1971 rear wheel and tire combo - El Camino Central Forum : Chevrolet El Camino Forums
Old 10-14-2006, 11:55 AM
flyboy22 flyboy22 is offline
Junior Member
Member
NECOA #: 8343
flyboy22 will become famous soon enough
Default 1971 rear wheel and tire combo
I own a 1971 elco...pretty much stock. I was wondering if anyone could tell me the largest wheel and tire combo that i could fit in the rear without having to alter anything. currently i have 15x7's with 235/60/15 tires. i want to get 15x8's, but i don't know what kind of tire to get. any help would be greatly appreciated. thanks.
Old 10-14-2006, 05:25 PM
mnunn's Avatar
mnunn mnunn is offline
Year: 1970
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 5673
mnunn is just really nice
I've got a 70 and JUST went through this.
I'm now running 235/60/15's in the front and 275/50/15 in the rear.
I opted for 8" wide 15" rims in the front with normal back spacing, and have no clearance problems whatsoever.
I chose 10" wide rims in the rear with 5.75 back spacing. They position the tire perfectly in the well, but rubbed on the shock mount. I added 1/4" shims (until I can move the shock mounts in a little) and that cured the rub. So 5.5" back spacing should be perfect.
I didn't have to roll the fender lip under or anything odd like that.
At a lot of the on-line rim places they offer a handy measuring guide you can use to measure your car exactly.
Be careful with one thing. Not all rear axles are positioned in the middle of the car. Mine's 1/4" off center. I saw one 1/2" or more off. Any offset will make a big difference in the max tire/rim sizes you can run.
Hope it helps.
70 Elky (Non-SS) 454CID, TH700-R4
85 Elky SS
68 AMC Rambler (Sold)
69 Chev C-10 Pickup (lost in the flood of 2010)
29 Model A (Sold)
Old 10-14-2006, 05:34 PM
Junior Member
Member
NECOA #: 8343
Default thanks
I will give the tens a try. Do you know of any good online sites that carry them for an affordable price? Thanks again.
Junior Member
Member
NECOA #: 8343
Default thanks
Old 10-15-2006, 07:32 AM
bigjames4xl bigjames4xl is offline
Year: 1972
Region: 5 (NC,SC)
NECOA #: 2409
bigjames4xl is a glorious beacon of light
I'm running 15x9 wheels(5 1/2 backspacing) with 2.75x60 tires. Like mnunn has said though there can be some variations. New rear control arm bushings and a rear sway bar will cure a lot of the rubbing issues that can arise.
Ol Paint now livin large in Texas with a new owner
Old 10-15-2006, 04:49 PM
FO50FO FO50FO is offline
Junior Member
Twisted Wrench
NECOA #: 8068
FO50FO will become famous soon enough
Same for me! 15x7 front 235/60 and 295/50 on rear with 15x8 No rubbing at all and my Elky sits pretty low. I also have a brand new pair of Radial TA's 275 mounted on some Weld wheel prostars if any one in the area wouls like to purchase.
1970 SS 454 Clone
Olympia, Wa.
Old 10-16-2006, 12:59 PM
Tim Tim is offline
Member
Knuckle Buster
Year: 1970
Region: 18(N.CA,N.NV)
NECOA #: 7961
Tim will become famous soon enough
I've got a '70, went with 15" rims. Because I wanted a particular wheel (TQ), I had to live with width and rear spacing I did not find optimum for max tire size. So, that said, here's what I just installed:
Front: 15 x 7 (4" rear spacing), 255/60
Rear: 15 x 8.5 (4.25 rear spacing), 255/60
I love the way it looks/sits, but would have preferred more rear spacing on the rear making a 275 possible. Such is life.
Tim
  #8
Old 10-16-2006, 03:49 PM
mnunn's Avatar
Year: 1970
NECOA #: 5673
Default Re: thanks
Quote:
I was only interested in Corvette style chrome ralley wheels. Best price I found was at /Pete Paulsen
  #9
Old 01-31-2013, 08:00 PM
7168mutt
Posts: n/a
Is anyone running 17x8 in front and 18x10 in rear? What size tires?
  #10
Old 02-01-2013, 01:36 AM
1972elcaminomartin's Avatar
1972elcaminomartin 1972elcaminomartin is offline
Year: 1972
Region: 25 (ALL OTHER)
NECOA #: 22195
1972elcaminomartin will become famous soon enough
Garage
I had 20 x 10s with 275 tires for some time, on my 72..no scrapeing issues ever.
  #11
Old 09-05-2013, 08:34 PM
Denis 68 Denis 68 is offline
Junior Member
Gear Head
Year: 1968
Region: 18(CA)
NECOA #: 26369
Denis 68 will become famous soon enough
Hope it helps.
This is good info. I want to run a 15x10 Draglite w/295/50/15 M/T ET Street radial. Is anyone running this combo?
I know on my Nova a 275/60/15 was a perfect fit with 15x8 with a 5"bs, but adding the same size in the M/T ET Street Radials the section width is slightly wider. and gave a very slight rub under certain conditions, so I added 1/8" spacers and all was good. There would probably been no problem as it was a go straight car, but I just felt a little better.
Sorry for the ramble and thanks in advance!
  #12
Old 09-05-2013, 08:36 PM
Junior Member
Gear Head
Year: 1968
Region: 18(CA)
NECOA #: 26369
Sorry it a 68 4:10 10 bolt posi all stock suspension.
  #13
Old 09-05-2013, 08:40 PM
Junior Member
Gear Head
Year: 1968
Region: 18(CA)
NECOA #: 26369
All of this ^^^ and will the wheels and tires stick out of the fenders?
  #14
Old 09-05-2013, 09:53 PM
Micro67's Avatar
Micro67 Micro67 is offline
Year: 1967
Region: 14(AR,LA,MS)
NECOA #: 23979
Micro67 has a spectacular aura about
Garage
1967 el camino. I'm running 18x8 with 5 back space front with 245/45 tires and 20x8 rear 4 inches back space with 275/35 tires. Front rubs just a tiny bit at full left lock but car sits 2 inches low. Back has no rub issues and it has BMR 1 inch lowering springs. Hope this helps
  #15
Old 09-06-2013, 11:09 AM
novelle's Avatar
novelle novelle is offline
Year: 1967
Region: 17(S.CA,S.NV)
NECOA #: 14267
novelle is a jewel in the rough
I'm running Centerline Convo Pros 15"X 8 1/2" with 5 1/2" backspacing and Mickey Thompson 295/50/15 Sportsman S/T radials.
My '67 Project Pictures:
Can't wait to get it on the road.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
biggest wheel/tire combo you coul get to fit w/out rubbing Dumbell Wheels & Tires 19 12-04-2014 11:03 PM
tire combo question camino1 Transmission & Drive line 4 03-24-2006 05:34 AM
Opinions needed on tire/wheel combo... Mr Marv Wheels & Tires 8 07-11-2005 10:37 AM
Another 5th gen wheel/tire combo question Tony_SS Wheels & Tires 4 02-24-2005 06:57 PM
wheel and tire combo hotrodharley Wheels & Tires 4 04-03-2004 09:08 PM
