Difference Between Standard and SS - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-26-2007, 08:49 AM
svenskekocken_2 svenskekocken_2 is offline
Junior Member
Member
NECOA #: 9082
svenskekocken_2 will become famous soon enough
Default Difference Between Standard and SS
Hi!
My name is Fredrik Henriksson and I'm a swedish fellow who doesn't own an El Camino.....yet!
I'm having some trouble deciding wich Camino I want.
I've been looking for an El Camino 1973 and I've found one SS and one standard.
The standard El Camino I've found is in very good condition and costs approx $7,800. http://www.millners.nu/elcamino.htm (wrong front)
The SS costs approx $8000 but needs some bodywork. there are some dents that needs fixing and a new paintcoat. http://www.usabil.nu/databas/Detalj.asp?ID=69913
My question for you guys is; Which one do you think i should buy?
US cars are quite expensive in sweden so just compare the two, and give me an idea of which one is worth it's money.
My other question is; what are the big difference between the standard and the SS version?
And my final question; Are the parts from the fourth generations El caminos changeable with one another? I mean, can i take the front from a 77 camino and put on a 73?
Hope you guys can help me to decide, and then i might be an el camino owner myself! =)
Old 02-26-2007, 09:27 AM
skinyfisher's Avatar
skinyfisher skinyfisher is offline
Deputy Director Region 6 - 2013 Founders' Award Winner
Year: 1969
Model: El Camino SS
Region: 6 (FL)
NECOA #: 3484
skinyfisher has a brilliant future
Garage
Not sure what to tell you on the value except the SS if Real is always given equal condition worth more $. However the year has a lot to do with it if you were looking at a 1972 SS BB, SS car it would be at least double and the standard would be close to the same and more yet for then 71,70,69,68 and so on over the 1973 model year.
If you are going to buy the car to drive and play cars and not restore it than take the best car mechanicaly ie: brakes ,tires,uhpolestry and of course engine, but mainly the items of cost that must go into the car now. If you are going to restore it to a weekend show car and drive it to and from and make it your baby. You know! ie: put on new seats some glass a lot of trim pull the engine and return the engine bay to new conditions and paint the car than take the SS car. If you are going to hot rod the car with some custom treatments and do not care about the car being badged or trimmed correct than take the best of the two cars as you will be killing its stock stance anyway.
These answer should get you confused, remember that pictures can not buy a car they are only taken to sell a car.
Good luck
El Chromeo is a "69" SS 396/350 HP with a stock outside, stock underside, stock inside and a splash of chrome and polish in the engine area.
Old 02-26-2007, 12:04 PM
ElkyPete's Avatar
ElkyPete ElkyPete is offline
Venerated Member
Year: 1980
Model: El Camino SS
Region: 13(TX)
NECOA #: 3
ElkyPete is just really nice
Well it looks like someone already answered you question about swapping front ends, it was done. The Non-SS has a newer front end.
The SS has hood stripes, that is not correct. The ones on the side are but the ones on the hood are not, they were added later.
The non-SS looks pretty nice but pictures don't explain well all the problems.
Check for Bondo patches with a magnet. Especially around the wheel wells, bottom of the doors etc... Also check the floor pans under the carpet for rust, especially in the back floor. If the magnet doesn't stick to any part of the body panel or is really loose in an area there is Bondo there.
If I picked, I'd probably take the SS - My self. But the other looks and sounds like it's in much better shape.
It is going to be your decision.
Generally in 73 the SS was an appearance package but did offer a Big Block engine in the SS as opposed to the 350 that came in the rest. So, in the SS I'd expect to see Bucket seats, console, floor shift, gauges, and a Big Block Chevy Engine and a THM 400 with a 12 bolt rear differential.
Here this is from Dan Carr's page on how to spot a Real/Fake SS
"1972 was the last year for a lot of things. For example, it was the last year for the LS5 454, the 396/402, and the 307. In '73 the Chevelle line was completely redesigned with driving comfort being the major theme rather than performance. There was still an SS-454 package available. It used the low-compression LS4 454 rated at 245 horsepower. This motor was less powerful than the earlier LS5, although with the right tuning, head porting and pistons it could equal the LS5. The LS4 had a cast crankshaft when mated to automatic transmissions, and a forged crankshaft when mated to a 4-speed manual. In 1973, an SS package was available with either a 350 or a 454 engine. A few post-'72 454/4-speed cars were built. These are seldom seen and are becoming more sought-after. Unlike previous years, it was possible to order the 454 without the SS package. There was also an SS package available for the '73 Chevelle wagon. These are fairly rare and few details are known. Baldwin Motion (famous for their hot "tuned" muscle cars of the late '60s) had one more card to play in '73. The '73 Baldwin Motion SS-454 Chevelle was the most potent of all the special cars that they had built. At least one example is known to have survived.
