'79- speedo "chirping" noise- suggestions? - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > General Topics > Tips & Tricks
Old 08-12-2006, 11:02 PM
sandman sandman is offline
Junior Member
Twisted Wrench
NECOA #: 3631
sandman will become famous soon enough
Default '79- speedo "chirping" noise- suggestions?
My '79 Royal Knight with cruise control has a speedometer issue. The speedo makes a very noticeable and annoying chirping or rubbing sound that gets quicker as road speed increases. It gets quiet occasionally at highway speeds, and is noisier in cold weather. Before I dive in again and take the dash apart to look for causes, has anyone else absolutely found the cause? To me, it seems to be coming from inside the speedometer gauge itself, I don't think it's the cable. I've gotten used to turning up the stereo a bit, but others going for a ride hear it and ask, "what's that noise?". I really want to solve this for good, and I posted here a while ago and thought I'd try again.
Old 08-13-2006, 07:43 AM
theelcaminofactory theelcaminofactory is offline
Year: 1984
Model: Conquista
Region: 10(IL,MN,WI)
NECOA #: 572
theelcaminofactory is of outstanding character
Quote:
Originally Posted by 87ElCamino
Sounds like the speedo cable needs to be lubricated.
Ernie's probably right on the money...or else you have a lil birdy living behind your gauge cluster! The gauge cluster is not hard to remove, take it out, disconnect the speedo cable and try liberally spraying inside the cable with some WD-40 (with the tube provided) to see if that'll stop it.
Old 08-13-2006, 07:15 PM
Quintonsdusty's Avatar
Quintonsdusty Quintonsdusty is offline
NECOA Board of Directors
Year: 1967
Region: 4 (MD,VA)
NECOA #: 7439
Quintonsdusty has a spectacular aura about
I've had the same problem with speedometer cables in the past. I never had a lot of luck on lubricating them. I usually wound up getting a whole new cable. I'd give the lube a shot first as it's a lot cheaper.
On the plains of hesitation, bleach the bones of countless millions who on the threshold of victory sat down to wait and waiting they died.
Old 08-21-2006, 11:31 AM
K5Cruiser K5Cruiser is offline
Year: 1987
Region: 17(S.CA,S.NV)
NECOA #: 6708
K5Cruiser will become famous soon enough
I had the same problem in my '80 Elco. I ended up just replacing the speedo cable with a new one because I didn't want to have to tear apart the dash a second time.
I have in the past used spray lithium grease on a couple different vehicles. It comes with a spray tube that you can poke down the speedo cable, and is thicker than WD-40, so it might get you better results.
Old 10-01-2006, 01:13 PM
82elke 82elke is offline
Junior Member
Member
NECOA #: 8233
82elke will become famous soon enough
mine was doing the same thing then just stoped working altogether.
82 El Camino
85 K5 blazer
95 Mitsubishi mighty max
94 mighty max
88 mighty max
Old 10-01-2006, 06:07 PM
Elky77's Avatar
Elky77 Elky77 is offline
Year: 1977
Region: 8 (OH,WV)
NECOA #: 1971
Elky77 will become famous soon enough
Sometimes, as with mine, it the plastic gears at the end of the cable and in the speedo. They wear down and look like "apple-core".
Especially if the needle is bouncing.
The cable gear is an easy fix, the speedo is not.
Good luck,
Elky77
Old 05-04-2009, 07:05 PM
cslix cslix is offline
Year: 1985
Region: 3 (DE,NJ,PA)
NECOA #: 13666
cslix will become famous soon enough
hey im pretty sure i have the same exact problem.. couple years ago my dad crashed the elky into a pound.. dont know why lol.. but it started since then.. the chirpping noise going on and off behind the left side of the dash like the gauge idk *** it is it pisses me off and i blast my music to meanwhile i should be listening to the nice engine.. ive never been behind the dash so i have no idea what the speedo cable is? and why i would lubricate it.. anyone have a picture or can anyone explain where to tackle the screws first and so forth like a walk through.. pleaseee! OH and now the speedo needle looks like its shaking a little.. not when i accelerate but when i cruise..
85 305
  #8
Old 05-04-2009, 07:55 PM
Year: 1984
Model: Conquista
NECOA #: 572
Quote:
Into a pound of what?
