High Idle 383 Stroker w/ large cam, how can I lower the idle - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Drivetrain & Performance > Performance Modifications
Old 08-08-2005, 01:33 AM
El Camino 925 El Camino 925 is offline
Junior Member
Member
NECOA #: 5899
El Camino 925 will become famous soon enough
Default High Idle 383 Stroker w/ large cam, how can I lower the idle
I have a 383 Stroker with a large cam and the idle most of the time stays at 1500, turning the carb idle screw does nothing. Someone told me it is because the cam is so large and vacum causes that or something along those lines and cant be lowered due to the size of the cam. It causes the engine to diesel at times wen turned off which is bad.
Most V8s with large cams have a nice low choppy idle, why is mine so high? The timing is fine.
Any help or suggestions are highly appreciated!
'71 El Camino 383 Stroker 4 Speed Muncie
Old 08-08-2005, 06:07 AM
old_coot old_coot is offline
Year: 1983
Region: 9 (IN,KY,MI)
NECOA #: 3943
old_coot is just really nice
I don't know who you been getting your information from but you need to change sources. The reason an engine idles so rough with a big cam is that the carb gets a poor vacuum signal from the engine so the air/ fuel ratio is really inconsistant.
Now for your problem, there is only one reason for the engine to idle that high and that is that the engine is getting enough air in to run that fast. what you have to determine is from where-----is there something other than the idle screw holding the throttle open---like the A/C fast idle solenoid or more likely the fast idle cam part of the choke being sticky or an open vacuum line..........................Dan
Old 08-08-2005, 07:16 AM
78 Hot Rod Elky 78 Hot Rod Elky is offline
Year: 1978
Model: Black Knight
Region: 8 (OH,WV)
NECOA #: 850
78 Hot Rod Elky will become famous soon enough
Also check your secondary throttle plates, I have two carbs on mine and one was not closing causing the same problem TOO much air.
Old 08-08-2005, 09:39 AM
Mrapii's Avatar
Mrapii Mrapii is offline
Venerated Member
NECOA #: 2314
Mrapii has a spectacular aura about
Sure sounds like a vacumn leak. How do you drive the Elky with that high a curb idle?
1979 El Camino\r\n1955 Chevrolet Del Ray\r\n1962 Corvette\r\n1966 Corvette Coupe
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Trottle sticking and adjust high idle 79ElkyFl Engine Topics 1 06-14-2008 03:38 PM
High Idle - Help Diagnose Problem swimman Engine Topics 8 02-17-2008 10:07 AM
low idle COILED1 Engine Topics 2 04-28-2007 05:51 AM
Car will not idle 70SS454 Engine Topics 11 03-30-2006 04:15 PM
Idle too high NavarrePitcher14 Engine Topics 7 01-13-2005 08:30 PM
