Whats the difference between TH350 and TH350C? - El Camino Central Forum : Chevrolet El Camino Forums
Old 06-14-2006, 08:11 PM
Silver Bullet 82 Silver Bullet 82 is offline
Member
Twisted Wrench
NECOA #: 7613
Silver Bullet 82 will become famous soon enough
Default Whats the difference between TH350 and TH350C?
I have a TH350C is it different from the TH350? Also what does the TH stand for? and what does the C stand for? If anyone knows please share.
Thanks,
Damien
Old 06-14-2006, 09:07 PM
71Sprint 71Sprint is offline
NECOA #: 609
71Sprint will become famous soon enough
Th stands for turbo-Hydromatic, Hope I spelled that right. What the c stands for I don't know.
Brian
Old 06-14-2006, 09:20 PM
Member
Twisted Wrench
NECOA #: 7613
Quote:
Brian
Thanks Brian,
Does anyone know if the TH350C can handle a 350 SB? or do I need to upgrade to a bigger and better trans? What recomendations? Why?
Damien
Old 06-14-2006, 09:42 PM
JamesF
Posts: n/a
.1
Old 06-14-2006, 10:53 PM
78elcaminoman 78elcaminoman is offline
Year: 1978
Region: 13(TX)
NECOA #: 5855
78elcaminoman will become famous soon enough
what does it mean by lockup transmission? sorry for coming on your post
Antonio Martinez III
Old 06-15-2006, 05:31 PM
Member
Twisted Wrench
NECOA #: 7613
Quote:
Originally Posted by JamesF
TH350 and a TH350C have different cases, input, converter. The C has lock up. Shouldl work if you want lockup.
James, can you tell me what lock up means? I found this site that has the different trans info. http://www.maliburacing.com/auto_tranny_id.htm
If I'm reading this correct, I have a Stock C=low torque, heavy car and it could be Modified to B=Heavy torque, light car?
It looks like the TH350C was a later model.
Old 06-15-2006, 08:38 PM
CANTED's Avatar
CANTED CANTED is offline
Year: 1970
Region: 7 (AL,GA,TN)
NECOA #: 6858
CANTED is just really nice
Garage
Default lock up
The "lock up" refers to the torque converter. Converters have some slip to them all the time, not just when you are stopped. A lock up converter has a part that locks the sections of the converter together under certain conditions. When locked there is no slip, which is good for gas mileage and reducing heat in the trans.
Jim
70 ElCamino 461 solid M20 331eaton
Third gen gallery, page 13
  #8
Old 06-15-2006, 08:59 PM
JamesF
Posts: n/a
.1
  #9
Old 06-15-2006, 09:11 PM
Member
Twisted Wrench
NECOA #: 7613
yep, right on all above. What motor are you useing? Do you really need a beefy transmission?
We are installing a 350 SB, I was wondering if the TH350C was ok for that size engine. Considering there was a 229 installed prior. Sounds like we should be fine with the TH350C and 350 SB.
  #10
Old 06-15-2006, 09:59 PM
JamesF
Posts: n/a
.1
  #11
Old 06-16-2006, 07:15 PM
79Elky's Avatar
79Elky 79Elky is offline
Year: 1979
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 1749
79Elky will become famous soon enough
The lockup TH350C has some plastic washers inside and isn't quite as strong as the old, original TH350. But it'll handle a fairly-stock 350 especially in a lighter car. It was usually provided in Malibu wagons. Other cars got the TH200C which has even more plastic parts. Like the TH350C, the nomenclature TH200C also means it has a locking torque converter. Other locking torque converter trannies include the TH200-4R and TH700R4, neither of which have the letter C in their nomenclature.
With all of these trannies, the later they were produced, the more reliable they became; early TH200Cs and TH200-4Rs, for example, earned a bad reputation for wearing out before 100K miles. I haven't heard such complaints about the 350C, however. By the mid '80s, all of these trannies were fairly reliable and many have lasted well into the 200+K mile range without a problem.
There used to be a cupla sites with more-detailed info but it looks like they've gone kaput One thing I was looking for was a listing of trannies showing their design torque ratings.
AHHA, here we goes:
http://www.gnttype.org/techarea/tran...ranstutor.html
Unfortunately, it doesn't include the TH350 or 350C
EDIT: I just noticed statements I made concerning the 4L60 and 4L80 were greatly in error, and deleted them
Frankly, if you HAVE to use a 3-speed automatic, I'd go with the 350C (unless you need the brute power-handling capability of the TH400). They're nowhere near as common as the other trannies, however; so if you eventually want to get rid of it, don't just junk it.
Yea, though I am forced to crawl through valleys of SUVs and riceburners, I fear no evil, for torque and positraction art mine. Mine eight rods, eight pistons and tripower, they comfort me. For therein lies mine power, and glory, and salvation, forever.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Whats the difference? No1TubaPlayer Transmission & Drive line 4 07-23-2006 07:11 PM
TH350 or TH350C bunkie21 Transmission & Drive line 2 07-04-2005 02:41 PM
difference in a th350 and a th250c lowrider45 Transmission & Drive line 2 06-16-2005 05:27 PM
headers/stock manifolds whats the difference 82 meeno Performance Modifications 8 09-16-2004 12:33 PM
Whats the difference KEEPKOOL VIN Decoding 2 12-11-2003 08:35 AM