A You Wish Merry Christmas Wish---->
  #9
Old 05-04-2009, 08:10 PM
dougs85 dougs85 is offline
Year: 1987
Model: Conquista
Region: 16(CO,MT,WY,UT)
NECOA #: 9322
dougs85 is a glorious beacon of light
Quote:
Most likely a large-wet pound.
Doug
85 El Camino 305, TH350, K&N, dual exhausts (Sold 2-21-09)
87 El Camino 305, 2004R, K&N, dual exhausts
1964-1/2 Mustang conv, 260 V8, dual exhausts
2003 Jaguar XJ8, 2000 Harley Road King
66 Austin-Healey BJ8
Lakewood, CO
  #10
Old 05-04-2009, 09:47 PM
Viet_Vet's Avatar
Viet_Vet Viet_Vet is offline
Year: 1968
Region: 19(AK,ID,OR,WA)
NECOA #: 13860
Viet_Vet will become famous soon enough
Try lubing the lower end that may have been submerged??
1968 El Camino BB/auto-- Hemi Orange
1967 Covette BB/4 speed--project as of now!!
2006 Honda ridgeline-V6
2002 dodge 3/4 ton diesel p/u Cummins /6speed-plus lance camper--Our go south with the boat for the winter Vehicle
2002 Harley softtail deuce
1 car 3 trucks
Khe Sahn survivor U.S. Marines
  #11
Old 05-05-2009, 03:06 AM
DONE DEAL DONNY's Avatar
Event Master & Deputy Director, Region 13
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a brilliant future
Garage
My ELKO starting chirping and the needle starting (bounceing), in less than a week the speedometer needle broke off! And that all happened after I removed the cluster and cleaned everything up. My advise fix it as soon as possible because one bad thing can lead to something much worse! If your going to turn up the music you better be playing sad songs.
1968 El Camino S/S 396 " Yellow Rose of Texas"
1980 Blu Buy U
  #12
Old 05-05-2009, 09:11 AM
Year: 1985
NECOA #: 13666
lol sad songs lol.. made me laugh.. aright well whats screws do i hit first and what should i be careful with and what am i looking for to lube? anyone got a pic.. and where to shoot the wd-40 or is there something better i can get @ pepboys
  #13
Old 05-05-2009, 09:16 AM
CoyoteOn2's Avatar
CoyoteOn2 CoyoteOn2 is offline
Name: Coyote aka Larry
Year: 1977
Model: El Camino Classic
NECOA #: 7195
CoyoteOn2 has a reputation beyond reputeCoyoteOn2 has a reputation beyond repute
They do make a speedometer cable lube and it is available at PeP Boys, but WD-40 is also good.
No longer in SIN CITY
Now in GODS COUNTRY
COLORADO
Larry
(but hay ~ What do I know?)
I'll chew on some Awhile
  #14
Old 05-06-2009, 03:21 PM
BillyJack's Avatar
BillyJack BillyJack is offline
Year: 1987
Model: Conquista
NECOA #: 13628
BillyJack will become famous soon enough
I've always used LubriPlate white grease on speedo cables and tach cables on both cars and bikes. Never had to do one twice.
Bill
  #15
Old 05-06-2009, 06:19 PM
Al Camino's Avatar
Al Camino Al Camino is offline
Year: 1987
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 10090
Al Camino will become famous soon enough
It's a '79 Royal Knight specific problem. The spring in the dynamic allan spectrum provides a time frequency variance.
79 Caballero 350 4-speed, Double Hump Heads.
87 El Camino SS
You may not post new threads
You may not post replies
Cragar16"X8"15"X7" lower price$150.oo 74hotrodmalibu Parts for sale 4 03-22-2008 03:10 PM
Upgrade for '59 gauges, 5" 200 MPH speedo & tach! Richard/SIA Interior Restoration 6 02-19-2008 12:59 AM
1978-1988 Elky Rear window "water-gutters"?? for s kburwell63 Parts for sale 0 06-20-2007 08:12 PM
SEPT 30th BOULDER CITY NEVADA "WURSTFEST" voodoocamino Region 17 (NV) 0 09-14-2006 01:47 PM
Region 2 interest in a "Spring Dust Off" type crui a73elkyss Region 2 (CT,MA,ME,NH,RI,VT) 1 03-29-2006 05:31 AM