Around 1974 the "Laguna S-3" package was introduced. It was similar to the '73 Chevelle SS package. The "S-3" package was available only on the Chevelle, not the El Camino or Sprint (they still had the SS and SP packages). 1975 was the last year you could get a 454 in the Chevelle, El Camino, or Sprint. Like the earlier SS-454s, the '73-'75 SS-454s are scarce today. However, they are not in demand as much as the '72 and earlier SS-454s. The same is true for the SP-454, although it is even rarer than any '73-up SS-454.
The Sprint SP package was available until 1977. 1977 was also the last year of production for the Sprint. "
I hope this helps. If you'd like to read more on this here is the link.
http://www.chevelles.com/shop/ss_ident.html#73-77
And
http://www.chevelles.com/elcamino/
Home Site:
1972 El Camino Custom 400
1976 El Camino Classic
1980 El Camino Super Sport
E-Mail:
Old 02-27-2007, 10:32 AM
77SS's Avatar
77SS 77SS is offline
Year: 1977
Model: El Camino SS
Region: 9 (IN,KY,MI)
NECOA #: 4241
77SS will become famous soon enough
Keep in mind that the SS option 73-77 was a trim package, not a performance package.
Steve Frey
Old 02-28-2007, 05:59 AM
Big Block Chevy Big Block Chevy is offline
Member
Twisted Wrench
NECOA #: 8559
Big Block Chevy will become famous soon enough
Finally i kno the diffrence
Old 11-03-2012, 03:31 PM
rharding rharding is offline
Junior Member
Member
Year: 1972
Model: El Camino SS
Region: 6 (FL)
NECOA #: 22961
rharding will become famous soon enough
Default Do I have a real SS454
Hello, I have recently acquired a 1972 El Camino SS?? the vin number is 1D80W2K572881 which i have determined through the vin number that it is a custom edition but realize that doesn't mean its a real SS. Cool car with a straight rust free body but some interior stuff has been changed along with the addition of a/c and a serpentine belt. Over the years I am sure other stuff has been changed but really need to figure out how I can tell for sure.
Old 04-03-2015, 05:54 AM
Nightmare77's Avatar
Nightmare77 Nightmare77 is offline
Junior Member
Gear Head
Year: 1977
Model: El Camino Classic
Region: 4 (MD,VA)
NECOA #: 55297
Nightmare77 will become famous soon enough
The VIN is saying it's an El Camino Custom (1D80) with a 454 CI engine (W) built in 1972 (2) Assembly in Kansas (K) Production number 72881 (52881). The GM heritage center will have a manual that you'll find interesting.
VIN Decoder: http://www.elcaminocentral.com/showthread.php?t=27738
GM Heritage Manual: https://www.gmheritagecenter.com/doc...-El-Camino.pdf
Enjoy!
  #8
Old 04-04-2015, 05:01 PM
O52's Avatar
O52 O52 is offline
Year: 1970
Model: El Camino SS
Region: 18(CA)
NECOA #: 22875
O52 is a glorious beacon of light
Garage
Not to hijack the OP but you have a genuine SS. The W in the VIN designates a 454 which was only available in 72 with the Z15 SS package.
See the following link:
http://chevellestuff.net/1972/72ss.htm
Ed
70 El Camino SS
  #9
Old 04-04-2015, 07:08 PM
Nicks 1984 elcamino's Avatar
Nicks 1984 elcamino Nicks 1984 elcamino is offline
Year: 1984
Region: 8 (OH,WV)
NECOA #: 23695
Nicks 1984 elcamino has a spectacular aura about
Garage
Default New B
Fredrik, I hope you get the answer you are looking for. Good luck on your search. have fun & enjoy the forum.
From Nick & Don
Grove City, Ohio
  #10
Old 04-04-2015, 07:11 PM
Year: 1975
NECOA #: 13978
The standard model doesn't have the metal drip rails above the doors. Not sure if the SS model does. I used the metal drip rails from a Classic on my standard plain-jane '75...
Driving with the widow cracked open a bit in rain, works better & dryer with the drip rails..
The SS model designation doesn't mean much after 1972. Had a '76...
  #11
Old 04-04-2015, 09:39 PM
jarhead's Avatar
jarhead jarhead is offline
Year: 1987
Region: 13(TX)
NECOA #: 11248
jarhead has a reputation beyond reputejarhead has a reputation beyond repute
How can you tell its the Easter season... an 8 yr old thread has been ressurected!
1987 El Camino, aka Harper's cruck
1983 El Camino S
Dang, I miss Ronald Reagan
more and more every day..
  #12
Old 04-05-2015, 08:44 PM
Year: 1975
NECOA #: 13978
Talking
Some threads just wont DIE !!!
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
age difference bondthenguyen General BS Topics 28 02-26-2009 05:12 PM
Are these standard equip.? Where can I find them ? 72 Custom Elky General BS Topics 8 05-16-2008 10:49 AM
Standard shift parts Longroof79 Wanted Items 0 01-21-2006 12:36 PM
not your standard looking Elky RedElky General BS Topics 12 01-12-2004 07:27 PM
? from automatic to standard whats entailed? Centaur Transmission & Drive line 1 10-13-2003 01:21 AM
