Window Felts - El Camino Central Forum : Chevrolet El Camino Forums
Old 08-01-2007, 05:56 AM
ruehled ruehled is offline
Junior Member
Gear Head
Year: 1983
Model: Caballero
Region: 9 (IN,KY,MI)
NECOA #: 9842
ruehled will become famous soon enough
Default Window Felts
El Camino is new to me, but i want to fix it up just fine. I now have the replacemant window felts. I have been doing my pre dismanteling look about and making notes. Note: Outside felt.There are 5 small Phillips head screw as that I would think are sheet metal. Take off the inner panel. Screws 1 2 4 5 are accessable. Screw 3 is behind the glass. When the panel is off, can the glass be adjusted so 3 is available?
Note : The inner felts seem to be fastened with a staple. A BIG staple. I presume I can work it out with a tack puller. But the question arises, how to get the staples back in. The desk stapler certainly cannot do it. Could I use smalll screws as on the outside felts? Perhaps when I get into the job it will be all clear. I like to do my homework first, so there are no surprises. It seems like all I do is full of surprises.
Thanks for you expert knowledge.
Richard Ruehle
Old 08-01-2007, 06:15 AM
464elky's Avatar
464elky 464elky is offline
Year: 1984
Region: 6 (FL)
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute
Take the bolts out of the regulator arms that hold the glass and lower it into the bottom of the door and the top screws will be accesible. Just bolt the glass back and your adjustments won't have changed.
Use a small grinder or snips and remove the corners of the staples to release the inner felts. Most people use 1/8" aluminum pop rivets to mount the new ones back.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
Old 08-01-2007, 08:30 PM
dougs85 dougs85 is offline
Year: 1987
Model: Conquista
Region: 16(CO,MT,WY,UT)
NECOA #: 9322
dougs85 is a glorious beacon of light
Read my reply on Window Felts July 22, just 12 topics below this one. Doug
85 El Camino 305, TH350, K&N, dual exhausts (Sold 2-21-09)
87 El Camino 305, 2004R, K&N, dual exhausts
1964-1/2 Mustang conv, 260 V8, dual exhausts
2003 Jaguar XJ8, 2000 Harley Road King
66 Austin-Healey BJ8
Lakewood, CO
You may not post new threads
You may not post replies
Window felts calif phil Body Restoration 2 10-17-2008 09:37 AM
4th gen window felts OldChevysNeverDie Body Restoration 6 06-19-2008 06:54 PM
window felts 1985elkySS Parts for sale 4 08-22-2005 02:53 PM
Window Felts 81_64Caminoman Body Restoration 8 05-24-2005 04:31 AM
Window felts shane22 Tips & Tricks 3 11-14-2003 06:28 PM
