Rear A6 bracket & vortec intake - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-01-2006, 09:46 PM
Sharp71's Avatar
Sharp71 Sharp71 is offline
Deputy National Director Participating Member
Year: 1971
Region: 18(CA)
NECOA #: 352
Sharp71 has a spectacular aura about
Garage
Default Rear A6 bracket & vortec intake
I have yanked the ol' stock 350 for a fresh 350/330HP crate.
One of the many little challenges of this project is mounting the A/C compressor onto the Edelbrock vortec style intake.
The rear A/C adjusting bracket used the middle two intake bolts on the old intake, but the new intake has NO middle bolts!
Anyone have an example of a fabricated bracket? Or better yet, an aftermarket supplier!
Danny
SHARP71 - NECOA #352
National Deputy Director
"Not all who wander are lost"
Old 02-13-2006, 08:14 PM
jayachtee jayachtee is offline
NECOA #: 6351
jayachtee will become famous soon enough
Is that a 2116/7116? I had to do some minor modification to my bracket to fit the EPS fit properly. Could you fabricate a plate between the two hold down bolts and drill it to hold the A/C bracket? Just an idea.
I haven't been able to find anything out about after market brackets for the A-6.
Regards,
John a.k.a. JayAchTee
350/TH350?
Old 03-13-2006, 01:23 PM
engineer engineer is offline
Motor Mouth
NECOA #: 2768
engineer will become famous soon enough
do not need rear AC bracket on intake. just leave it off. Compressor is supported by bottom sufficently.
Old 03-13-2006, 02:27 PM
NECOA #: 6351
Quote:
Is that true? You mean I can drop that bracket in the recycle bin and put on tall valve covers with roller rockers under them?
Old 03-13-2006, 07:11 PM
acauth1's Avatar
acauth1 acauth1 is offline
El Camino Central Founder/Administrator/NECOA Board of Directors
Vendor
Year: 1987
Model: El Camino SS
Region: 13(TX)
NECOA #: 124
acauth1 has a reputation beyond reputeacauth1 has a reputation beyond reputeacauth1 has a reputation beyond reputeacauth1 has a reputation beyond reputeacauth1 has a reputation beyond reputeacauth1 has a reputation beyond repute
Garage
Sure, leave the rear mount off if you enjoy listening to and feeling the compressor vibrating all the time! The mount is there for a reason. You can leave it off, but it will be pretty noisy...even when the a/c is off.
Auto A/C & Electrical Shop Owner, ASE Master
If you want a vision of the future, imagine a boot stamping on a human face - forever.
George Orwell
Old 03-14-2006, 05:53 AM
NECOA #: 6351
Thanks, Robert. Sometimes engineers use a bit of over kill but apparently not in this case. I'll keep the quite.
Old 03-14-2006, 02:04 PM
Mrapii's Avatar
Mrapii Mrapii is offline
Venerated Member
NECOA #: 2314
Mrapii has a spectacular aura about
That rear A6 compressor top mount is pretty hefty and I think eliminating it could be a mistake. Generally speaking when a new new vehicle is designed (especially a lower cost vehicle) the engineers don't design anything into it that is not necessary.
1979 El Camino\r\n1955 Chevrolet Del Ray\r\n1962 Corvette\r\n1966 Corvette Coupe
  #8
Old 03-14-2006, 02:28 PM
NECOA #: 6351
Quote:
I think you are right and here in SC we need AC to live.
  #9
Old 04-05-2006, 08:55 PM
Sharp71's Avatar
Year: 1971
Region: 18(CA)
NECOA #: 352
Garage
Thanks Guys,
I went with jayachtee's idea 'bout fab'ing a plate across the two mounting holes on my 2116. It came out fairly decent.
I used a 5" piece of an old garage door hinge (5"X 1-1/2" X 1/4") , cut to fit, drilled/tapped two holes for the A/C bracket and two more to secure to the intake. The original bracket needed only slight tweaking to fit. The plate is hardly noticeable and I believe GM put those heavy brackets there for a reason.
Anyway, I'm getting pretty good at this backyard engineering!
Next.. A rear sway bar out of an ol' swing set!
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
New Bracket For intake Stockish Engine Topics 0 09-25-2006 08:06 PM
Need rear shock bracket for 4th gen 1973elcaminoSS Wanted Items 1 03-16-2006 09:23 AM
80-up accelelorator cable bracket on intake manifold fast68 Wanted Items 1 02-13-2006 07:18 PM
TPI Vortec Intake Bowtie Ebay / Craigslist Alert 0 01-22-2006 11:21 AM
Rear A/C compressor bracket for 78 Elky blackstallion Heating & Air Conditioning Systems 7 08-28-2003 06:49 AM
