big tires - El Camino Central Forum : Chevrolet El Camino Forums
Old 04-18-2007, 04:33 PM
elkman78 elkman78 is offline
Member
Twisted Wrench
NECOA #: 6849
elkman78 will become famous soon enough
Default big tires
The motto is go big or go home, can anyone give me some advice on how to squeak big, wide tires under the rear wheel wells of my 78 and how big might i be able to go or should i just go home. Thanks
Old 04-18-2007, 09:38 PM
Snaggle To0th Snaggle To0th is offline
Year: 1978
Region: 18(CA)
NECOA #: 4293
Snaggle To0th will become famous soon enough
ive fitted a 245/45/17 in my rear with a funky backspacing on them and had plenty of room for a fatter tire. you can probably go like 265 or even 275 if you wanted. Go to a reppable tire shop and they should be able to put a measuring tool to see how wide they can go for you. Plus your wheels will limit how wide you can go too. So MY best advice for you is to go to a reppable tire shop and see what they can do for you. Thats my experience from working at a tire shop and getting customers what they wanted no matter how ridiculous the choice was.
-Anduh
2007 WyoTech Graduate/California licensed SMOG Tech/gear head
Old 04-23-2007, 05:53 PM
Member
Twisted Wrench
NECOA #: 6849
i was told that i could grind off a couple of inches off the frame..... but how safe is that?? is there any thing else to do as well?
Old 04-23-2007, 07:34 PM
464elky's Avatar
464elky 464elky is offline
Year: 1984
Region: 6 (FL)
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute464elky has a reputation beyond repute
Garage
Default NO WAY
If a tire shop is telling you to cut your frame you need a new tire shop!!!!!!!!!!
Do a search for frame replacement and see how many people have had to replace the frame because of rusting into or just part out the Elky.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
In year 10. Added FITech Fuel Injection this year. 40K miles and going strong.
Link to Garage:
Old 04-24-2007, 01:54 AM
Member
Twisted Wrench
NECOA #: 6849
a tire shop wasn't telling me this i herd about it from Malibu owners they did it to fit wide slicks under the wheel wells
Old 04-24-2007, 08:58 AM
WhisperPC WhisperPC is offline
Year: 1973
Model: El Camino SS
Region: 18(CA)
NECOA #: 5463
WhisperPC will become famous soon enough
Garage
Quote:
This is the process of "tubbing". It's used to fit HUGE tires into the rear wheelwells.
I think that all Elkys can fit up to 255s on the rear with no problems, IF they have the right wheel. I've seen a 4th gen with 275s and no rubbing problems. I'd like to squeeze 295s into my 4th gen, but I expect to need a panhard bar (or maybe a watts linkage) to keep the rear axle centered.
Just how big do you want to go?
Old 04-24-2007, 07:30 PM
Member
Twisted Wrench
NECOA #: 6849
i found this : http://www.maliburacing.com/frame_notching.htm i am trying to find a way to fit these: http://store.summitracing.com/partde...D61415&FROM=MG
and
http://store.summitracing.com/partde...2D6655&FROM=MG
i know im hoping for a lot but ive seen pics of elkys with bigger tires just dont know how they do it. thanx
  #8
Old 04-25-2007, 08:52 AM
theelcaminofactory theelcaminofactory is offline
Year: 1984
Model: Conquista
Region: 10(IL,MN,WI)
NECOA #: 572
theelcaminofactory has a brilliant future
It's called notching the frame, and if done correctly and reinforced in other ways, is perfectly OK to do. It involves more than just grinding the frame. Even with rolling the wheel well lip and notching the frame, it will still not give you enough room to stuff a 15" wide Mickey Thompson tire in there. To do that you'd have to back half the frame (with tubs) not just tubs. If you roll the lip and notch the frame, you could probably have enough to get a 10" wide wheel in there, depending on the backspacing of the wheel. The Pro Street look is pretty cool even though it's old hat now...it ruins the handling of the car as far as going anything but straight line...and if this is your daily driver, I sure wouldn't recommend doing it...it's for guys who have more than one toy to play with.
  #9
Old 05-02-2007, 10:20 AM
Steve84Ec Steve84Ec is offline
Year: 1981
Model: Conquista
Region: 6 (FL)
NECOA #: 1529
Steve84Ec will become famous soon enough
I have on my elcamino 275/60's on a 15x8 rim. no clearence issues. Have done know modification to anything, but does have some heavy duty springs in the rear. This is on my 84....which really doesn't need such big of tires. But it did help with cruising on the highway lol
1984 El camino, V8 with wheels spinning in the back, thats the only way to do it
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
New Tires ChevelCamino Suspension & Steering 0 12-08-2006 01:11 PM
tires elcaminocpl355 Transmission & Drive line 6 11-22-2006 09:19 AM
Tires for my 78. z3pr General BS Topics 0 01-31-2006 01:25 PM
tires 1985elkySS Parts for sale 0 08-15-2005 06:13 PM
Tires Supercharged 86 Performance Modifications 5 10-13-2004 12:59 PM
