Roll Cage - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-23-2003, 06:08 PM
Trout Camino Trout Camino is offline
Member
Loose Nut
NECOA #: 6
Trout Camino will become famous soon enough
Default Roll Cage
I didn't know what area to post this in, so I guessed here.
I was thinking that maybe while I have my El in pieces I should put a roll cage in. Anyone ever done a roll cage in an El? What are the build specs if I want it to be NHRA legal?
I'm not concerned that I'm going to roll it at the track or anything, I'm more concerned about rolling it street racing or driving like a maniac.
screenwriter-director-welder-bartender
myspace.com/nealtrout
Old 02-23-2003, 07:48 PM
87SS 87SS is offline
87 Choo Choo
Year: 1987
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 128
87SS will become famous soon enough
Default Re: Roll Cage
Quote:
Hmmm...Not to preach, but racing is meant for the track! But, If that's what you really want to do how about auto x's? But then again, I really don't think Elkie's were meant for twisties.
Aside from that I would think the least you'd be able to get away with in an El Camino would be a 6 point.
Comments guys ?
Old 02-23-2003, 07:59 PM
Member
Loose Nut
NECOA #: 6
I can't tech at a track, and plus the local track stinks, they do zero prep work and the equipment is not reliable. It's one thing to weave your honda in and out of rush hour traffic, it's another to go out on a road in the middle of the desert and run it old school style.
Eventually I want to do something like the Gumball 3000 with the El. That would be awesome.
As far ask cages go, I have no idea what a 6-point is, I'm still new to the drag racing scene.
Old 03-11-2003, 09:20 PM
Iceman Iceman is offline
Member
Knuckle Buster
NECOA #: 520
Iceman will become famous soon enough
6 point roll cage refers to the number of mounting points of the roll cage. Here, more is better, the more points, the sturdier the cage is. I wish I knew of any links that would show you diagrams or layouts of common rollcages but I'm not much of a netsurfer.
Personally, I have only seen one photo of an El Camino with a roll cage and that was a '68, all-out drag car featured in a Summit catalog last year. It looks like you'll have to sacrifice your rear window if you plan on installing a 6 point roll cage. Besides from protecting you in case of a rollover, the roll cage also stiffens the frame (cages are always mounted to the frames in cars with frames) but a 2 point or 4point isn't going to do much in that department.
Another point to consider is that when a roll cage is installed in a car, interior space is severely compromised and in an El Camino, the room on the inside can't really stand shrinking any further, in my opinion.
Gudmundur Eyfells.
'68 El Camino
'69 El Camino
'04 Dodge Dakota
"I don't know where I'm going but they'll tell me when I get there."
Old 03-16-2003, 01:00 PM
Jims78elky's Avatar
Jims78elky Jims78elky is offline
Motor Mouth
Year: 1978
Model: El Camino Classic
Region: 18(N.CA,N.NV)
NECOA #: 657
Jims78elky will become famous soon enough
I saw a pretty decent cage in a 79 elky that actually tied to the back frame supports ( thru the rear window) i think it was plexiglass,but it sure looked good, the car was full tubed and i liked the look fo the roll cage,if i find any pics of where i saw it, i'll post them,if anyone gets a idea,i would be interested to see how it was done..later..
Old 03-16-2003, 01:01 PM
Jims78elky's Avatar
Motor Mouth
Year: 1978
NECOA #: 657
I saw a pretty decent cage in a 79 elky that actually tied to the back frame supports ( thru the rear window) i think it was plexiglass,but it sure looked good, the car was full tubed and i liked the look of the roll cage,if i find any pics of where i saw it, i'll post them,if anyone gets a idea,i would be interested to see how it was done..later..
Old 09-23-2003, 10:04 AM
81stroker 81stroker is offline
Junior Member
NooB
NECOA #: 1209
81stroker will become famous soon enough
How about a main hoop, a bar across the back, two door bars with pins and two angle bars going through the body under the window to 6x6 plates on the frame? No need to cut the window.
1981 El Camino - gutted, needs motor has Art Carr TH400
1987 Buick Grand National - has motor, needs money and a paint job
  #8
Old 09-23-2003, 09:00 PM
Elky85 Elky85 is offline
Year: 1985
Model: Conquista
Region: 19(AK,ID,OR,WA)
NECOA #: 499
Elky85 will become famous soon enough
doesn't the gumball run cost like 25,000 to enter?
1985 El Camino Conquista 13.7 @ 99mph with 87octane
soon to have a 200-4r and some superram
  #9
Old 10-17-2003, 10:05 PM
427adam 427adam is offline
Junior Member
Member
NECOA #: 1657
427adam will become famous soon enough
Default Roll Bar/ Cage
I am new to this site..(very cool btw) I own a 76' El Camino drag car/truck. I would encourage you to do your high performance driving at the track....With that said S&W Racecars in PA. makes a rollbar or rollcage for the El Camino. I have a 8pt. rollbar in mine. NHRA rules states that that is satisfactory to run 10.00 (1/4 mi.) if you havent altered your floor or firewall. S&W has a website www.swracecars.com Thier rollbar fit nicely inside the car and need minor trimming and fitting. They also make a "side bar swing out kit" that allows easier access to the seats. Good Luck with your project.
  #10
Old 10-18-2003, 11:12 AM
hairball hairball is offline
Junior Member
Twisted Wrench
NECOA #: 1406
hairball will become famous soon enough
Default roll cage
You don't need to give up your rear window. Take a look at a nascar truck. Run the rear bars out of the top of the rear body pnl above the window.
You may not post new threads
You may not post replies
roll pan? DiRt Body Restoration 2 07-10-2005 04:23 PM
roll cage ohioelcamino Suspension & Steering 7 04-29-2005 09:42 PM
4bolt 350, roll cage, steering box, SBC parts, interior, etc Minotaur15 Parts for sale 3 01-20-2005 09:40 PM
Many G-body Parts Interior, 4 bolt 350, roll cage, and more Minotaur15 Parts for sale 0 11-12-2004 07:19 AM
Roll cage questions z28evans General BS Topics 1 05-04-2004 04:01 PM
