Wiring Diagram for 1970 ElCamino please - El Camino Central Forum : Chevrolet El Camino Forums
Old 09-03-2005, 05:56 AM
UncleGusTurbo UncleGusTurbo is offline
Junior Member
NooB
Year: 1970
Region: 19(AK,ID,OR,WA)
NECOA #: 6061
UncleGusTurbo will become famous soon enough
Default Wiring Diagram for 1970 ElCamino please
Hello everyone I am new here. I just became the owner of a '70 ElCamino 350/350 car. I was hoping that someone could send a link to a full wiring diagram for my car. Please!!!!!!
UncleGusTurbo
DOHHHH!!!!!! I am sorry for posting a stupid question last night. It was way too late to be sitting here. I just noticed that the wiring diagrams listed second choice is '64-'88 not '64-'68.
Please don't put me in the yellow bus list.
UncleGus
Old 09-03-2005, 08:47 AM
JustBrits's Avatar
JustBrits JustBrits is offline
Member
Loose Nut
Year: 1970
Region: 10(IL,MN,WI)
NECOA #: 4593
JustBrits will become famous soon enough
Any diagram will do that for you, Gus!!
One prob is that so far, I have found that there are THREE DIFFERENT
Fron wirings. I have TWO '70s, both 350/350 with A/C and both are different 8O 8O 8O
One of the largest Loom re-manufacturer is VERY close to me and when I got the first /70 I visited them as I was having A/C switch and Resistor coil probs. The Lead Tech double checked and offered that the one they already had was different than mine !!
Got the new one (Dec. last year) and I found it was again different
So Good Luck!!!
PS: BTW, I do have several NOS Switches if anybody neds one.
Old 09-04-2005, 12:51 AM
Junior Member
NooB
Year: 1970
NECOA #: 6061
Default Thanks for the reply
It figures that they would have small differences. It's good to know that you have switches. I will definately keep that in mind. I am going to probably need a column or at least a shift collar as mine was beat up before I got the car by some scumbag thief. That is what I needed the wiring diag. for. Right now I'm making due with an aftermarket cheesy ign. switch under dash. That makes theft prevention pretty crappy.
My car too is a 350/350, A/C car. It is a little rough but an easily conquered project and I traded my '87 Nissan 4X4 4cyl truck for it!!
UncleGus
Old 09-20-2011, 11:12 AM
VIPGYM VIPGYM is offline
Junior Member
Member
Year: 1970
Region: 6 (FL)
NECOA #: 20294
VIPGYM will become famous soon enough
Default New owner 1970 el camino
I JUST PURCHASED A 1970 350 ELCAMINO AND NEED THE ENTIRE WIORING DIAGRAM SO I CAN REPAIR MULTIPLE PROBLEMS THAT OBVIOUSLY WERE JURY RIGGED BY A JACKASS BACKYARD BACKDOOR SELF PROCLAIMED MECHANIC. CAN SOMEONE HELP ME OUT WITH ANY TYPE OF WIRING DIAGRAM FOR THIS VEHICLE.
Old 09-20-2011, 12:01 PM
87next2last1's Avatar
87next2last1 87next2last1 is online now
Year: 1987
Model: Conquista
Region: 6 (FL)
NECOA #: 16317
87next2last1 has a reputation beyond repute87next2last1 has a reputation beyond repute
Garage
Welcome From Gainesville !!
Check this link
http://www.elcaminocentral.com/showthread.php?t=27190
1987 EL Camino Conquista 4.3L (My Car)
1984 EL Camino SS V8 (My Truck)
1983 El Camino V8 (My Toy)
Check them out on link Below !
Old 09-20-2011, 12:02 PM
goodcruiser goodcruiser is offline
Year: 1982
Model: Caballero
Region: 18(CA)
NECOA #: 17105
goodcruiser is a glorious beacon of light
Quote:
Look here for what you seek.
Old 09-20-2011, 02:13 PM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 has a brilliant future
Garage
Get the haynes repair manual #24020 from midway auto $16.00 plus frt.
1969-1987 This book is one of the best i 've ever seen. It contains every spec. offered for those years with step by step inst. and pictures. I'll post a couple to see how they come out.
(this post was written by a well used crash test dummy, on a closed course. No armadillos were harmed in the making of this post. Your mileage may vary. If you have a stiff upper lip lasting more than four hours, seek medical assistance. Reading this post may cause bleary eyes in men over 50, and is known to cause a significant reduction in brain cells....)
Knowledge before $$$$ is my new philosophy!!!!!!
  #8
Old 05-23-2012, 07:09 PM
Barry L Barry L is offline
Junior Member
Member
Year: 1970
Model: El Camino SS
Region: 18(CA)
NECOA #: 21839
Barry L will become famous soon enough
Default New guy with a turn signal problem
I have a 70 SS that developed a strange problem with the front turn signals. When I activate either left or right both dash indicators flash and both front turn signals flash at the same time. The rear signals work as they should.
I recently replaced the dome light and when installing the bulb I saw an arc. The fuses are good. Bulbs are good. Flasher module near the fuse box clicks when it should. No idea why the front lights and the dash both flash but the rear operates fine??
Could use some help if anyone can assist. Thanks.
  #9
Old 05-24-2012, 02:54 PM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
welcome BL
im not sure
could be a short between the 2 turn sig. wires up front, look for the blue and the lite blue wires,,
try to seperate them,, look for any spots rubbed thru on the insulation..
the rear lights are a different curcuit so turn signals can work with the brake lights on the same bulb..
heres the diagrams
http://www.elcaminocentral.com/articles/wiring/701.gif
http://www.elcaminocentral.com/articles/wiring/702.gif
hit the button in the electrical forum and start your own thread,,
you may get more answers..
JJ
  #10
Old 05-24-2012, 05:54 PM
hotcamino's Avatar
hotcamino hotcamino is offline
Name: Glenn "The Mayor"
Year: 1970
Region: 6 (FL)
NECOA #: 13525
hotcamino will become famous soon enough
Strange things happen when front turn signals have poor ground...I looked for problems for weeks, when I made new grounds for front turn signals ...TA DA...life is good.
That was easy
Post by:
Hotcamino
aka: "The Mayor", aka: Hot Rod, aka: Glenn
1970, 383 Stroker, 450hp
Jupiter Farms resident
  #11
Old 05-24-2012, 06:02 PM
hotcamino's Avatar
Year: 1970
Region: 6 (FL)
NECOA #: 13525
Best wire diagram period!
www.classiccarwiring.com
I have the 70/71 Chevelle-El Camino- Malibu laminated 11" X 18" full color.
Dirty fingure prints wipe off, you're gonna love it.
  #12
Old 05-25-2012, 01:42 AM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
x2 on the grounds G
your link had a extra ECC in it.. cool link.
http://www.classiccarwiring.com/
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
wiring diagram for 78' Kryp7ik Electrical Systems 4 12-31-2010 11:54 AM
1969 wiring diagram jock nz Electrical Systems 2 03-01-2007 11:20 PM
79 - 350 - AC wiring diagram JDHWFTX Electrical Systems 2 06-16-2005 07:53 PM
Wiring Diagram for 72? Gsir8 Electrical Systems 5 04-16-2005 09:00 PM
4th gen wiring diagram dwindham Electrical Systems 4 05-06-2004 10:54 AM
