrade? | FWI | Interior Restoration | 4 | 01-16-2008 08:43 AM |
| Wheel and tire sizes help | hillcountry65 | Wheels & Tires | 0 | 01-29-2005 09:52 PM |
| Tire & Wheel upgrade | LINY | General BS Topics | 0 | 04-19-2004 08:09 PM |
| Tire/Wheel combinations for 5th Gen? | Robby85 | General BS Topics | 1 | 10-12-2003 07:05 AM |
