one of my visors doesnt seem to stay up against the roof, i have to tuck it into the headliner molding to get it to stay there. I tried putting some electrical tape around the rod the visor attaches to but that actaully made it worse....any ideas?
| Sponsored Links | ||
Advertisement | ||
On my 82 Elky there is a small Phillips head screw on the back side of the sunvisor where the rod goes into it. If you tighten this screw down some it should tighten up the sunvisor too and keep it from falling down.
Bobby 56 Chevy 2-door sedan 82 El Camino Conquista |
i think i need some type of cushoning on the inside of the visor to support it or something...i tried electrical tape and aluminum foil and neither of those worked
You need to replace the tensioning tubes (that's what I call them anyway.) They are the plastic sleeves that slip over the hinge arm and provide resistance for the visor to stay up. I found a few a couple of years ago at a Pontiac dealer... NO you can''t have mine!
old thread but i have the same problem.. im gonna try losin them and then pushing them in further and tightening them maybe that will work.. any idea on if i should rap something around the metal rod then stick it on or anything?
85 305 To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
I ended up ordering the "tensioning tubes" from elcamino store and they fixed the problem, less than 5 bucks to fix both visors.
1984 Conquista V6 (newly acquired) 1984 El Camino V8 700r4 |
Quote:
just answer me
#8
Replacing the bushing is an easy job. Loosen the screw on the back of the visor, and pull the visor off the rod. Pull the old bushing ( what's left of it) out of the visor with a pair of needle nose pliers. Push the new bushing in, and re-install. Tighten the screw to get the visor performance you want. 5 minutes max for both sides.
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade. To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| sun visor supports | hammer | Wanted Items | 2 | 07-26-2007 06:43 AM |
| Visor speakers | 77SS | Audio | 1 | 08-17-2006 12:01 AM |
| Sun Visor Question | JimmyZ | Interior Restoration | 3 | 05-13-2004 09:11 PM |
| 78-79 headliner and visor question | nemcss | Interior Restoration | 2 | 12-26-2003 04:28 PM |
